2023 trd or check engine light
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Steves55, Nov 4, 2023.
  1. Nov 5, 2023 at 8:42 AM
    Bishop84
    Bishop84 Well-Known Member
    As a dealer tech, guys if you have warranty, don't clear the codes. Don't disconnect the battery. Then book it in for CEL.
    If its not a permanent code you're just wasting everyone's time.
    Let the light stay on and book it in. Dont clear it.
    Sometimes connecting cheap scanners will blow the code out by accident. The Innova is as cheap as I'd go.
    Dm93 and Cetacean Sensation like this.
  2. Nov 5, 2023 at 9:30 AM
    Steves55
    Steves55 [OP] Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    I didn't clear the codes, couldn't get my reader to link to truck. I thought about disconnecting battery but wanted the code first. So that was a no. Some symptoms found online with the code- starting issues- won't start- rough idle (I've had that since I brought it home- dealer said normal, crappy gas)- poor gas mileage (I'm lucky to average 14 since new).
    I found a video that shows where the 4 sensors are located, the one throwing the code is under the intake cover between intake runners. I checked all the plugs on the bank A sensors- they look brand new- all 4 do, no damage observed. No little footprints in the dust on intake. I checked all the other plugs around the top of engine- no damage anywhere. I suck at modern electronics (give me a carbed drag car anyway) so I will let the dealer try & screw me.
  3. Nov 5, 2023 at 9:47 AM
    CVCV
    CVCV 3rd Toyota Truck
    Tacoma 2022 3.5L DCSB TRD OR 4x4
    If it ran poor from day one, this may be a nice fix. Keep us posted.
  4. Nov 5, 2023 at 9:52 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Well you have a code and a warranty. I would take it in for the fix. It would likely remedy your rough idle too
  5. Nov 6, 2023 at 8:15 AM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    I did recently purchase a locking gas cap. At end of 2nd tank fill the check engine light went on. I put the ild one back on but so far no change.
    Will take it to the dealership tomorrow.
  6. Nov 6, 2023 at 8:28 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Stop toying around in there, you are at under 3k miles, you're still WELL within your warranty window, bring it to Toyota, tell them "Here's the code, fix". Walk away and let them fix. You toying around in there is not covered under warranty, if you mess something up more, you're going to be on the hook. That's no bueno.
    PS rough idle can be normal, mine comes and goes, depends on lord knows what. Weather, gas, if I farted too loud getting into it.
    Canadian Caber likes this.
  7. Nov 6, 2023 at 8:34 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  8. Nov 6, 2023 at 8:52 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Warranty, the end
    ppat4 likes this.
  9. Nov 6, 2023 at 9:24 AM
    Sandthemall
    Sandamal
    2023 TRD OR MT
  10. Nov 6, 2023 at 9:39 AM
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    Who's toying around? All I did was get the code & do a visual.
  11. Nov 7, 2023 at 5:40 PM
    Steves55
    Palm Desert, Ca
    2023 TRD Off Road
    Took truck in. Diagnosis was a bad sensor plug. They replace the sensor, plug & pins. Warranty covered the job.
  12. Nov 7, 2023 at 8:44 PM
    Sandthemall
    Sandamal
    2023 TRD OR MT
    FYI: took my truck in today. Issue was the evaporative system…so it was the bad locking gas cap. They simply cleared the code. The BSM (blind spot monitor) not working was caused by the new Head Unit. Need to sort that out. They did not charge me this time but told me that it could have been a $400 diagnostic charge because both issues were result of pilot error.
