2022 NorCal Wheeling, Camping, and Fuckery Thread
Discussion in 'Northern California' started by Blue Canary, Jan 2, 2022.
  1. Sep 18, 2022 at 6:22 PM
    #1561
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    essjay, silvertep, Impoy47 and 3 others like this.
  2. Sep 18, 2022 at 6:50 PM
    #1562
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Damn! Hwy 108, Sonora Pass, is closed. Snow and ice.
    TacoEspecial likes this.
  3. Sep 18, 2022 at 6:54 PM
    #1563
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Snow is in the forecast above 9000' for the next few days.
    ian408[QUOTED] likes this.
  4. Sep 18, 2022 at 8:11 PM
    #1564
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Wild!
  5. Sep 18, 2022 at 8:26 PM
    #1565
    nDub
    Lead Free Gasoline
    That shark fin obstacle is one that always sticks out to me. Drive out onto it then take a total blind passenger turn down a super steep spot.
    That flop was quick!
  6. Sep 19, 2022 at 12:33 PM
    #1566
    k3g
    k3g Well-Known Member
    Santa Clara, CA
    2023 Tacoma TRD Off Road
    100% send 0% skill
    Slight departure from the norm here, but what pull rating winch do y'all run for the Sierras? I've got a third gen with ~500lbs of stuff (dirt bikes, camping gear, etc).
    I was thinking I'd just get Harbor Freight's 12k winch and call it a day, even though it'll be a bit overkill.
    EDIT: since most of these threads always need more pics, here's the truck in question up near Cherry Lake:
  7. Sep 19, 2022 at 12:42 PM
    #1567
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I don't think 12K is really over kill at all. I'm running the HF Apex 12,000 now. I used to run a Warn M8000.
    8000# would be on the low end of what I need, 12K# is on the high side... but I'm a lot more comfortable knowing I should have more than enough.
    rob1208 and Blue Canary[OP] like this.
  8. Sep 19, 2022 at 12:44 PM
    #1568
    k3g
    Santa Clara, CA
    100% send 0% skill
    How long have you had the HF Apex? Any complaints?
    I figure if it's good enough for Matts off road recovery to use, it'll probably be mad overkill for my needs...
  9. Sep 19, 2022 at 12:54 PM
    #1569
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I started using it earlier this year. I've had to pull rope 4 or 5 times with it already. Works like a champ.
    Pulling rope in free spool is smooth and easy. The Free Spool lever is easy to use, even with gloves. The wireless remote is great. The line speed is really good. And, it has lot's of power.
  10. Sep 19, 2022 at 12:55 PM
    #1570
    k3g
    Santa Clara, CA
    100% send 0% skill
    Thanks, that's good to know.
    I think the price is so good I'll grab one on the way home from work. My bumper should be here Wednesday, so I want to have my ducks in a row to install it all as soon as I can.
  11. Sep 19, 2022 at 12:55 PM
    #1571
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I used it in the video a few posts above, as a matter of fact... check it out.
  12. Sep 19, 2022 at 1:21 PM
    #1572
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I have a warn 10k winch on my rig. I would've gone with a 12k if I had the extra disposable money at the time AND if I knew it would fit in my bumper with minimal modifications. 10k is more than enough pulling power for what I need but I would love the extra capability of a 12k in case I ever had to pull myself or another, possibly heavier rig out of a bad situation.
    I think I read somewhere before that a good rule of thumb for winch size would be 1.5x of your rig's weight.
  13. Sep 19, 2022 at 1:24 PM
    #1573
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    1.5x rig weight is a good rule of thumb. I've heard that quite often.
    rob1208[QUOTED] likes this.
  14. Sep 19, 2022 at 1:32 PM
    #1574
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There's a lot that goes into selecting a winch. How much does the truck weigh? Double that. Are you gonna be able to add a bumper and will it be adequately connected to the frame so you don't rip it off? So many questions.
    12,000 pounds is probably a start. But if you just make the basic attachment, you come close say 7,000 pounds, you might damage the truck. Do you know how to use the winch so that you (or those around you) don't get hurt? The winch draws enough current that it must be connected to the battery directly--you will need a breaker and correctly sized wire.
    Be worth spending some time and reading various winch makers websites. Like Warn.
  15. Sep 19, 2022 at 1:38 PM
    #1575
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Brought a new friend home from the shelter yesterday.
  16. Sep 19, 2022 at 2:16 PM
    #1576
    k3g
    Santa Clara, CA
    100% send 0% skill
    Thanks for breaking down the checklist, getting double checked is always good.
    Mounting will be on a Greenlane offroad stump bumper, so a proper mounting setup is fine. If I need to relocate the solenoid, I'm a HW engineer and a fabricator, so that won't be an issue.
    Regarding using it (safely!), I've done plenty of rigging and winching, but never on an off road vehicle. Most of my background comes from pulling cargo into/out of aircraft, which was always done with snatchblocks + straps + the hydraulic winch in our helicopter. Having a winch offroad will be new to me.
    El Taco Diablo likes this.
  17. Sep 19, 2022 at 4:27 PM
    #1577
    theesotericone
    Bishop CA
    I have an Engo 12K that's been beat and abused. It's never failed me.
    As far as the 1.5x rule goes. That's a fine rule. I went big because I knew I'd use it. The higher the rating the less the winch has to work the less time it needs to cool off from overheating. A 12K is perfect for that. My longest winch was well over 300 yards with a dead stick rig. That winch never once needed to stop to cool off. It just kept pulling, and pulling and pulling. That reminds me. I should really repack that thing with grease one year. lol
    nDub and rob1208 like this.
  18. Sep 19, 2022 at 5:16 PM
    #1578
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Duty cycle is a good thing to look at. You may also want a larger battery to help as well.
  19. Sep 19, 2022 at 8:55 PM
    #1579
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Another good thing to remember if you are winching someone else is to keep the truck in neutral and foot on the brake. Keeps stress off the tranny. Also allows you to double foot and keep your rpm’s up.
  20. Sep 20, 2022 at 9:59 AM
    #1580
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    THIS ^^^
    You don't ever want to do a hard pull with an Auto in park. That could be messy.
    Dan8906[QUOTED] likes this.
