2023 bed liner
Discussion in 'General Tacoma Talk' started by Wings 350, Nov 28, 2023.
  1. Nov 28, 2023 at 9:09 AM
    Wings 350
    Wings 350 [OP] New Member
    Hi everyone! I just got my 2023 Trd sport access cab and I’d like to know is the factory bedliner adequate or should I invest in a line X
    davidstacoma likes this.
  2. Nov 28, 2023 at 9:10 AM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    there is no such thing as a factory bedliner lol. however a factory bed mat does exist.
  3. Nov 28, 2023 at 9:13 AM
    Wings 350
    So the plastic walls and floor is not a bedliner that is the bed is that true?
  4. Nov 28, 2023 at 9:22 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    The composite factory bed has been fine for me.
  5. Nov 28, 2023 at 9:24 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  6. Nov 28, 2023 at 9:40 AM
    Elkhart
    Elkhart Well-Known Member
    Anthony
    New England
    2013 TRD Sport DblCab Long Bed, Mica Silver
    Stock
    yep. Composite (read: plastic) beds from 2005 onward.
    Bed Mat is nice to prevent things from sliding around, but not really needed for most cargo
  7. Nov 29, 2023 at 5:45 PM
    spp
    spp OC, Kalifornia
    OC California
    When I drilled into my 2007 I got white dust more like fiberglass than plastic.
  8. Nov 30, 2023 at 5:00 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    fiberglass is a composite. but it's not the only composite either.
  9. Dec 5, 2023 at 5:13 AM
    TedTRD
    TedTRD Well-Known Member
    Charles
    2023 Tacoma TRD
    The factory bed is composite. Used my truck for moving furniture and deer hunting and it’s durable. If you have the bucks add the OEM bed mat. Keeps things from sliding around back there and easy to pull out and hose clean when needed.
  10. Dec 5, 2023 at 10:11 PM
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
  11. Dec 6, 2023 at 1:04 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    It would be cool to have a guinea pig get the plastic bed Line Xd just for the hell of it. Kind of like how I'd like someone on a brand new 3rd gen to never change the oil so we can put this whole 5k-10k controversy to bed. I bet a new truck makes it 100k w/o the 1st oil change.
  12. Dec 6, 2023 at 1:33 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Been fine in my ‘14. It doesn’t rust but fiberglass will show wear.
  13. Dec 6, 2023 at 1:52 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    The new Tundra has a composite bed also, and it has a factory liner option similar to Line X. I think it is mostly to make it less slippery.
  14. Dec 6, 2023 at 7:05 PM
    soundman98
    NW Indiana
    absolutely possible to bed line a composite bed, as the bed liner is just a coating. it's extremely common in the offroading community to bed line the bottom edge of offroad vehicles, as the coating is tougher than standard paint, and hides trail damage better. a coworker has his entire jeep bedlined just to be different.
    there is an advantage to bedlining it, as it becomes a sacrificial wear layer, and depending on the coating, and can be more robust than the factory composite material.
  15. Dec 6, 2023 at 7:13 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    not common to do, but people on here have done it. Not sure of long term durability.
  16. Dec 7, 2023 at 4:40 PM
    soundman98
    NW Indiana
    really comes down to the quality and thickness of the coating. the off-the-shelf aerosol can bed liners, even 6-10 coats thick won't compare to 2 coats of a 2k raptor liner, which likely won't compare to a professionally-applied, chemically-mixed formulation.
  17. Dec 7, 2023 at 5:10 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I agree, I meant more along the lines of long term bonding to the bed surface after prep.
  18. Dec 7, 2023 at 5:30 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm not a fan of spray in bed liners. Over time they wear out just like anything else. I'll take a rubber bed mat every time over a spray in liner. Even though not needed to protect the Tacoma composite bed they do keep stuff from sliding around in the bed and since I have a cap on my truck they are a lot easier on the knees if I need to get in there.
    The composite bed in my 17 year old Tacoma has held up better than steel beds on trucks of the same age. I have no doubts about it.
  19. Dec 7, 2023 at 6:54 PM
    PooTaco
    Utah
    Only reason I puchased a liner was to keep stuff from sliding everywhere.
    The pretection of scuffing the bed is also a plus.
