2024 or 2025 Anybody having Problems
Discussion in '4th Gen. Tacomas (2024+)' started by mark530, Dec 5, 2024.
  1. Aug 13, 2025 at 11:37 AM
    #61
    dweid
    dweid Active Member
    xtracabs are hard to get, esp the sr5 ones - SRs I've seen around. The pathfinder way back when was one of the most unsafe vehicles for front seat passenger injuries. I'd believe it if the Frontier was not great.
    batacoma[QUOTED] likes this.
  2. Aug 13, 2025 at 11:40 AM
    #62
    dweid
    dweid Active Member
    nope, 4x4 SR5 - with a cold weather (tech) package is going to be around that depending on dealer fees.
  3. Aug 13, 2025 at 11:49 AM
    #63
    dweid
    dweid Active Member
    towing with a lift... I'd regularly tow a 6" wood chipper with my gen 2 6MT those were just shy of the taco's rated tow capacity (around 6600 iirc) - the rental place wouldn't let me toe an 8" one - to heavy.
  4. Aug 13, 2025 at 11:50 AM
    #64
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I think the new engine will do fine , it may be a little finicky when the miles pour on but it will depend on people and maintenance. Now more than ever . If I ever own 4 th Gen
    4 k miles on the oil is how I will roll. . No matter what any one says , turbos and clean oil are a must
    95SLE likes this.
  5. Aug 13, 2025 at 12:05 PM
    #65
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    There's an engine. I guess you 4th gen guys don't know much about "bro lean". Towing capacity on 2nd gen v6 is 6500lbs and I'm still shy a few lbs.
    NO... you should not try this with a 4th gen unless you want your trans to sh!t the bed.
  6. Aug 13, 2025 at 12:10 PM
    #66
    Vereor_Nox
    North California
    I got more towing miles on my taco then 4th genners have freeway miles. That's how far
  7. Aug 13, 2025 at 12:12 PM
    #67
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Show your research.
  8. Aug 13, 2025 at 12:15 PM
    #68
    snickers
    Mouth breathers come in flocks. Must be a migration of dodo birds flying through.
    TurboDA6 likes this.
  9. Aug 13, 2025 at 12:32 PM
    #69
    dweid
    dweid Active Member
    not sure why you feel the need to post a derogatory remark?
  10. Aug 13, 2025 at 12:35 PM
    #70
    snickers
    Because I felt like it.
  11. Aug 13, 2025 at 12:39 PM
    #71
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    That doesn’t answer my question.
  12. Aug 13, 2025 at 12:41 PM
    #72
    CrispyTacoLover
    I was thinking it’s a short distance from storage to the boat ramp.
  13. Aug 13, 2025 at 12:45 PM
    #73
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Friday's come early this week.
    CrispyTacoLover likes this.
  14. Aug 13, 2025 at 2:12 PM
    #74
    TruckGuy63
    Gilbert
    New York
    Don’t care about research, I worked on motors my whole life . There’s my research , no disrespect, but if I spend 50 k on a truck I will maintain the hell out of it . Now if that’s not agreeable with some people it’s ok . My things ,my money , my way .
  15. Aug 16, 2025 at 5:54 PM
    #75
    Longbow25
    Longbow25 Well-Known Member
    Colin
    2021 Black TRD Pro
    You are 100% correct. Clean oil is uber important to both the turbo and to high compression engines in general.
    Research? It's obviously a known fact... anyone that doesn't know how this works should start by reading Maximum Boost by Corky Bell. I think the guy you're replying to is just real grumpy...
  16. Aug 16, 2025 at 6:14 PM
    #76
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    Every 5K, throw the old oil away...
    1Strailhunter likes this.
  17. Aug 16, 2025 at 7:24 PM
    #77
    gpb
    Atlanta
    What’s the compression ratio on the 2024+ and how does it compare to the 2016-2023 compression ratio?
  18. Aug 16, 2025 at 8:22 PM
    #78
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    The 3.5 v6 had 11.8 and the new turbo 4 has 11.0, but that turbo is certainly increasing the cylinder pressure.
    GrrrMaker likes this.
