2023 manual transmission in cold
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Dec 4, 2023.
  1. Dec 5, 2023 at 5:12 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I have the ADM delete but don't have 5.1 fluid. It still stiffens up in the cold, I wouldn't want to know how bad it would with if I still had the accumulator.
  2. Dec 5, 2023 at 7:21 AM
    BillyE
    BillyE Well-Known Member
    Delete the accumulator and switch to a low viscosity brake fluid (I used Pentosin DOT 4 "LV" but there are others as mentioned earlier).
    Also--Sport models share the reservoir with the brakes. Pro and OR have separate reservoirs.
  3. Dec 5, 2023 at 9:47 AM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    Northeast. NJ
  4. Dec 5, 2023 at 9:48 AM
    2023tacomer
    It was hydraulic thought.
  5. Dec 5, 2023 at 1:53 PM
    InThePlains
    InThePlains Well-Known Member
    Yes, hydraulic.
  6. Dec 5, 2023 at 3:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve owned many vehicles with manual transmissions in Minnesota and never experienced as much viscosity in cold weather than with my Tacoma. Caveat: I don’t notice it unless I let it sit outside overnight in 10F or below. Otherwise it’s just normal cold weather stiffness.
    I heard one report that the accumulator delete mod does not solve the issue.
  7. Dec 5, 2023 at 3:57 PM
    Manitoba
    No it doesn't solve the issue it makes it less though. My 22 corolla acted the same way. My older car did the same thing. It was expected and isn't an actual issue
  8. Dec 5, 2023 at 4:36 PM
    Pscdouglas
    Pscdouglas Wish you weren't so awkward Darry.
    Stu
    Glens Falls, NY
    2004 black Tacoma Xtracab 4WD TRD AT, 2020 Black Tacoma ACLB 4WD Sport MT
    I total y read that statement in the voice of Bubbles from Trailer Park Boys :rofl::canada:
    Diablo169[QUOTED] and Junkhead like this.
  9. Dec 5, 2023 at 4:47 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    This, even my 69 FJ40 was hydraulic as were all the later one's I had. Same for my 84SR5.
    Junkhead likes this.
  10. Dec 5, 2023 at 5:16 PM
    gudujarlson
    Minnesota
    I’ve never seen a cable clutch on anything except a motorcycle as far as I remember back to my 1974 Datsun pickup. I could be senile.
    shakerhood likes this.
  11. Dec 5, 2023 at 5:31 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Bishop is it normal for these trucks to have vibrations under different acceleration patterns especially as the engine is warning up? I swear everyone of these trucks have a different personality after owning so many of them
  12. Dec 5, 2023 at 5:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Most of my vehicles have had cables.
    BillyE and Speedfreak like this.
  13. Dec 5, 2023 at 7:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Yea, its just cold rubber, cold metal, all varying warming up rates.
    My truck rattles my cup holder like crazy when its cold.
    shakerhood and Gfenza89[QUOTED] like this.
  14. Dec 5, 2023 at 7:06 PM
    Gfenza89
    Thanks what year is your truck ?
  15. Dec 5, 2023 at 7:19 PM
    #35
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    It sucks when they leak but I do like clutch hydraulic designs with the slave inside the bell-housing like ford's because everything stays nice and light unlike our hydraulics that shed their heat and takes longer to warm up
  16. Dec 5, 2023 at 7:53 PM
    #36
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Most of my vehicles were cable... Fox body Mustangs. First thing to modify was throwing away the self adjusting quadrant and installing a BBK manual adjusting aluminum quadrant with adjustable cable. Even my old 1978 Honda Civic was cable.
    My 1980 C20 3/4 ton square body Chevy pick up was linkage.
    The only vehicles I have had with hydraulic clutches were a 4Runner, a Corolla and my Tacoma. The only one with the firm pedal issue when cold has been the Tacoma though....
    I don't remember if my Samurai was cable or hydraulic.
  17. Dec 5, 2023 at 7:55 PM
    #37
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I haven’t had any cable setups before. I’ve had all hydraulic on everything except the family 82 CJ7. That thing used a terrible mechanical bell crank linkage that was nearly impossible to get shifting right and if you flexed the body and frame enough, the pieces of the linkage could fall out. It only got worse with body lift too.
  18. Dec 5, 2023 at 8:00 PM
    #38
    shakerhood
    Southern Ohio
    The only hydraulic ones for me were a Cavalier and the Tacoma's, everything else was a Cable.
    Speedfreak[QUOTED] likes this.
  19. Dec 5, 2023 at 10:52 PM
    #39
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Samurai’s have clutch cables. I carry a trail spare.
  20. Dec 6, 2023 at 1:07 AM
    #40
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Manual transmission? :hattip:
