2024+ Front Shock Top Hat Failure TALLY...
Discussion in '4th Gen. Tacomas (2024+)' started by FreshMexicanTaco, Aug 12, 2024.
Has your Top Hat failed?
  1. No
    139 vote(s)
    96.5%
  2. Yes, TRD OR
    4 vote(s)
    2.8%
  3. Yes, TRD Sport
    0 vote(s)
    0.0%
  4. Yes, SR/SR5/Pre-runner
    0 vote(s)
    0.0%
  5. Yes, Limited
    0 vote(s)
    0.0%
  6. Yes, PRO / TRailhunter
    1 vote(s)
    0.7%
  1. Sep 3, 2024 at 7:22 AM
    #121
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Half tons use the same method? That should make us less worried not more. Maybe I misunderstand.
    batacoma[QUOTED] likes this.
  2. Sep 3, 2024 at 7:23 AM
    #122
    TacoRancher
    Houston
    I was thinking articulation as well. It limits movement on the 3G. But it’s probably wishful thinking on my end.
  3. Sep 3, 2024 at 7:27 AM
    #123
    TacoRancher
    Houston
    Thanks.
    Hrímfaxi[QUOTED] likes this.
  4. Sep 3, 2024 at 7:29 AM
    #124
    TacoRancher
    Houston
    I got a trail hunter. I won’t be jumping the truck. But I will be going over potholes and dirt trails at speed. Hopefully the OME shocks will help some. If it breaks it breaks and I’ll deal with it then. Right now I’ve got a lot of anxiety over theoretical issues. I went through this on my 3G and at the end of the day it was a great truck. We shall see with this one. It is what it is.
    TOMRR likes this.
  5. Sep 3, 2024 at 7:31 AM
    #125
    Hrímfaxi
    Hrímfaxi Well-Known Member
    You’re welcome!
    Of course not something you should have to do a $65K dollar truck. Or any of the other trims for that matter.
    The first year run or two will expose gremlins, Toyota will address them, but will take some time. More I read, the more I think I should keep my 3rd Gen until after the smoke settles.
    TOMRR likes this.
  6. Sep 3, 2024 at 7:38 AM
    #126
    TacoRancher
    Houston
    So, I don’t see any bump stop on my brothers F150 Raptor… and that thing is tough as nails.. maybe it’s just a materials issue and not a design issue .. but I don’t really know much.
    Best I get off the internet and just enjoy the truck.
  7. Sep 3, 2024 at 7:40 AM
    #127
    Hrímfaxi
    Maybe!
    Best advice evar!
    TOMRR likes this.
  8. Sep 3, 2024 at 7:42 AM
    #128
    TacoRancher
    Houston
    Out of curiosity do half tons use frame mounted stops or just much stronger bumps inside the shock tower?
  9. Sep 3, 2024 at 7:44 AM
    #129
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I think this issue has probably already been fixed, just like the shutter issue went away. Toyota jumps on these problems as soon as the dealer logs in for the warranty repair. They are famous for flying a team to examine the problem. Busted stuff costs them money and product reputation.
    Vidman and Hrímfaxi like this.
  10. Sep 3, 2024 at 7:45 AM
    #130
    TacoRancher
    Houston
    Sir, you are being level headed and rational. Are you lost? This is TW.
    LN13, Sagebrush[QUOTED] and Hrímfaxi like this.
  11. Sep 3, 2024 at 7:46 AM
    #131
    Hrímfaxi
  12. Sep 3, 2024 at 7:47 AM
    #132
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
  13. Sep 3, 2024 at 7:58 AM
    #133
    TacoRancher
    Houston
    Hrímfaxi likes this.
  14. Sep 3, 2024 at 7:58 AM
    #134
    Sagebrush
    Gens 1, 2, 3, and 4
    Goin2drt and PDKTaco like this.
  15. Sep 3, 2024 at 7:59 AM
    #135
    TacoRancher
    Houston
  16. Sep 3, 2024 at 9:09 AM
    #136
    Tacowrench
    Tacowrench Well-Known Member
    Northern California
    2024 Bronze Tacoma TRD Off-Road
    Not bummed about having no bump stops... The only issue here is poorly casted shock cap and for Toyota to come clean with this. They need to replace the cap that will perform as intended.
    TOMRR likes this.
  17. Sep 3, 2024 at 9:18 AM
    #137
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    so if only 2 have failed out of 90,000 or so that means toyota was correct! no one actually takes their tacomas off road enough to break them! and one of the 2 that did actually break was from a suspension company basically trying to break something on the truck so they could sell people a fix....
    ace_10 and Goin2drt like this.
  18. Sep 3, 2024 at 9:30 AM
    #138
    Tacowrench
    Northern California
    Not sure where the stats came from, but suspension parts are crucial for off road adventures. Your correct about no one treating their Taco's rough or off-roading often, but when on remote areas, the last thing I want is to snap the shock from it's mount.
  19. Sep 3, 2024 at 9:55 AM
    #139
    Goin2drt
    Goin2drt Well-Known Member
    Amen. The amount of posts, threads, time and energy spent on what is a couple of parts that probably had a manufacturing defect and NO ONE else is having the problem. Icon has probably sold so many of these top hats. It will be hilarious for all those that use this so-called "fix" break something else cause by this "fix". I will just wait for mine to break and then drive it on over to the dealer and let them actually fix the so-called issue.
  20. Sep 3, 2024 at 10:04 AM
    #140
    TacoRancher
    Houston
    100%
    TOMRR likes this.
