2023 Android Auto (wireless)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bails, Sep 17, 2023.
  1. Sep 17, 2023 at 4:21 AM
    Bails
    Bails [OP] Well-Known Member
    Tampa, Florida
    2023 TRD Sport 2WD
    Have my new 2023 TRD Sport, and I take it I can't connect to android auto wirelessly?
  2. Sep 17, 2023 at 4:28 AM
    apowers
    apowers '23 TRDPro6MT Solar Octane
    TRDRed, batmanis243 and Bails[OP] like this.
  3. Sep 17, 2023 at 10:01 AM
    bubbaearle
    bubbaearle Well-Known Member
    N Central Arkansas
    2012 DCSB TSS , 2003 SR 2.4l 5spd, 2023 DCSB SR V6 4x4
    I have a CarlinKit 5 and it works with both Android & Apple. So far it's worked pretty good, connection is fairly quick & stable. I have less audio drops outs with it than being connected via USB cable.
    Bails[OP] likes this.
  4. Sep 17, 2023 at 5:14 PM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    Can I use 1 of the USB charging ports in the center gloove box to connect the wireless adaptor? That way it would be out of the way and not seen leaving the USB for whatever else, or does it need to be close to the head unit?
  5. Sep 17, 2023 at 5:18 PM
    apowers
    Nope. You will need to use the one close to the head unit. That's the one one set up to use with android auto/carplay. You can relocate that to the glove box if you want.
    hilighter and TRDRed like this.
  6. Sep 17, 2023 at 5:24 PM
    Bails
    Tampa, Florida
    2023 TRD Sport 2WD
    Figures it wouldn't be that easy
  7. Sep 17, 2023 at 7:40 PM
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
  8. Sep 18, 2023 at 8:01 AM
    attc44
    attc44 Well-Known Member
    Wisconsin
    Magnetic Gray Metallic 2021 TRD Sport
    That must be the problem I have with my MA1. There's a spot on the freeway near my home where Android Auto disconnects, every. single. time.
  9. Sep 18, 2023 at 10:34 AM
    RicerRabbit
    Itz JDM tyte, yo!
    Yeah that’s it. And when I contacted Motorola to ask if there is a fix, they said there’s none
  10. Sep 18, 2023 at 2:37 PM
    bubbaearle
    N Central Arkansas
    My CarlinKit 5 has a disconnect issue at the same place in town when I drive down a certain street.
  11. Sep 18, 2023 at 2:49 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    FWIW my Pioneer DMH-WC6600NEX does this as well in certain places every time like clockwork. The BT also has the same issue in my other car in the same spot, as does my bosses fully stock Taco when connected to BT on her phone. Just the nature of the beast with wireless connections. It is trouble free the other 99.9% of the time though.
  12. Sep 18, 2023 at 8:08 PM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    I run one of these too. And love it. For the price, you can't go wrong. I intended on relocating the USB but I still just have it dangling there.
    Like you, there's a spot on my drive to work where it disconnects every morning. Exact same spot...like EXACT. The weird thing is, while the current spot of disconnect is always the same, it used to be about 3/4 of a mile further down the road. It just shifted like 6 months ago. :confused:
  13. Sep 18, 2023 at 10:15 PM
    RicerRabbit
    Itz JDM tyte, yo!
    It happened on some cars that came with wireless Android Auto from the factory too. I rented a '22 Durango R/T one time and it disconnected as well.
  14. Sep 18, 2023 at 11:11 PM
    TRDRed
    TRDRed Well-Known Member
    Pacific Northwest Playground
    2020 TRD OR DC SB OTT Tune
    Even though it was attached under the dash I didn't like seeing the wireless adapter so I ended up hiding it behind the dash. Works perfectly. Although it's for Car Play as mentioned earlier, there are equivalent adapters for Android Auto. I keep my phone in my pocket and it connects every time I get in. More here:
    https://www.tacomaworld.com/threads/usb-port-opening-size.805008/#post-28948954
    stftaco likes this.
  15. Sep 19, 2023 at 4:47 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    That's not a bad idea. However, I'd either find something to put in it's place on the dash (maybe a USB port just for charging), or blank it off.
    I was hoping you'd discuss how you detached the lower part of the dash holding the port and BSM etc, since I was in there this weekend, had the radio out (as I was adding the amp), and pulled the environmental controls panel. Couldn't figure how the lowest part was detached though.
    In another thread, I think you mentioned that a USB splitter might work? I believe I read somewhere that the Head Unit doesn't recognize two USB inputs, and so that's going to be nojoy. YMMV.
  16. Sep 19, 2023 at 4:55 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I have a 2021 Sport and my Android works fine on any WiFi that is near but not on the main roads. I cannot make calls on WiFi but can download data no problem.
  17. Sep 19, 2023 at 5:02 AM
    stftaco
    That's pretty odd. Possibilities:
    Maybe on your phone you have selected calls via WiFi, because you have poor cell coverage, and/or you want to save cellular data, and/or you have implemented a threshold on your cell data for each month that cannot be exceeded
  18. Sep 19, 2023 at 6:17 AM
    Nirango kid
    Gilles
    Ontario
    My phone does not support WiFi calling so it is useless to me. Yes we have poor cell coverage as I live in a remote area. I have lots of data on my phone which I do not use as I can download all the apps, internet etc on my phone from home with Wifi. I will be changing my plan to less data as I use my phone unlimited text and long distance calls.
    TRDRed likes this.
  19. Sep 19, 2023 at 6:33 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I have had the Carsifi wireless adaptor since about March 2022 in my 2020. I have tried changing the wifi channel in the settings app a few times. No matter what channel I choose 2.4 or the 5GHz band there is always some place that I regularly drive that I get Audio drop outs from interference. Its not that often but predictable on my daily commute. Otherwise its good. the Carsifi has a button that lets you flip between 2 android phones. It does not however support iPhones Which sucks because my Partner has a 13 pro Max and can't use carplay without unplugging the adaptor and changing settings in the head unit, but bluetooth works for music without changing all my settings.
    Would the Carlink 5 let us connect either Phone without going in to the head units menus and switching carplay/android auto on or off?
    edit: This answers my question: https://********************/blogs/...switch-from-connected-carplay-to-android-auto
    TRDRed likes this.
  20. Sep 19, 2023 at 6:34 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    for me a new head unit was the right answer. YMMV.
    *but i bought the SR with the understanding that i didnt want to pay money for a factory upgraded sound system that i would never be happy with.
    TRDRed and stftaco like this.
