2023 Tacoma wheel bearing going out
Discussion in 'New Members' started by black2023, Jul 5, 2025.
  1. Jul 5, 2025 at 5:36 PM
    black2023
    black2023 [OP] New Member
    Debbie
    2023 Black Tacoma TRD
    None
    Tacoma TRD 2023 only 32 thousand miles a wheel bearing going out. I think they only ordered one. This was the last of April and the part is on back order was told it was safe to drive. Has anyone had this problem before on the 2023s Thanks
  2. Jul 5, 2025 at 5:55 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    HondaGM likes this.
  3. Jul 5, 2025 at 5:58 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW….had any damage to that wheel before..impact maybe?
    buckhuntin-tacoma likes this.
  4. Jul 5, 2025 at 6:00 PM
    black2023
    Debbie
    None
  5. Jul 5, 2025 at 6:02 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You been sending it…
    3JOH22A likes this.
  6. Jul 5, 2025 at 6:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There have been plenty of failures here, but for the most part they are a decently long lasting part.
    Is it a rear or a front bearing going bad?
    Citron likes this.
  7. Jul 5, 2025 at 6:06 PM
    black2023
    Debbie
    None
    It is the rear.
    Citron likes this.
  8. Jul 5, 2025 at 6:15 PM
    BLtheP
    Plano, TX
    The rears seem to fail more commonly and randomly at low miles, so I’m not surprised. Still, not a failure prone part and failures are quite rare overall.
    And I wouldn’t worry about the fact that they are only changing one. There is only a reason to change one. If you were at 150k then doing both would make sense but even then, doing both saves no time or effort, so there’s still only really a reason to do one at a time. It’ll be good as new when they’re done.
  9. Jul 10, 2025 at 6:11 AM
    whiteplainjaneride
    whiteplainjaneride New Member
    looking for white
    That doesn’t sound good especially at low mileage. Good luck
  10. Jul 10, 2025 at 6:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I had a front wheel bearing go in 2022 at 26,000 miles. Earlier that year I sent it hard enough to get my picture in the TW calendar.
