2022 Tacoma TRD Sport Audio Upgrade Wiring Help/Opinions (Morel Maximo Ultra Coax and Kicker Key)
Discussion in 'Audio & Video' started by Sprdno, Sep 28, 2022.
  1. Mar 5, 2023 at 3:27 PM
    #41
    Houston5
    Houston5 Member
    Joe
    Florida
    89 4runner, 05 Tacoma 4x4, 13 4 Runner
    3inch spacer lift
    Thank you bud everything is up and running sounds great. I would highly recommend these little amps will
    Post pic of complete later
  2. Jul 28, 2023 at 4:16 PM
    #42
    Fatclay
    Fatclay New Member
    2023 TRD Sport
    Newbie here and I just found this thread but still have questions. I have a ‘23 Sport. Adding a Kicker Key 200.4 myself to the stock unit. This thread has been very helpful about the Red Wolf harness to make a plug-n-play for the amp. My question is, where to run the blue remote turn on wire without splicing into stuff. Also, just to verify, the Red Wold harness is all I need correct?
  3. Jul 28, 2023 at 6:52 PM
    #43
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    easiest way is a fuse-tap. just need to locate a fuse that turns on/off with the key.
    Fatclay[QUOTED] likes this.
  4. Jan 13, 2024 at 6:18 PM
    #44
    ticklemytaco
    ticklemytaco Well-Known Member
    IM planning on running a Kicker Key 200.4 to speakers, and an LC2i for subwoofer. My plan is to tap into the front 2 speakers on the redwolf harness attached to the kicker key. Should I tap on the input or output side? Which would yield better results to the LC2i and Subwoofer?
  5. Jan 13, 2024 at 6:34 PM
    #45
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Absolutely the input side. The output side will have the Key’s EQ and crossover
