2023 4Runner agp 17 wheels w/ 4mm offset going on 2011 TRD Tacoma w/ 3in lift.. will it work?
Discussion in 'Wheels & Tires' started by Nosrac10, Dec 3, 2024.
  1. Dec 5, 2024 at 6:38 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you really want to run the 285s and do any sort of wheeling you really will need both.
    MGMDesertTaco likes this.
  2. Dec 5, 2024 at 6:41 PM
    Nosrac10
    Nosrac10 [OP] A young gun just havin fun!
    2011 Charcoal Grey Tacoma 4x4 TRD V6
    3in Lift Aftermarket Headlights/Taillights Aftermarket Grill
    Probably won’t until I’m financially ready for it lol. These wheels & tires are my last Christmas gift before I go off to college. Me and pops are meeting halfway to pay for it
  3. Dec 5, 2024 at 6:42 PM
    MGMDesertTaco
  4. Dec 5, 2024 at 6:42 PM
    Nosrac10
  5. Dec 5, 2024 at 6:45 PM
    gotoman1969
    It can be done with just ucas with the right caster set up. Doing both is best case scenario. But at minimum ucas and really good alignment.
  6. Dec 5, 2024 at 6:46 PM
    Nosrac10
    So I can’t go without a cmc or uca’s?
  7. Dec 5, 2024 at 6:46 PM
    gotoman1969
    And return the 2” spacer and go with the 1” , I believe Bora or Spidertax makes a 1/2” spacer that would work too.
  8. Dec 5, 2024 at 6:47 PM
    gotoman1969
    With out the cmc if you get ucas
  9. Dec 5, 2024 at 7:01 PM
    Nosrac10
    So I can’t run my new tires at all without either the CMC or the new uca’s? What would happen if I ran them with spacers only?
  10. Dec 5, 2024 at 7:08 PM
    gotoman1969
    They will rub on the factory set up. With just spacers it will make the rubbing worse as it changes the track width and scrub radius. Unfortunately you just can’t throw on 285s and go with these trucks it takes a little bit of work. You need the spacer to clear the ucas with that wheel but then the additional track width causes another set of issues unfortunately.
  11. Dec 5, 2024 at 7:08 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Spacers only help with clearing the uca, but creates problems with the fender plastic and cab mount. 2" spacers are not the answer. Get 1" and a CMC, and trim whatever plastic rubs. CMC should cost $100~, as opposed to $900 control arms.
  12. Dec 5, 2024 at 7:11 PM
    Nosrac10
    I have a mechanic at work who’s experienced with truck welding.. do you think I could get him to do my cmc or do I need to take it to a specific outfitter to do it? 100 isn’t too bad.
  13. Dec 5, 2024 at 7:12 PM
    Nosrac10
    Gotcha. I’m just trying to figure out if I can run it with just spacers temporarily
  14. Dec 5, 2024 at 7:17 PM
    gotoman1969
    The I’d go with the least amount of spacer needed to just clear the ucas. Knowing they’re definitely will rub on full turns and even probably half turns if hitting a bump like going onto and angled slope and backing up while turning.
  15. Dec 5, 2024 at 7:28 PM
    #35
    Nosrac10
    Found this cmc on tw. My mechanic has the trimming tools to do this and I bet it’d be a walk in the park for him. I’ve seen him weld and cut off a bunch of different things on the trucks around the workplace. He’s my girlfriends grandfather so I bet he’ll hook me up for some help around the shop in return:D
    https://www.tacomaworld.com/threads/3rd-gen-cmc-quick-diy.618098/
    gotoman1969 likes this.
  16. Dec 5, 2024 at 7:29 PM
    #36
    Nosrac10
    Yeah.. sounds like the best option is to wait until I’m all ready to go. I appreciate the advice guys
    gotoman1969[QUOTED] likes this.
  17. Dec 5, 2024 at 7:35 PM
    #37
    Nosrac10
    So my gameplan:
    - Run current wheels/tires with 1in spacers when I get them in
    - See if my mech would want to do the cmc at some point (if not I just take it to a shop in town somewhere)
    - once cmc is on then I can put on the new wheels/tires
    - new uca’s in the future
    sound good @gotoman1969 @Wyckedan @MGMDesertTaco ???
  18. Dec 5, 2024 at 8:12 PM
    #38
    MGMDesertTaco
  19. Dec 6, 2024 at 4:35 AM
    #39
    gotoman1969
    Sounds like a plan. Once all that is done. Take it and get a good alignment. Have the tech set the caster as high as possible while trying to keep the camber as closes to spec as possible. Good luck at school.
  20. Dec 12, 2024 at 8:02 PM
    #40
    Nosrac10
    Thanks man!
