2022 Tacoma DCLB not starting after 2900 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kosta2009, Nov 23, 2022.
  1. Nov 23, 2022 at 12:07 PM
    Kosta2009
    Kosta2009 [OP] Well-Known Member
    Constantine
    2022 silver Tacoma SR5 4x2 DCLB
    None
    Went in my truck to go to the local Costco. Truck doesn’t start, almost like it ran out of juice. Only has 2983 miles. Only things I have electrical is oem LED lights with harness from Dave, I have raptor lights on with fuse tap but it’s on when the headlights are on and off when headlights are off. I didn’t leave anything on. Truck has no codes etc.
  2. Nov 23, 2022 at 12:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Does it turn over? How are the fuses?
    Kosta2009[OP] and SR-71A like this.
  3. Nov 23, 2022 at 12:11 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Probably gunna need more info than that. Does it turn over and not fire, not turn over at all, just clicks?
    Kosta2009[OP] likes this.
  4. Nov 23, 2022 at 12:13 PM
    Kosta2009
    Constantine
    None
    Sorry guys. It barely makes noise as it tries to turn over. If that makes sense. Then nothing and fuel gauges moves back down and as the gauges moves down it clicks.
    upon trying again I do hear the fuel pump engage.
  5. Nov 23, 2022 at 12:14 PM
    Kosta2009
    Constantine
    None
    As for fuses what should I check?
  6. Nov 23, 2022 at 12:15 PM
    roundrocktom
    roundrocktom Well-Known Member
    2021 Silver DCLB Off Road
  7. Nov 23, 2022 at 12:16 PM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    does it shows any messages on the dashboard. i have an random issue every once in a while where the dash screens says "Check Charging system" in that case i usually put the jump pack i have in the back seat. but i have check that the battery is reading like 13volts with the engine off.
  8. Nov 23, 2022 at 12:16 PM
    SR-71A
    Zack
    Southern Maine
    If its trying to turn over that makes me think low battery. Anyone around that can give you a jump? Also turn off everything electrical like headlights, radio, HVAC fan etc. save every last bit of power for the starter
  9. Nov 23, 2022 at 12:17 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    LED gremlins.
    MJTH, Cadha13, MR E30 and 1 other person like this.
  10. Nov 23, 2022 at 12:18 PM
    Kosta2009
    Constantine
    None
    I did get a check charging system just now. I thought it would be something I shouldn’t have to worry about for a bit. Someone is coming to give me a jump
  11. Nov 23, 2022 at 12:27 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    loose battery terminal? :confused:
    SR-71A likes this.
  12. Nov 23, 2022 at 12:31 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Everytime your ignition is on and the engine is off, it will display “check charging system”. Completely normal.
    4xThad, Irons, gsubioguy and 7 others like this.
  13. Nov 23, 2022 at 12:31 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Have the battery load tested ASAP! Dead and dying batteries are known to kill alternators quickly.
  14. Nov 23, 2022 at 12:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Kill alternators? Wut?
    2016Tacoman, Simple Man and MR E30 like this.
  15. Nov 23, 2022 at 12:53 PM
    OldCity
    OldCity Well-Known Member
    St Augustine Florida
    2022 Tacoma TRD Offroad DCLB
    Icon Stage 3, 285/70/17 KO2/Fuel Tech 17x9 +1 Offset, Cab mount chop, DiamondBack Tonneau, KDMax Pro+XT,
    +1 on the Nico jump pack. Carry one in all my vehicles.
    Chew and Kosta2009[OP] like this.
  16. Nov 23, 2022 at 1:11 PM
    Kosta2009
    Constantine
    None
    My dad and I jumped the truck. Going to check the battery with meter now.
  17. Nov 23, 2022 at 1:14 PM
    Kosta2009
    Constantine
    None
    no, first thing I checked
  18. Nov 23, 2022 at 1:21 PM
    Kosta2009
    Constantine
    None
    Checked with meter with truck off. Battery is at 10 volts. Doesn’t want to start up again.
  19. Nov 23, 2022 at 1:23 PM
    SR-71A
    Zack
    Southern Maine
    It will take some time to fully charge if it is that dead.
    Being a new truck Id just take it to the dealer. Possibly a bad battery right from the factory.
  20. Nov 23, 2022 at 1:37 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a bad cell at 30 months. Got a free battery from my dealer. Jump start it to get it to your dealer. Any good dealer will not send you on your way if it will not start on their lot.
    2016Tacoman and RustyGreen like this.
