2022 TRD Trail/Pro Replica Wheels Group Buy (Closed)
Discussion in 'Wheels & Tires' started by Johnny77, Mar 10, 2022.
  1. Jul 19, 2022 at 5:00 AM
    #461
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Stock lugs for Steel or stock for alloy?
  2. Jul 25, 2022 at 1:35 PM
    #462
    RedWings89
    RedWings89 Well-Known Member
    Luke
    SE Virginia
    2014 SR5 DCLB
    Delivered today. Trying to decide about the center caps still.
    Inferno! and TRD_Seeds like this.
  3. Jul 30, 2022 at 7:56 AM
    #463
    junior0000069
    junior0000069 Member
    Dave
    2012 trd off road
    Finally got around to gettin' er washed. These wheels completely transformed my truck.IMG_20220730_103550084_HDR~2.jpg
  4. Jul 30, 2022 at 8:32 AM
    #464
    RedWings89
    Luke
    SE Virginia
    2014 SR5 DCLB
    Just got em mounted
    Johnny77[OP], Inferno! and TRD_Seeds like this.
  5. Jul 30, 2022 at 10:55 AM
    #465
    Nyrob
    Nyrob Well-Known Member
    Robert
    2021 SX 2.7 AT 4WD
    5100 1.1 Front, 5125 Icon Stage 2 Rear, 5.29's, LCE Header
    Anyone know the weight difference over the factory wheel trail/pro wheel
  6. Aug 2, 2022 at 5:32 AM
    #466
    mjackson92rs
    mjackson92rs Well-Known Member
    SE PA
    '15 TRD Sport
    looks like 265/70/16? any lift on that truck? Mine is set up identically and has a 1.75"front and 2" rear lift with a leer cap.
  7. Aug 2, 2022 at 5:51 AM
    #467
    RedWings89
    Luke
    SE Virginia
    2014 SR5 DCLB
    Yep - 265/70/R16. I intend to go up to 265/75 but these ones still have a lot of tread left. And the 265/70s look a lot better with the offset of these wheels than they did with the stockers, so I can probably stand to stick with these tires until they wear out.
    Truck is lifted ~2" in the front with 5100s and 885s and is around 1.75" in the rear with 5100s and an icon rxt leaf pack on stage 2.
  8. Aug 2, 2022 at 7:50 AM
    #468
    mjackson92rs
    SE PA
    '15 TRD Sport
    i wouldn't change a thing, your truck looks perfect as-is!
    RedWings89[QUOTED] likes this.
  9. Aug 2, 2022 at 8:28 AM
    #469
    RedWings89
    Luke
    SE Virginia
    2014 SR5 DCLB
    Thanks man!
  10. Aug 10, 2022 at 9:34 AM
    #470
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    Got the wheels on...turns out my kid had stuck the center cap stickers on the shelf when they first arrived. Now I need to order a set of backup center caps for when the guy at the tire shop breaks these.
    Johnny77[OP] likes this.
  11. Aug 10, 2022 at 1:24 PM
    #471
    manapiko
    manapiko Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Has anyone put these, in 17's, on a first gen?
  12. Aug 12, 2022 at 1:07 PM
    #472
    auskip07
    Skip
    Atlanta, Ga
    @Johnny77 looking over my wheels before i go to have tires mounted and balanaced but i wanted to run this by you before i went to my appointment. i saw that you all have corrected the hub clearance but do you know what accuracy the machining was done to provide that clearance? The most common way that these are balance is via the hub on a taper balancing machine and if that taper hits the "corrected" clearance portion before the hub that it rides on the truck, i think there could be discrepancies between wheel balance on the machine vs the truck.
    looking for assurance that it was done with a certain degree of accuracy
  13. Aug 12, 2022 at 1:24 PM
    #473
    Johnny77
    Johnny77 [OP] Well-Known Member
    Dustin
    San Diego, CA
    2019 Silver Sky Tacoma TRD O/R
    Thanks for posting your question. I understand your concern, but we have had zero issues with balancing after the corrections were made. We test fit every set before shipping them out. We also mount and balance in-house every day. Not only is the wheel put on the balancer with a tapered cone, but it is also clamped on with a vibration solution plate and a crank handle, which completely secures the wheel in place for balancing. Just as it would be secured on the hub when the lugs are torqued down. There should be no issues with balancing the wheels.
    -Dustin
    auskip07[QUOTED] likes this.
  14. Aug 12, 2022 at 1:27 PM
    #474
    auskip07
    Skip
    Atlanta, Ga
    thanks Dustin i feel better now, my concern was because im riding on stud mounted rims currently and i bought these rims because i wanted to get rid of the vibrations!
    Johnny77[QUOTED][OP] likes this.
  15. Aug 12, 2022 at 1:30 PM
    #475
    Johnny77
    Dustin
    San Diego, CA
    No worries!
    We take care of our customers as well, so in the event there was a problem, we would do our very best to find a solution for ya.
    Feel free to shoot me a message any time.
    -Dustin
  16. Aug 13, 2022 at 10:33 AM
    #476
    auskip07
    Skip
    Atlanta, Ga
  17. Aug 13, 2022 at 10:35 AM
    #477
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    That's the security plug, you just put JB weld in the hole and then pop it on. Real talk that's unfortunate, hopefully they take care of you quickly.
    sikeitsryan and auskip07[QUOTED] like this.
  18. Aug 13, 2022 at 10:37 AM
    #478
    auskip07
    Skip
    Atlanta, Ga
    ive contacted them but im in a rush since ill be driving to florida for vacation in a week ( i doubt they will move that fast) i bought a set of wheel locks and those should deliver sooner than ill get a response back from the seller.
  19. Aug 15, 2022 at 11:34 AM
    #479
    clubfed11
    clubfed11 Well-Known Member
    James
    Bay Area, CA
    2022 TRD OR DCLB
    Got mine mounted! Black lugs and the land cruiser caps
  20. Aug 15, 2022 at 11:47 AM
    #480
    bryanh69
