2023 tacoma with pinhole leak in head
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 17tacomalb, Nov 14, 2023.
  1. Nov 14, 2023 at 9:32 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    It's 2023. 4K video cameras, >20 Mpixel cell phones, and <$200 flex-neck inspection cameras with multiple lenses and lights on the end are widely available.
    There is no excuse for a technician, dealer, service shop, etc. NOT to show visual evidence of claimed diagnoses wherever possible.
    Chew and HondaGM like this.
  2. Nov 14, 2023 at 9:38 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Want gives way to need when you are slow. Holidays become a slow time around the shop because people focus on other things.
    HondaGM likes this.
  3. Nov 14, 2023 at 9:48 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    My 2022 sr5 had a bad cylinder head. Was leaking oil out of it. 4k miles it had. I Hope a quality tech is going to work on your truck. It’s an engine out job with a lot of wire harness that need to be disconnected and I’m ocd about all the wiring being put back in place without shit being broken or just dangling in the engine bay.
    HondaGM likes this.
  4. Nov 14, 2023 at 9:57 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    2017 with only 5k?
    I'd ask to see it before I agree to anything
    HondaGM likes this.
  5. Nov 14, 2023 at 10:02 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    2023
    HondaGM likes this.
  6. Nov 14, 2023 at 10:35 AM
    17tacomalb
    17tacomalb [OP] Active Member
    2017 taco lb
    2023 not 2017
    HondaGM likes this.
  7. Nov 14, 2023 at 10:39 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Thats the Truth...and The Post of The Day right there
    SR-71A and Tacoma Mike[QUOTED] like this.
  8. Nov 14, 2023 at 10:41 AM
    17tacomalb
    2017 taco lb
    What's involved in replacing the head?
    HondaGM likes this.
  9. Nov 14, 2023 at 10:42 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Taking apart the top and front of the motor.
    HondaGM likes this.
  10. Nov 14, 2023 at 10:44 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I might have zoomed past it,but is this a 4cyl or V6
  11. Nov 14, 2023 at 10:45 AM
    17tacomalb
    2017 taco lb
    V6
    HondaGM likes this.
  12. Nov 14, 2023 at 10:46 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I believe replacing the head calls to pull the motor. Unfortunately (fortunately for you) most dealer techs are well versed in pulling motors as the great timing cover leak of 2018 forced many a dealers to learn how to efficiently pull the engine without much issue. I wouldn't be concerned with a dealer pulling my engine to fix an issue.
    HondaGM likes this.
  13. Nov 14, 2023 at 10:47 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Are they pulling the motor out?...I've heard some techs do
  14. Nov 14, 2023 at 10:48 AM
    17tacomalb
    2017 taco lb
    They have to pull the whole motor out??
    pastoreater and HondaGM like this.
  15. Nov 14, 2023 at 10:51 AM
    #35
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Make sure you go around the fenders ,hood and grill with the service advisor...make him note about any dents or scratches
    Chew likes this.
  16. Nov 14, 2023 at 10:52 AM
    #36
    AvockAdoo
    AvockAdoo Well-Known Member
    Sam
    Denver, CO
    '21 DCLB TRDOR
    People on this forum get so up in arms about things - the dealer will do the work just fine. They have trained techs, and if the dealer screws it up, its on them 100%. Stop worrying about it - its warranty work, they'll fix it and you'll be on your way. Its literally why warranty exists.
  17. Nov 14, 2023 at 10:53 AM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Head removal requires timing cover removal. Timing cover has some interlocking seams with the oil pan, so it's faster (in a shop) and actually less error prone to pull the engine than to work in-situ.
    You might have preemptively forestalled a future timing cover leak, so there's that...
    Tacoma Mike and HondaGM like this.
  18. Nov 14, 2023 at 11:09 AM
    #38
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Only reasonable comment, on this thread so far.
    Tacoma Mike likes this.
  19. Nov 14, 2023 at 11:14 AM
    #39
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Add doctors to this note as well......:rolleyes:
  20. Nov 14, 2023 at 11:28 AM
    #40
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    interesting. here's an example of Toyota doing what it should. Saw a problem, diagnosed and wants to fix it for free. Like they should. What's the problem?
