2023 MT and the clutch accumulator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by terryhutchinson, May 22, 2023.
  1. May 27, 2023 at 3:20 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    That iMT function on the 4G is selectable BTW, just so everyone knows. It wasn't implemented on the new truck because there's no accumulator, its there as a convenience.
    Also, the accumulator was axed because they wanted to improve clutch feel and consistency. The chief engineer has stated both more than once.
  2. May 27, 2023 at 3:24 AM
    MOC221_
    Frank
    This is exactly why I did the ADM. Others are obviously ok with it in stock form.
    Junkhead and GBR like this.
  3. May 27, 2023 at 10:44 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    Right, I also read somewhere that 3G's accumulator is intended for reducing shock and wear. So with accumulator, the driver doesn't need to do a relatively good rev matching when shifting, just simply slowly releasing clutch (without blipping the throttle or waiting for the rev hang to drop to appropriate range) and let the clutch do all the rev matching.
    When they remove accumulator in the 4G, the shifting will be not smooth if one doesn't know how to rev match well, so iMT is a necessity for them, and a convenience for those who do know how to.
    Maybe Toyota put the accumulator in 3G because:
    • they assume a sizable portion of people use their truck as work/commercial vehicle and they don't take care to rev match and minimize clutch wear.
    • they have signed a long term supply contract with suppliers who make accumulators, and knowing how Toyota likes to be shareholder of their parts suppliers, it makes financial sense to keep on equipping accumulators.
    But, I think Toyota finally wised up and realized that people who buy manual Tacomas are seasoned manual enthusiasts and don't need that accumulator. That's why iMT is by default OFF and need to be turned ON each time.
    MOC221_[QUOTED] likes this.
  4. Oct 10, 2023 at 9:34 AM
    terryhutchinson
    terryhutchinson [OP] Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    I dunno. I am a very long time user of MTs - sports cars, trucks, whatever. Typically I get a lot of miles out of a clutch, certainly over 150k for whatever I have owned. It does take a couple weeks to learn a new vehicle and when my '23 MT Tacoma was new I have made some sloppy shifts. That said, my clutch feels very consistent and my shifts can be quick and smooth and I have not deleted the accumulator in my truck. When I do make a sloppy shift, it feels the way one would expect.
    BC Hunter and MOC221_ like this.
  5. Oct 10, 2023 at 3:27 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    For me the crunch comes into going into third. I'm in the same boat and have the disc and the URD short shifter just have to rally up and install it.
  6. Oct 11, 2023 at 4:46 AM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    I have noticed the occasional crunchy shifts too. Why does the accumulator cause that?
  7. Oct 11, 2023 at 4:56 AM
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    I didn't see what all the fuss was about either; felt no need to mess with anything.
  8. Oct 11, 2023 at 7:39 AM
    MattiasdelTaco
    MattiasdelTaco unknown member
    Illinois
    2023 trd sport MT
    swapped for clean, scoopless hood
    Is the accumulator physically located on the driver’s side, near the center, and behind the center part of a cat shield, if you have a shield installed? I recently installed a shield, and thought it might need to come off, just as i was finishing attaching it.
    Maybe Toyota included the accumulator to accumulate more accumulator sales, since a lot of people buy a second accumulator before modifying/deleting/effectively bypassing the original accumulator config.
    What would 2 or 3 or more accumulators in series feel and drive like? Someone should do an accumulation of accumulators mod with 4+ accumulators for the Lord’s work or science or giggles or youtube followers or something.
    TacoGranny and joba27n like this.
  9. Oct 11, 2023 at 10:59 AM
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I found you couldn't feather the clutch properly. I could never find a consistent bite point, it was always like the bite point would come on and off in waves. Drove me crazy, so I took an hour and used the Dremel method to make a groove between the holes in the accumulator. Pretty simple free mod, if it doesn't bother you then keep it. If it bothers you fix it. But I will say it definitely shifts and drives better now. None of my other manual vehicles acted like this one. Everything is personal preference.
    MOC221_ likes this.
  10. Oct 11, 2023 at 2:32 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    The accumulator only dampens the hydraulic line, thus you get a vague and inconsistent clutch engagement feel. The crunchy shifts from what I've read can be remedied by better fluid.
    Mine, once warmed up tends to be fine but I will still try a different fluid.
    02Duck likes this.
  11. Oct 11, 2023 at 2:34 PM
    MattiasdelTaco
    Illinois
    2023 trd sport MT
    What fluid do you plan to try?
    Did you glean any type of insight from other past threads or enthusiast's or article writer's test results on what the best choice of fluid might be especially for winter/cold?
  12. Oct 11, 2023 at 4:02 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I suspect this subject is primarily affected by personal driving style, past experiences, and just generally subjective, but I suspect most of the “crunchy” shifts are caused by driver error.
    MOC221_ likes this.
  13. Oct 11, 2023 at 4:10 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    I had some crunch shifts early on before I put in the URD shifter. That helped a good bit. I think it was just a timing issue because the throw was so long. I have the S2000 stainless clutch line to install in the next couple weeks. At first I thought it was fine with the accumulator but I have started to notice it's inconsistency now that I have 2400 miles on the truck and I have gotten used to the shifting and the engine. I notice it most on higher RPM shifts during harder acceleration. The clutch it just really slow to engage, that is why I decided to delete the accumulator.
  14. Oct 11, 2023 at 4:17 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    When I got my ‘22 6MT a year ago, I hadn’t driven a manual in close to a decade. It immediately felt familiar to me, and after a day or three of sloppy shifts, I was right back at it. I did notice the slow release in cold weather last winter, but that only seemed to happen in extreme cold (<20°F), and even then started operating normally after cycling the clutch a few times.
    No issues with the clutch in my truck at all, just as it came from the factory.
    BC Hunter likes this.
  15. Oct 13, 2023 at 8:41 AM
    #35
    MOC221_
    Frank
    Well, in my experience the only slightly "crunchy" shift was 2-3, and only when the truck was new. Same thing with both 3rd gens I've owned. After break in, smooth as silk. Not driver error.
    TacoGranny likes this.
  16. Oct 13, 2023 at 8:49 AM
    #36
    MOC221_
    Frank
    Exactly my experience.
  17. Oct 13, 2023 at 9:48 AM
    #37
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Every manual and clutch system is different from the last one you drove. I got used to my 2022 Tacoma.
    .:notsure:
    MOC221_ likes this.
  18. Oct 13, 2023 at 1:21 PM
    #38
    MOC221_
    Frank
    That's great, glad you enjoy the factory clutch setup. I'm not being a dick with that statement BTW.
    I didn't enjoy it (along with the lazy throttle), so I did something about both.
    I've also owned/driven a pretty broad spectrum of M/T vehicles in my time, and the 3rd gen Taco was the only one that I couldn't get used to. Sure, I COULD be smooth with it, but it never became natural.
  19. Oct 13, 2023 at 1:33 PM
    #39
    Irons
    NW Michigan USA
    Believe it or not the smoothest gearbox I've ever owned was in my 2013 ferd focus hatchback. It was so nice I even tried to convince my wife to learn how to drive a manual in it before I sold it, but being a genius she refused.
    I have read on here some folks really like a certain ford manual transmission fluid, so I figure give that a run when I change my fluid in 22 thousand more miles.
  20. Oct 13, 2023 at 3:59 PM
    #40
    MOC221_
    Frank
    Lol, I believe it..
    Looking back, I think the smoothest I've ever owned was my 01 Accord. It just seemed to age very well. Buttery smooth from day 1.
    I'm just waiting on a gallon jug of Redline M/T 90 (75W90 GL-4) to get my gearbox fluid changed, then I'm all done with driveline fluid changes.
    Irons[QUOTED] likes this.
