2024 Early Technical Information
Discussion in '4th Gen. Tacomas (2024+)' started by Jeff Lange, Nov 29, 2023.
  1. Dec 4, 2023 at 7:40 PM
    tomatogrower
    tomatogrower Well-Known Member
    2013 tacoma crew cab 4x4
    none
    Thanks for summarizing the more relevant info for the upcoming 2024 taco... i found what i was searching for about the axle ratios and more interestingly about the spin-on oil filter (good news!)... hopefully the filter access is like on a second gen tacoma...
  2. Dec 4, 2023 at 8:07 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The picture I remember seeing had it on the bottom and you had to pull the skid plate, however it was on the front side of the engine.
    3JOH22A likes this.
  3. Dec 4, 2023 at 8:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Filter is near the bottom of the engine pointing forward. There's a spout to direct the oil away from the electric steering rack.
    None of the three types of front skid plates shown so far (aluminum, steel, plastic) have an access door for it.
    shakerhood likes this.
  4. Dec 6, 2023 at 2:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    @Jeff Lange do you know if the RC60F on this model will be using a direct or cable shifter? Sheldon Brown mentioned something about "it's a bit further to where the cable hooks up"....not sure if that's just a misnomer or if the new model is using a cable shift.
    I figured it would be an RC60J or similar if they were going cable route.
  5. Dec 6, 2023 at 2:20 PM
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It is a direct shifter, though it does sit further back on the transmission. It's not a cable.
    Jeff
    GBR, shakerhood and BLtheP like this.
  6. Dec 8, 2023 at 3:30 PM
    Jeff Lange
    Calgary, Canada
    Added a few updates to the first post and corrected some info as well.
    Jeff
  7. Dec 8, 2023 at 3:42 PM
    BLtheP
    Plano, TX
    Fantastic on the RC60F! Any ideas if the shifter is easily swapped?
  8. Dec 8, 2023 at 3:47 PM
    Jeff Lange
    Calgary, Canada
    The shifter from an RC62F would be a direct fit onto the Tacoma RC60F.
    Jeff
    BLtheP[QUOTED] likes this.
  9. Dec 8, 2023 at 4:02 PM
    BLtheP
    Plano, TX
    Fantastic.
  10. Dec 9, 2023 at 11:54 AM
    BLtheP
    Plano, TX
    Curious about this now….do you think it’s going to be an issue with the hole in the floor? Or am I misunderstanding the location of the shifter?
  11. Dec 9, 2023 at 12:03 PM
    Jeff Lange
    Calgary, Canada
    You’re misunderstanding. You will remove the housing that moves where the shifter sits and install the 2016-2023 shifter, so it will be in the exact spot it is on the earlier truck.
    Jeff
  12. Dec 9, 2023 at 12:04 PM
    BLtheP
    Plano, TX
    Makes sense…when I saw direct shifter, I was thinking that means no extension and that maybe there was a new rear case half relocating the shifter further back. Good to hear.
  13. Dec 10, 2023 at 7:51 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    rip, despite having the correct bolt pattern, all my 3rd gen aftermarket wheels don't have offset that's anywhere close to these wheels on 4th gen, probably gonna need to shop for some +20mm offset wheels for 4th gen
  14. Dec 14, 2023 at 9:33 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Damn my -10 offset Volks will look terrible even if they do clear
  15. Dec 15, 2023 at 7:06 AM
    #35
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^You'll be 6" wider with the Volks! Assuming the 14mm lug nuts fit in the wheels
    TacoBuffet[QUOTED] likes this.
  16. Dec 15, 2023 at 7:26 AM
    #36
    TacoBuffet
    AL
    so sad cause I love my current look
    CROM123, shakerhood, malatx and 2 others like this.
  17. Dec 15, 2023 at 7:39 AM
    #37
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Nice truck, only thing missing is the trd bro grill.
  18. Dec 15, 2023 at 7:43 AM
    #38
    TacoBuffet
    AL
    never ran one never will
    Fast1 and Johnny919[QUOTED] like this.
  19. Dec 15, 2023 at 7:55 AM
    #39
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    Paid off. Keep it. :D
  20. Dec 15, 2023 at 8:04 AM
    #40
    TacoBuffet
    AL
    I’m more and more leaning that way these days.
    shakerhood and BirdBrain[QUOTED] like this.
