2024+ Front Shock Top Hat Failure TALLY...
Discussion in '4th Gen. Tacomas (2024+)' started by FreshMexicanTaco, Aug 12, 2024.
Has your Top Hat failed?
  1. No
    139 vote(s)
    96.5%
  2. Yes, TRD OR
    4 vote(s)
    2.8%
  3. Yes, TRD Sport
    0 vote(s)
    0.0%
  4. Yes, SR/SR5/Pre-runner
    0 vote(s)
    0.0%
  5. Yes, Limited
    0 vote(s)
    0.0%
  6. Yes, PRO / TRailhunter
    1 vote(s)
    0.7%
  1. Aug 23, 2024 at 10:42 AM
    #81
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    Let me preface that I know that i don’t know much if anything at all about motor vehicle suspension design. I’ve put 170,000 miles on a 2011 Double Cab LB that I purchased new. I later added that generations TRD Pro coil overs and rear shocks at 65,000 miles. Both the stock sport and TRD Pro front have what “feels” like more than adequate bottom out support accomplished by a simple external hunk of rubber on each side.
    My 2024 Double Cab LB TRD Off Road bottoms out with a noticeable “clunk” over a mild neighborhood speed hump at 15 mph.
    I don’t recommend off-roading one of these trucks until there’s an internal (Toyota) or external (aftermarket) solution.
    I am confident in the power of large markets. The Tacoma world is a large market with an abundance of innovative vendors looking to satisfy market needs. I expect several solutions forthcoming.
    Superdave1.0 likes this.
  2. Aug 24, 2024 at 4:56 AM
    #82
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
  3. Aug 24, 2024 at 6:03 AM
    #83
    Gampy164
    Gampy164 Member
    2025 Tacoma Trailhunter
    I was able to squeeze a 3/8” drive torque wrench in there with a medium deep socket.
  4. Aug 24, 2024 at 7:10 AM
    #84
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    This guy breaks down a lot of good points and shows the difference in frame and bumpstop set ups on different Toyota trucks. I can't believe Toyota put frame mounted bumpstops on the new GX and the new Land Cruiser, yet Tacoma gets wimpy internal bumps. Why would Toyota design the higher end models with external bumps and the taco without???
    https://youtu.be/xh3-09v8MYo?si=kxjt6t1i6bryS0zw
    JoeManji likes this.
  5. Aug 24, 2024 at 9:20 AM
    #85
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Here's my 2 cents. I'm assuming Toyota deleted the front bumps for better front axle articulation and clearance (I'm sure it was brought up before), similar to off-road rock crawlers (no bump stops mounted on those buggies). However, it's not the shock with the built-in bump stop that is creating the issue. It's the material, used, and design of the top shock mount caps. If the cap didn't break, there be no thread on the subject matter. It's an easy fix and I guess cheapo Toyo is waiting for the masses to complain and part break.
  6. Aug 24, 2024 at 9:25 AM
    #86
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    OP, you should probably make it clear that this is for 4th gens. I suspect there are other gens just clicking in, not paying too much attention, and voting. I almost did because I love polls.
  7. Aug 25, 2024 at 1:36 AM
    #87
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    Good point.
  8. Aug 25, 2024 at 5:04 AM
    #88
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Have the failures only happen to trucks with out the sway bar disconnect?
    Disconnect the front sway bar creating the opportunity for more articulation and a greater chance of damaging the top hat.
  9. Aug 25, 2024 at 5:06 AM
    #89
    FreshMexicanTaco
    AJ
    San Diego
    I don't think so. ours doesn't have the disconnect
    batacoma[QUOTED] likes this.
  10. Aug 25, 2024 at 5:14 AM
    #90
    TOMRR
    Tom
    Mass
    Ok. the top hat reinforcement plate, but is this considered a permanent fix or just a band aid??
  11. Aug 25, 2024 at 5:29 AM
    #91
    batacoma
    batacoma Truck Wars
    I would doubt if Toyota is using a different tophat cap design on those trucks, nobody has probably activated the disconnect and articulated the suspension as much as the tophats have failed.
    I'm wondering if other manufactures have more surface area on the coil bucket so if the cap broke it wouldn't push the top hat thru the coil bucket?
  12. Aug 25, 2024 at 5:43 AM
    #92
    FreshMexicanTaco
    AJ
    San Diego
    Our plate is going to be very hard to break through, I can't speak for Icon's plate but they are both more of a problem prevention than a band aid. is thicker than Icon's and ours is supported by the entire coilover bucket not just the nuts on the studs. In order to break through ours you're REALLY going to have to try.
    2024OffRoad and TOMRR[QUOTED] like this.
  13. Aug 25, 2024 at 6:11 AM
    #93
    TOMRR
    Tom
    Mass
    Thanks for the reply. Is your top hat a replacement for the original or a reinforcement. I have a stock 2024 OFF ROAD442422628_7561781393887569_5126198926060194377_n.jpg
  14. Aug 25, 2024 at 10:59 AM
    #94
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    It’s a permanent fix for me.
    TOMRR[QUOTED] likes this.
  15. Aug 25, 2024 at 12:40 PM
    #95
    FreshMexicanTaco
    AJ
    San Diego
    reinforcement
  16. Aug 25, 2024 at 1:36 PM
    #96
    TOMRR
    Tom
    Mass
    So the stock cover can still break. I think for now I will wait if Toyota will fix the issue.
    Goin2drt likes this.
  17. Aug 25, 2024 at 1:49 PM
    #97
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    The front struts on these new gens are a PITA to remove, just an FYI.
    I’d be disappointed to remove them and have to put the same spongy struts back in.
    Not at all knocking this product, it looks very well made, just a lot of work to make it happen.
  18. Aug 25, 2024 at 3:18 PM
    #98
    FreshMexicanTaco
    AJ
    San Diego
    What part of the removal was a PITA for you? We haven’t had any significant difficulty, maybe not as easy as the 3rd gen but I would only ad maybe a 5% difference- on a lift though- so if you’re trying it on the ground it may be different.
  19. Aug 25, 2024 at 3:38 PM
    #99
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Yup on the ground like the peasant I am
    FunknNasty, PDKTaco and batman900 like this.
  20. Aug 27, 2024 at 8:21 AM
    #100
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Which part is difficult vs. 2nd/3rd gen? Suspension looks similar? Remove the two steering stop bolts, loosen the LCA cam bolts. Drop LCA down. I guess the sway bar link is extra work?
