2023 TRD PRO Rough Idle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MudSpike01, Mar 7, 2023.
  1. Aug 16, 2023 at 9:37 AM
    #41
    tacomadome
    tacomadome Well-Known Member
    It has a self-cleaning cycle where it will idle rough, as mentioned earlier. Leave well enough alone
    TX BAJA1 likes this.
  2. Aug 16, 2023 at 11:18 AM
    #42
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    I know when it’s in clean cycle but as I mentioned in an earlier post mine does it all the time when the ac compressor cycles on sitting at a red light in drive.
  3. Aug 16, 2023 at 11:29 AM
    #43
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Best way I've found, hands down, to fix my similar rough idle was a 19 hour road trip. Let that engine get up to operating temp and stay there for a long time. Got to Laramie, WY from West Michigan and that idle was smooth as could be.
  4. Aug 16, 2023 at 12:39 PM
    #44
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Under warranty take it to Toyota and have them fix it .
  5. Aug 16, 2023 at 1:48 PM
    #45
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I certainly know to take it Toyota I was just curious what MudSpike found out when he took his in. Seems like everyone on here instead of helping has some SA answer.
  6. Oct 7, 2023 at 1:55 PM
    #46
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    What makes you say it’s sensitive? What does it do when you don’t use top tier gas?
  7. Oct 7, 2023 at 3:35 PM
    #47
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Idles a little rougher and has the occasional ping/stumble.
    45Frank and Gfenza89[QUOTED] like this.
  8. Oct 7, 2023 at 3:37 PM
    #48
    Gfenza89
    I think dealer put crappy gas in my new truck. Deff idles much rougher then my last tacoma. I’m at half take I’ll run it empty then fill up with Exxon top tier. If that doesn’t work guess I’ll live with it lol
  9. Oct 7, 2023 at 4:32 PM
    #49
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    My Tacoma started at around 7,000 miles with a rough idle at red lights or anytime it idles in drive mainly with the ac compressor engaged. I started using top tier premium fuel and that seems to help. I went by and talked with one of the mechanics at the local dealer he suggested first option would be to reset the ECM but since the fuel helped with smoothing the idle I haven’t done anything cause I don’t want to deal with the relearning process. Let me know how yours turns out with a fresh tank of top tier fuel.
    Gfenza89 likes this.
  10. Oct 7, 2023 at 5:08 PM
    #50
    Gfenza89
    Can’t wait to try it. Some dealers have their own gas stations on site prob the absolute cheapest fuel they can buy. I’ll keep y’all posted. I mean it’s not the end of the world everyone of these 3rd gens I’ve owned were different in their own way good or bad
  11. Oct 7, 2023 at 10:40 PM
    #51
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Yeah, I got mine in July and noticed this. It’s a lot rougher idler than both my second gens. It’s enough to vibrate a bottle in the cup holder. Neutral it's fine. I’m going to mention it at my first complimentary service.
  12. Oct 8, 2023 at 4:42 AM
    #52
    Gfenza89
    Have you tried different gas?
  13. Oct 8, 2023 at 10:54 AM
    #53
    jassco
    NH
    2023 TRD Offroad
    We have have an rx350 with very similar engine. Father-in-law has 2008 4Runners we use sometimes which run smoother. I always use different gas stations anyway and tried the Ethenol free 93 just for kicks. I noticed on the scanguage it gets below 600 sometimes. Raising it to 650 smoothes it out, so I may have tuner fix if dealer can’t remedy. 2200 miles btw and same since new.
    Also, my father (2017 Tacoma) and wife both commented on it, so it’s certainly not what others are describing as normal. 2017 Tacoma is smooth as butter.
  14. Oct 8, 2023 at 8:22 PM
    #54
    bubbaearle
    bubbaearle Well-Known Member
    N Central Arkansas
    2012 DCSB TSS , 2003 SR 2.4l 5spd, 2023 DCSB SR V6 4x4
    I noticed mine was rough while sitting in the parking lot while waiting on my wife in the grocery store. 100 degree day idling with AC on. It felt pretty rough and I could see tach jump a bit on the rough spots. I turned the AC off and it smoothed out considerably. Settled @ 500 RPM or so. Kicked AC back on and it started the roughness as the AC compressor cycled on & off.
    I noticed it again today, 70 degree day, kicked off AC and all smooth again. My truck seems to default to running the AC when started.
  15. Oct 9, 2023 at 5:05 PM
    #55
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    I definitely think there is a problem with the ac compressors they done away with the clutch on them and I think that may be the issue.
  16. Oct 9, 2023 at 5:08 PM
    #56
    MGMDesertTaco
    bump,
    Several Tacoma's came with loose spark plugs from the factory including mine. After changing the plugs out, fresh air filter and some Lucas fuel system treatment the truck runs and drives a lot smoother. Something to consider if you haven't.
  17. Oct 9, 2023 at 5:48 PM
    #57
    bubbaearle
    N Central Arkansas
    How does it work without a clutch?
  18. Oct 9, 2023 at 5:51 PM
    #58
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Thank you MGM!! That could very well be the problem with mine.
    MGMDesertTaco likes this.
  19. Oct 9, 2023 at 5:54 PM
    #59
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Bubba, I’m not sure how it works that’s what the service manager told me at the dealership.
  20. Oct 9, 2023 at 6:08 PM
    #60
    bubbaearle
    N Central Arkansas
    I may check my plugs, but it pretty much only idles rough with AC on. You'd figure it'd be rough all the time otherwise.
    I'll check it more closely this weekend.
    MGM.... was it all plugs loose or random plugs??
    How loose were they??
    Did you remove & inspect or just torque them down?
