2022 Speedometer Calibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nash, May 23, 2022.
  1. May 25, 2022 at 5:40 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    It is a self install. Very easy. Pop off the radio bezel, then the instrument cluster bezel. Remove the screws for the instrument cluster. Unplug the large plug at the upper center of the cluster, plug in the jumper to the cluster and the other end to the connector that originally plugged into the cluster. It took less than 10 minutes.
    musicisevil likes this.
  2. May 25, 2022 at 8:18 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    For op and anyone doing this in the future: when programming the calibrator with software before installing it, use the factory listed metric size for “stock” (I.e. p265/65 r17) and the actual, real-life measured diameter for your new tires (As in, go out and measure ground to top of the tire four times and take an average. My toyo at3s measured 31.75” despite supposedly being 33s). This method was suggested in RCs how to video for their calibrator, and doing it that way made the calibration spot on first try for me.
    I actually left the usb cable dangling to make changes if needed, but yanked it out after testing the calibration against 3 gps apps and two radar signs
    Speedfreak likes this.
  3. May 25, 2022 at 9:21 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    yeah I did it myself. Very easy to do. Also, you’ll find the hidden taco :thumbsup:
    It’s helpful to leave the USB accessible because if you just plug in your to and from tire size it isn’t exactly accurate. I had to say my 295/70r17s were 33.8” even though they aren’t. Tested a bunch going 80 and using GPS
  4. Jul 29, 2022 at 12:12 PM
    navin
    navin Well-Known Member
    I went to 265/75-16 from stock 245/75-16 on my 2022 SR and passing a few radar signs in a Pa.highway construction zone today, (like 8 total), two said I was going 3 and 5 mph faster than indicated, the others were dead on with my CC setting and digital display.
    By the way, 1200 highway miles today.... 6th gear is useless. Gears soon. 4 banger, 2WD. It has the stock oem 4.30 already, thinking 4.88 isnt enough, even for a street truckster. Now to surf ratios!
  5. Jul 29, 2022 at 2:56 PM
    snakeplissken
    snakeplissken Call me Plissken
    Yeah I went from stock to 33s and using gps against my speedo Im within 1mph at 70mph on a flat road.
    navin likes this.
  6. Jul 29, 2022 at 3:07 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Leave it alone. Unless you're going from stock to 35-37" tires it isn't worth the effort. Even from the factory the speedometer will be off 3-5% with factory tires. And it is constantly changing as you drive because your tires wear down and get smaller as you drive. A set of 265/70/17's with 40,000 miles on them will be the same diameter as 245/75/16's when they are new. You can either choose to have the speedometer calibrated right with new tires, or old tires. They shoot for a middle ground from the factory. They will read a little slow with new tires, a little fast when the tires are near the end of their useful life. Most drivers find the speedometer more accurate after they go up one size than with stock tires. At least when new.
    You'll be within 2-3 mph of accurate at 70. At speeds of 50 or slower you'll only be off by 1-2 mph. There is a reason no cop will write you a ticket unless you're doing at least 5 over. In fact here in GA with a couple of exceptions you have to be 11 over for them to write a ticket. It's the law.
    BC Hunter and navin like this.
  7. Jul 29, 2022 at 3:11 PM
    snakeplissken
    Yeah until you hit the super speeder limit in Georgia…. Around a $1800 ticket ouch.
    navin likes this.
  8. Jul 29, 2022 at 3:22 PM
    navin
    Not a chance to get a speeding tix in this rig! Hahaha. It liked fifth gear at 60/65. Sixth gear wouldnt hold for very long and itd jump to fourth all too often where it would hold fifth most of the time.
    snakeplissken likes this.
  9. Jul 29, 2022 at 4:25 PM
    OldCity
    OldCity Well-Known Member
    St Augustine Florida
    2022 Tacoma TRD Offroad DCLB
    Icon Stage 3, 285/70/17 KO2/Fuel Tech 17x9 +1 Offset, Cab mount chop, DiamondBack Tonneau, KDMax Pro+XT,
    I used the Hypertech one. Easy install and works on a 22 even though it say “up to 21”.
    I just left the usb attached as well as it took several adjustments to get it spot on.
  10. Nov 28, 2022 at 1:54 PM
    Iceman1N
    Iceman1N Active Member
    2022 Metallic Grey Toyota Tacoma TRD Off-Road
    Soooooooooo this confirms it works for a 2022???
    Literally just got off the phone with hypertech and they said they haven't tested it on a 2022 lol. Don't wanna buy it and have it not work but the speedo difference/gas mileage readouts/ etc etc etc are really beginning to piss me off lol.
  11. Nov 28, 2022 at 2:44 PM
    OldCity
    I have in on my 22 TRDOR so I can attest it works.
    Iceman1N likes this.
  12. Nov 28, 2022 at 3:02 PM
    Iceman1N
    Awesome thanks! Boutta pick it up right now lol
  13. Nov 28, 2022 at 4:15 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My friend just did the Rough Country on his new trail edition. It worked on his 2022 when he went to 285s. irs not that hard after I have seen it done. My tuner did mine and its worth it.
  14. Dec 2, 2022 at 9:26 AM
    Iceman1N
    When you set up your calibrator to update and enter tire size did you have to enter your truck as a 2021 Tacoma?
  15. Dec 2, 2022 at 9:40 AM
    #35
    VaToy
    Parts Unknown
    I don't think so. My kdmax tuner did it.
  16. Dec 2, 2022 at 10:29 AM
    #36
    Iceman1N
    I just did lmfao and it worked at least from what I can tell. Haven't highway tested it yet but it appears to be 1-2 mph HIGHER now... which is like stock and I'm okay with that
  17. Dec 2, 2022 at 11:00 AM
    #37
    OldCity
    Yes I just listed it as a 2021.
  18. Nov 26, 2023 at 6:45 AM
    #38
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    This can't be accomplished with a software update? Or like the OTT Tune?
  19. Nov 26, 2023 at 7:16 AM
    #39
    musicisevil
    Alaska
    2019 TRD Sport
    Nah
  20. Nov 26, 2023 at 7:49 AM
    #40
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    @BLtheP had some trouble with one of these I think but I don’t remember the specifics.
    I am rocking stock size on my 3rd Gen so I’m in ignorant bliss :)
    About to swap the diff in my ‘05 and I’ll need to recalibrate that but 2nd Gen Tacomas are easier to do.
