2023 Tacoma announcement.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JJ Diablo, May 17, 2022.
  1. May 17, 2022 at 7:17 PM
    #41
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    How much will it cost to de-chrome the chrome package?
  2. May 17, 2022 at 8:30 PM
    #42
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    If there was a clutch start cancel switch with push start, the brake pedal wouldn’t be involved, you would just hold the start switch instead of holding the key on Start.
    The brake pedal is not involved when starting a Toyota with a manual transmission and smart key.
    Jeff
    DaddyMasterTech and TRD75 like this.
  3. May 17, 2022 at 8:38 PM
    #43
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Toyota is just trolling us now. Chrome package? They must have died laughing in the boardroom. Next they will announce the “incandescent lighting upgrade package” and “new thinner paint for weight savings”
    Junkhead and shakerhood like this.
  4. May 17, 2022 at 8:50 PM
    #44
    DaddyMasterTech
    DaddyMasterTech Well-Known Member
    Union County, NJ
    ‘22 TRD Sport DCSB MT (MGM)
    Push button in = turn key to start
    Release button = stop turning key
    This should work the same way with the clutch start cancel.
  5. May 17, 2022 at 8:53 PM
    #45
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    AC delete option on Texas Edition, and South East Toyota models.
    Stocklocker[QUOTED] likes this.
  6. May 17, 2022 at 9:01 PM
    #46
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Just saw the price for 2023 TRD off road, starting at $50,000.
  7. May 17, 2022 at 9:02 PM
    #47
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    16-19 was part of the premium package (sunroof, leather in 18+). I thought all v6 got dual climate after 20. Mine does.
  8. May 17, 2022 at 9:09 PM
    #48
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    according to my VSPEC, no DCC.
    https://guest.dealer.toyota.com/v-spec/3TYCZ5AN4NT079403/detail
    I think Toyota reduced the tech package to just RCTA and BSM. They moved DCC to the premium package, I think.
    In my quest for a new TT my must have was the tech package at minimum followed by advanced tech which comes with the cameras.
    I don’t want leather unless it comes with cooled seats.
    I was happy they made the sunroof a premium option. That’s not something I want for long term ownership. Wiring, glass, rubber, tracks, ooof no thanks.
  9. May 17, 2022 at 10:01 PM
    #49
    Jeff Lange
    Calgary, Canada
    For those wondering, expect 2023 production to start in September 2022.
    Jeff
  10. May 17, 2022 at 10:09 PM
    #50
    6mtTRD
    6mtTRD Well-Known Member
    2022 Celestial Silver Metallic TRD Off-Road
    Cilajet ceramic coating
    You aren’t getting the point of the clutch start cancel. It isn’t a convenience feature used to start the truck in neutral without the clutch depressed. The clutch start cancel is used to start the truck IN GEAR in precarious situations where any amount of rolling back would be dangerous, ie: off-roading and you stall out and risk rolling back into an obstacle or worse.
    In these situations, you’d engage clutch start cancel from the dash button. Keep your foot on the brake pedal. Put the truck into first gear/reverse. Then you’d crank the starter with the key. This essentially uses the starter motor to pull the truck away from the obstacle and starts the engine as well.
    Again, this is a tool used to prevent damage in certain situations. In day-to-day use, you wouldn’t use it and you’re correct that the brake isn’t used to start a manual Tacoma. But hopefully this helps explain this useful feature!
    DaddyMasterTech and venezian like this.
  11. May 17, 2022 at 10:14 PM
    #51
    Jeff Lange
    Calgary, Canada
    I completely understand what it is and what it is used for.
    I don't understand how pressing and holding a button is different than turning and holding a key. Because I don't understand the difference, I thought you were insinuating there was a brake pedal involvement in starting the vehicle. My mistake.
    So... what's the difference?
    Jeff
    Junkhead and 6mtTRD like this.
  12. May 17, 2022 at 10:17 PM
    #52
    Lava-road
    2019 trd-off road
    Do you think a driver Grab handle be in the package? Hood struts? LED head lights? I saw a special incandescent interior light package maybe offer in 2023?
    Question is led lighting that more expensive ? For factory produce Tacomas? Led lighting seems to be a selling point! Today more people want the led lighting.
    Flashlights, head lamps, lanterns all comes with leds today! Toyota needs meet those demands!
    Aloha
  13. May 17, 2022 at 10:21 PM
    #53
    6mtTRD
    Understood, I could see how my original post could’ve been worded better.
    I hear ya that the push button could technically be equivalent to turning the key. Maybe it’s a decision Toyota made after testing, or possibly a cost related decision as the manual is cheaper than the auto.
  14. May 17, 2022 at 10:46 PM
    #54
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
    You sure we don’t have this? My cab is very quiet…relative to the 2008 FJ I traded.
  15. May 17, 2022 at 10:50 PM
    #55
    Jeff Lange
    Calgary, Canada
    This isn't new for 2023, it's been the same since 2016.
    Jeff
    Grindstone and RTweet[QUOTED] like this.
  16. May 17, 2022 at 10:55 PM
    #56
    MGMDesertTaco
    FLAK-TAC[QUOTED] and shakerhood like this.
  17. May 18, 2022 at 5:21 AM
    #57
    Wire4Money
    Tim
    My 22 OR non premium has dual zone climate. As did all the other non premium TRDs they had.
    venezian[QUOTED] likes this.
  18. May 18, 2022 at 5:41 AM
    #58
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
  19. May 18, 2022 at 5:42 AM
    #59
    DaddyMasterTech
    Union County, NJ
    Maybe they did it to make it even harder to steal the already-harder-to-steal Tacomas (MT).
    But actually someone mentioned a totally dead battery would affect the possibility of popping the clutch on this if there was a push button rather than a key. I was going to say “push starting,” but didn’t want to confuse that with the button. So this is probably the reason for the key!
    6mtTRD[QUOTED] likes this.
  20. May 18, 2022 at 8:03 AM
    #60
    venezian
    Los Angeles
    2022 7545E
    I'll find out soon :)
