2024 Early Technical Information
Discussion in '4th Gen. Tacomas (2024+)' started by Jeff Lange, Nov 29, 2023.
  1. Jan 3, 2024 at 2:29 PM
    #121
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's exactly 4" taller (70.6" vs. 74.6"). People want jacked-up seats and extra headroom with a moonroof, and this is the result.
  2. Jan 3, 2024 at 2:30 PM
    #122
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    wonder if its just the cab overall or clearance from ground like is it similar to a lifted 3rd gen
  3. Jan 3, 2024 at 2:32 PM
    #123
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Cab from floor to roof is taller as shown in a couple of Youtube videos. Part of the 4" is a 0.5" increase from the bigger stock 32" tire (vs. 31" on 3rd gen).
    TacoBuffet[QUOTED] likes this.
  4. Jan 3, 2024 at 2:36 PM
    #124
    TacoBuffet
    AL
    Figured that much just couldn’t tell from all the comparison videos even the one with Chloe’s lifted 3rd gen next to it
    shakerhood likes this.
  5. Jan 12, 2024 at 4:57 PM
    #125
    Jeff Lange
    Jeff Lange [OP] Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    First post updated with VIN decoding information.
    Jeff
  6. Jan 18, 2024 at 3:27 PM
    #126
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Does the black boot shifter ring carry over to the 3rd gen since the shift knob is the same?
  7. Jan 20, 2024 at 6:29 AM
    #127
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Wait, so the big diff is only the Manual Trans? Or am I reading that wrong?
  8. Jan 20, 2024 at 7:29 AM
    #128
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    NVMD, I see this is all non-hybrid stuff..
  9. Feb 4, 2024 at 12:10 PM
    #129
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    @Jeff Lange Does the needle bearing carry over from the 3rd gen? Thanks!
  10. Feb 7, 2024 at 2:27 PM
    #130
    Jeff Lange
    Calgary, Canada
    For models with ADD, yes. Full-time 4WD models, i.e., Limited, do not have ADD or the needle bearing.
    Jeff
  11. Feb 17, 2024 at 3:58 PM
    #131
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    @Jeff Lange, do you know if all trims use vacuum boosters now? Watching a video of a TRD Off-Road and it’s got a vacuum booster. Haven’t seen much discussion about any of that yet.
  12. Feb 20, 2024 at 1:12 AM
    #132
    Jeff Lange
    Calgary, Canada
    Yes, they all do, at least for non-Hybrid versions.
    Jeff
    shakerhood and BLtheP[QUOTED] like this.
  13. Feb 20, 2024 at 4:28 AM
    #133
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    @Jeff Lange. Are the Predator side steps available to order in Canada?
  14. Mar 27, 2024 at 12:49 PM
    #134
    apex652
    apex652 Member
    Bob
    Colorado
    2024 Bronze Oxide Tacoma TRD Or Long Bed
    Does any know the oil filter part number for a 2024?
  15. Mar 28, 2024 at 2:53 PM
    #135
    Jeff Lange
    Calgary, Canada
    90915-10009 or 90915-YZZN1
    Jeff
  16. Apr 11, 2024 at 4:28 PM
    #136
    6MTPro
    HI -> CA
    @Jeff Lange any insight on this? Thank you!
  17. May 3, 2024 at 6:49 PM
    #137
    fitsofrage88
    fitsofrage88 Well-Known Member
    ATX
    both for synthetic oil? the 10009 has red/orange seal and the YZZN1 has black seal per visual when inspecting both filters.
  18. May 4, 2024 at 10:51 AM
    #138
    Jeff Lange
    Calgary, Canada
    Yes.
    Jeff
  19. May 4, 2024 at 7:06 PM
    #139
    linuxpickup
    linuxpickup Well-Known Member
    2024 OR MT
    I've heard YZZF2 is the old part # for YZZN1 as well, so those two are interchangeable - correct me if I'm wrong? Be prepared to be startled at how small the oil filter is for a vehicle this size.
  20. May 4, 2024 at 7:46 PM
    #140
    Jeff Lange
    Calgary, Canada
    90915-10003, 90915-10009, and 90915-YZZF2 are all serviced by 90915-YZZN1 in North America, yes; and yes, it's pretty small. Used for Toyotas smallest of engines in the past.
    Jeff
