2022 Tacoma limited led hyper Flash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimH4662, May 13, 2022.
  1. May 13, 2022 at 4:16 AM
    JimH4662
    JimH4662 [OP] Member
    Greetings. New owner as of 3/26/2022.
    2022 MGM Nightshade.
    Any of you folks successfully changed leds in brake and rear running lights.
    Been through several Amazon 7443 brands that hyper flashed.
    Thanks
  2. May 13, 2022 at 4:26 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You need to install a resistor in line with the bulb or spend the cash and get the MESO total tail stage 1 or 2 (they have built in resistors and are plug-n-play). The truck is hyperflashing because it think the bulbs are burnt out since the LED's don't pull as much current as halogen. Resistors can be found on Amazon or at most auto part stores. Be prepared to cut harnesses and solder.
  3. May 13, 2022 at 4:28 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
  4. May 13, 2022 at 4:40 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I have not looked into the flasher relays on my truck yet, but another option is to replace it with an electronic style, they are not load sensitive and will not hyper flash with LED bulbs installed.
    airforceb2cc likes this.
  5. May 16, 2022 at 12:29 PM
    JimH4662
    Thanks for the response.
  6. May 16, 2022 at 4:29 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
  7. May 17, 2022 at 5:41 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Thank-you for this question and welcome to the forum. I am in the same boat with my 21 Tacoma Sport. So many of the Amazon bulbs say they don't fit the Tacoma as the above link also states on the website. I guess we are looking for the cheaper 10 and 12 dollar bulbs to work - but I'm pretty sure that they won't.
    Does CanBus Ready mean no Hyper Flash or that it won't show a code that the bulb is out. I took all of the bulbs out of my right taillight and started the truck and got no dash warnings ? Maybe I didn't let it run long enough. Anyway - I'm starting to be happy with the factory bulbs with all the complications that LED seems to offer.
    JJ Diablo likes this.
  8. May 17, 2022 at 6:54 PM
    JJ Diablo
    JJ.
    CT
    Amazon is wrong here. I can tell you with 100% certainty that these bulbs will and do fit in a 21-22 Tacoma. I went thru several different types that all hyperflashed on my 21 Sport Premium. I pulled that link from my past Amazon order . It is the standard 7443 bulb which is the exact size bulb Tacoma uses for brake and turn bulbs. No hyperflash, no warning lights, no resistors needed. They work perfectly.
    ernscott[QUOTED] likes this.
  9. May 18, 2022 at 2:44 AM
    AndrewW
    AndrewW Well-Known Member
    2020 Or 4x4
    Same with me, no hyper flash.
    JJ Diablo[QUOTED] and ernscott like this.
  10. May 18, 2022 at 5:26 AM
    JimH4662
    I've tried approx 4 MFG leds supposed to be canbus ready. But hyper flashed. Odd thing is had an old set used in third break light Ram 2019 1500. They worked in Back up lights.
  11. May 18, 2022 at 5:34 AM
    wayne0
    wayne0 Well-Known Member
    I did this on a Celica. Easy fix!
    Speedfreak[QUOTED] likes this.
  12. May 18, 2022 at 5:38 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Welcome to TW!
    Honestly, I’d recommend the @MESO stage 1 total tails, in case you’ve not seen them. They’re sold out on his site but one of his dealers has them listed as in stock… there might have been a set here for sale somewhere too-
    edited to add more- Ive only seen a few people have hyperflash with these during normal use. When you turn your blinker on while in reverse it will hyperflash. I think that’s just the way it is with the switchback being turn and reverse light.
    https://www.tacomalifestyle.com/products/meso-customs-total-tail-light-kit
    https://youtu.be/4gzzecHi79c
  13. May 18, 2022 at 8:52 AM
    wayne0
    Yeah, you can do that, but south of $20 sounds better to me.
    hyrule_trd[QUOTED] likes this.
