2023 V6 Oil Filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Buildup21, May 1, 2023.
  1. May 3, 2023 at 1:10 AM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Fram is better. Their newest "Synthetic Endurance" line is specifically for Walmart, $12 for the equivalent of a TRD oil filter, 99% @ 20 micron rating and good for 25k miles.
  2. May 3, 2023 at 3:59 AM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Here we go
    atc250r, wayupnort, Blockhead and 7 others like this.
  3. May 3, 2023 at 4:21 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Well, its more expensive than the stock toyota filter, so that must make it better.
    Barsoom, TacoSR523 and HondaGM like this.
  4. May 3, 2023 at 5:48 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Would you really leave an oil filter on for 25K miles?
    leueddie, Rainoffire, atc250r and 6 others like this.
  5. May 3, 2023 at 5:55 AM
    Friend of Crows
    2022 Tacoma SR
  6. May 3, 2023 at 8:59 AM
    Buildup21
    Buildup21 [OP] Member
    They have silver holographic sticker, I’m sure they’re legit. Walmart is to big to sell fake products, at least in my opinion
    HondaGM and shakerhood like this.
  7. May 3, 2023 at 9:00 AM
    Buildup21
    Do I really need a new crush washer every time?
    HondaGM likes this.
  8. May 3, 2023 at 9:05 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    No Wally World for me…..
    VB25 and D.A.S. Taco like this.
  9. May 3, 2023 at 10:31 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    if you are talking about the washer on the drain plug is a good idea but you could get by with the old one.
    the old one sticks to the pan and you have to snake a screwdriver up there and pop it off.
  10. May 3, 2023 at 10:37 AM
    zoo truck
    None
    Even the fake toyota filters all come with that sticker, its just not as pronounced.
    TheDanimal likes this.
  11. May 3, 2023 at 10:41 AM
    tacos4u
    tacos4u Active Member
    I never change the crush washer only had one drip in my 30 years of changing my own oil. On that one I tightened it up a little more and it stopped then I replaced the washer the next oil change. Changed my Tacoma 3 times with the old washer so far. No issues
    wayupnort and zoo truck like this.
  12. May 3, 2023 at 10:44 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
  13. May 3, 2023 at 12:59 PM
    Buck Henry
    As long as you are not buying your Toyota filters from this guy, you are probably OK.
  14. May 4, 2023 at 10:36 AM
    islesrule123
    islesrule123 Well-Known Member
    New York
    2016 inferno Tacoma TRD off road
    Trd pro suspension trd pro grill
    Compared the old and new filter from the dealer and the orange one seems like what Subaru had to do which is offer another supplier until the main on catches up again. It says Toyota on it but not the part number. Seems the same to me
  15. May 4, 2023 at 11:11 AM
    #35
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    2023 tacoma should be under warranty up to 36000 miles right? unless you have over 36000 m on it already, what is the reason/s not going to dealer for oil change?
  16. May 4, 2023 at 12:42 PM
    #36
    zoo truck
    None
    Nothing if you have a dealer like we have here. All the techs are middle aged ASE certified. I only stopped when toyotacare was done. Cost for an oil change now is $160. I can do the job just as well for a lot less. Only pita is, having to take a 5 mile ride to the recycling ctr. to dispose of the spent oil.
    TacoSR523[QUOTED] likes this.
  17. May 4, 2023 at 12:45 PM
    #37
    TacoSR523
    VA
    All right, Thank you!
  18. May 4, 2023 at 12:52 PM
    #38
    zoo truck
    None
    Just beware not all toyota dealers are like we have. You'll get the trainees usually doing the bottom end work to start...hopefully they do a good job:fingerscrossed:
    Barsoom likes this.
  19. May 4, 2023 at 1:02 PM
    #39
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    I replaced the shiity plastic oil filter housing with aluminum ones on both my Taco and wife's RAV4 (part#15620-31060). Just needed to move the aluminum plug to the new filter.
    I get my filter by the case on Amazon, comes out to $45.37 for 10 filters, Ships from BAM wholesale parts. Real deal filters.
    @OP do not forget to drain the oil out of the housing first.
    I hate the OEM drain nipple that comes with OEM filter, so I got a screw in drain adapter with a tube. No mess.
    As far as the dealer... Mine lost a bolt for the filter access door in the TRD skid plate. Sent me out without saying a word. I am anal, so I check under my truck after every oil change. Went back, they admitted that screw was stripped when tech took the door off. He knew what happened, did not do anything about it.
    I asked dealer to order me a replacement screw. They ordered me the full skid plate install kit.
    I am not letting them change any more of my oil. Rotate the tires under Toyota care, yes, but no oil changes.
    atc250r likes this.
  20. May 4, 2023 at 1:04 PM
    #40
    Barsoom
    NW GA OTP
    Any store selling motor oil takes back used oil. Walmarts with auto centers, Advance Auto, Auto Zone all have oil drain barrels where you can dump your used oil, ATF, Diff oil.
    wayupnort and shakerhood like this.
