2023 Manual Transmission Floor Mats
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigpapajt, Jan 11, 2023.
  1. Jan 12, 2023 at 7:20 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I had WT and they were hard, slippery, and ill-fitting.
    I got Husky Xact liners which are softer, don't move, and have a superior fit.
    MT driver-side floor does not have a tall dead pedal like the automatic driver-side floor.
  2. Jan 12, 2023 at 8:02 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I like the OE all weather mats. They are molded and offer good protection but are also a soft rubber. They do not get harp and slippery like my WT's did.
  3. Jan 12, 2023 at 2:06 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Just got mt TuxMat today
  4. Jan 12, 2023 at 3:41 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I wore out the OEM’s in 1 year. My heel wore through. Get the Husky brand.
  5. Jan 12, 2023 at 3:54 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Those look nice, great coverage. Dam just looked them up. Suburb Toronto, gf was just there for a month visiting family. I could of had her pick them up.
  6. Jan 14, 2023 at 5:17 AM
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    AT and MT mats are 100% not the same. The dead pedal is half the size and the AT mats will interfere with the clutch.
  7. Jan 14, 2023 at 5:45 AM
    hambone72
    hambone72 Member
    Daniel
    Central Louisiana
    2023 TRD Pro MT Solar Octane
    Just installed Weathertechs in my 2023 Pro with the manual transmission yesterday. Love them. Have also used Husky brand in the past. Both are excellent floor liners. Pretty sure I just ordered for the 2022 on the weathertech website when it either didn't give the option for 2023 or said that they would not fit.
  8. Jan 18, 2023 at 10:37 AM
    milesbeyond
    milesbeyond Well-Known Member
    Seattle, WA
    ‘23 Solar Octane TRD Pro M/T
    Man this looks great. I'm tempted to just buy a full set and have use them everywhere except the driver side. I'm assuming yours is an AT? I emailed and Tuxmat confirmed theirs won't work with the clutch pedal but curious if you actually have a MT and making it work?
    We have 3DMaxpider mats in our Kia Telluride. They fit really well, but they're just a little stiffer than I want them to be. They also don't make them in MT for the Tacoma.
    The biggest difference as you can all tell by the photo is the amount of extra coverage these 3rd party mats give than the OEM mats. I have the TRD OEM rubber mats for my MT but still a ton of carpeting left for my two little kids to get messy.
    For the Huskyliners - is standard transmission their name for MT? They also have "other" so not sure which was which. It looks like the X-contour doesn't have a MT option but the regular Weatherbeater does.
  9. Jan 18, 2023 at 11:08 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Yes “standard” is MT. Weatherbeater is what they offer for us. The X-contour are nice and more soft, ours are more plasticky. I wish we could get the X but the weatherbeaters are pretty dang good. My only complaint is that I have to push the clutch sorta hard to start or get into 4LO. I might adjust that switch to make it less sensitive.
    milesbeyond[QUOTED] likes this.
