2024 locking gas cap? Or fuel door?
Discussion in '4th Gen. Tacomas (2024+)' started by Kansas-CY, Nov 22, 2024.
  1. Nov 22, 2024 at 9:33 PM
    Kansas-CY
    Kansas-CY [OP] Member
    2024 Tacoma TRD Off Road
    Is there a locking option for 2024 gas cap? Haven’t found one yet that says it’s specifically for a 2024.
  2. Nov 22, 2024 at 10:01 PM
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Are you trying to prevent vandalism or gas theft?
  3. Nov 23, 2024 at 6:26 AM
    Kansas-CY
    Vandalism mostly
  4. Nov 23, 2024 at 6:45 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Here is the 3rd Gen Locking Gas Cap thread. I have the Stant on the left side of the pictures in post #61. No CEL light in 9 years of use. You may have to experiment to see if any gas caps work on your 4th Gen.
    https://www.tacomaworld.com/threads/locking-gas-cap.750710/page-4
  5. Nov 23, 2024 at 5:29 PM
    Kansas-CY
  6. Nov 23, 2024 at 6:55 PM
    TA2016
    Oregon
  7. Dec 8, 2024 at 4:23 AM
    Kansas-CY
    Well it works so far. Likes: key is universal direction so it’s easy to get it right. Dislikes: you have to turn the key clockwise to unlock. Then when you turn the cap counterclockwise, the key tends to rotate back to the lock position. Takes getting used to. My old cap had the key rotation the other way which made it much easier.
    3JOH22A and Vitamins like this.
  8. Dec 8, 2024 at 6:03 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Make sure you keep that lock cylinder lubed up with some type of WD40 or silicone spray. There’s nothing more aggravating than trying to get the cap off in inclement weather and the key won’t go in or turn.
    Also, get a duplicate key and store it in the truck. I had a locking cap on a car years ago, the key fell off my ring at the beach and I had no gas to get home. Luckily, by the grace of God listening to my prayers, I found the key in the dirt parking lot!
    PUMPKINKING and Kansas-CY[OP] like this.
  9. Dec 8, 2024 at 7:00 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can you pull the key out after unlocking?
    Does the cap automatically relock without the key when you re-install the cap after fuelling?
  10. Dec 8, 2024 at 7:35 AM
    Kansas-CY
    Key doesn’t pull out when it’s turned in the unlock position. You can only get the key out after turning it’s position to lock.
  11. Dec 8, 2024 at 10:10 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Thanks. Reviews say the thread size is the same as recent-year 4Runners, which means it's the same as 2009-2023 Tacomas as well. If you want, try MotoRad MGC791; you can remove the key after unlocking, but need to manually lock with the key after re-installation. I've used this on my 4Runner for two years without issues.
    https://www.rockauto.com/en/moreinfo.php?pk=4592727&cc=0&pt=5900&jsn=323&optionchoice=0-0-0-1
    https://www.amazon.com/MotoRad-MGC791-52127864AB-52100465AA-F67Z9030DA/dp/B000C5CEKC/
    I give all lock cylinders a spray of teflon lube before every winter: driver's door, tailgate, tonneau, and fuel cap.
