2023 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cincy Tacoma, Jul 26, 2022.
  1. Jul 28, 2022 at 2:39 PM
    #41
    DividedSky
    DividedSky Well-Known Member
    Jeff
    2018 TUNDRA
    Mid-Travel ADS Shocks, MCM UCA, Full Armor
    Regarding a 4cl Turbo vs a 6cyl, I have a buddy I wheel with and one issue he has with his turbo-4 is that when we go up SUPER steep grades he has to floor it to get the turbo to kick in or he can't make it up. Turbos don't work well for slower rock crawling applications.
  2. Jul 28, 2022 at 2:42 PM
    #42
    turtleguy_83
    turtleguy_83 Well-Known Member
    Fixed and ended up being extremely reliable.
    Turbo issues that require you to separate the cab off to replace it? What a mess and failure of design. Turbos have a limited lifespan too, meanwhile the old Tundra regularly went 500k miles. Some even went 1 million miles.
  3. Jul 28, 2022 at 2:44 PM
    #43
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That engine isn't really new. It's been around for a few years in the Lexus LS500. But the turbo issue is indeed a wastegate problem.....part supplier issue, not a design issue. It's really only effected very early ones. That's of little consequence if it's yours though.
    tstack22 and shakerhood like this.
  4. Jul 28, 2022 at 2:49 PM
    #44
    Plain Jane Taco
    USA
    And the 2.4 T will be a single turbo. It's basically the existing 2.5 A25 Dynamic Force engine that's been out since '17. It is reinforced and has thicker cylinder walls....hence the reduction in displacement. There will be both longitudinal and transverse versions and it will replace nearly all current 2GR applications in the near future
    tstack22 likes this.
  5. Jul 28, 2022 at 3:00 PM
    #45
    republic_of_texas
    republic_of_texas Well-Known Member
    Josh
    Austin TX
    Black 2016 Tacoma TRD Sport 4x4
    3/10/22 •icon stand 9 suspension with billet UCA’s, running medium duty Dakar leafs •method NV on 32” BFKO2 •Prinsu RR with Cali raised dual function LB •DIY BHLM •BANTAMMAX8 and SPOD •arb single comp •KC FLEX ditchlights •Wescot designs rock sliders •Relentless Fab HC rear bumper with spod •BA slimline front bumper with 20” lb, 11K lbs Superwinch •full RCI skids •MobTown fab BR, with rotopax and traction board mounts •softopper •OVTUNE dump tubes •AFE COI •URD spec u y pipe and full exhaust •KDMAX pro Tune •Smitty bolt RTT, and canopy •TBC
    From what I've been reading the next gen will be a turbo 4cylinder with a presumed 317hp
  6. Jul 28, 2022 at 3:15 PM
    #46
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’ve driven engines with turbos in excess of 300k miles and had NA engines blow up with less than 100k miles. There is nothing inherently less reliable about a turbo or a turbocharged engine.
    devinzz1 likes this.
  7. Jul 28, 2022 at 3:21 PM
    #47
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    people gona act like some of the most reliable vehicles ever made were turbocharged diesels. and even if a turbo did go bad they can be rebuilt for like $500. worse case have to be replaced at $1500.
  8. Jul 28, 2022 at 3:27 PM
    #48
    turtleguy_83
    Turbochargers do not have an infinite lifespan. And all else equal, the same engine with a turbocharger has more pressure and higher temperatures than the version without one
  9. Jul 28, 2022 at 3:40 PM
    #49
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    I am almost certain that replacing a failed turbo in a longitudinal mounted 2.4L 4 cylinder in the next gen Tacoma will be tremendously easier than accessing the turbos in the new Tundra.
  10. Jul 28, 2022 at 3:47 PM
    #50
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    No recall from what I understand and those that have the wastegate failure are under warranty. Typical issues with first year of a new gen vehicle.
  11. Jul 28, 2022 at 3:53 PM
    #51
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    It is always a massive issue when it happens to a friend or relative :rofl:
  12. Jul 28, 2022 at 3:55 PM
    #52
    Plain Jane Taco
    USA
    While this is true.....manufacturers don't simply slap on turbos, close their eyes and hope. If the turbo engine is based on an existing NA mill....lots of strengthening and reinforcement go into it. That's why you almost always see the turbo version of an NA engine have less displacement. That strengthening almost always reduces the cylinder bore.
  13. Jul 28, 2022 at 4:45 PM
    #53
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I don’t recall anyone saying turbochargers have an infinite lifespan. I’ve had turbo engines with over 200k miles on the original turbo no problem. I’ve had NA engines fail at lower mileage. Obviously a turbocharged engine will run at higher pressures since that is the reason to use a turbocharger in the first place. As someone else mentioned it’s not as if the designers don’t know this and build the engines accordingly to handle that.
    stevesnj likes this.
  14. Jul 29, 2022 at 7:11 AM
    #54
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    4 cyl. turbo is for 2024 and it's putput is close to the V6.
