2024 Reliability / Durability - Believe it or not?
Discussion in '4th Gen. Tacomas (2024+)' started by Fast1, Nov 20, 2023.
  1. Nov 27, 2023 at 5:11 PM
    #121
    Helen3RFT
    Helen3RFT Veteran
    Helen
    A free state east of California
    "Discipline Equals Freedom.” -Jocko
  2. Nov 28, 2023 at 7:08 AM
    #122
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    If I bought an early 24’ would anyone pay $5 a month on patreon for a monthly “reliability report”?
    I drive approximately 72k miles a year.
  3. Nov 28, 2023 at 10:33 AM
    #123
    packfan
    packfan Member
    ^ Have you ever considered getting a different job or changing your life so you drive less? I don't drive 72,000 miles in 5 years and I make a heck of a living.
  4. Nov 28, 2023 at 10:43 AM
    #124
    Fast1
    Fast1 [OP] Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
  5. Nov 28, 2023 at 11:28 AM
    #125
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Finally the diesel everyone wanted.
    Lt. Dangle and Williston like this.
  6. Nov 28, 2023 at 11:48 AM
    #126
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is TFL video where they show the 4th Gens increased turning radius, engine did have somewhat diesel sounds as he tried to maneuver the sharp corner.
  7. Nov 28, 2023 at 12:34 PM
    #127
    Fast1
    Minneapolis, MN
    the video I posted they actual step outside the truck and listen to it reving.. sounded like shaking a can filled with rocks.
    shakerhood[QUOTED] likes this.
  8. Nov 28, 2023 at 2:18 PM
    #128
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    enforcertaco91 likes this.
  9. Nov 28, 2023 at 2:21 PM
    #129
    BirdBrain
    BirdBrain Well-Known Member
    2021 4wd Off-Road
    We’ll know how reliable they are in a few years.
  10. Nov 28, 2023 at 8:09 PM
    #130
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It sounds like an amazing machine. I’ll be picking one up in a few years for sure. The only question is 6 speed manual or full hybrid automatic. Hmmm
  11. Nov 29, 2023 at 12:47 AM
    #131
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
    I’m keeping an open mind to see how this turbo 4 would go reliability wise. Especially the gas model with the 6-speed manual
  12. Nov 30, 2023 at 7:54 AM
    #132
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Toyota manufactured turbo motors 25~30 years ago that are still highly desired in performance swaps (1JZ-GTE and 2JZ-GTE). They've probably learned a few things in all those years.
  13. Dec 1, 2023 at 3:35 PM
    #133
    enforcertaco91
    enforcertaco91 Well-Known Member
    West is best !
    2024 Tundra Terra (terror) Pro
    PPF Front grill, bumpers and headlights.
    ::boo::hissssss:: Get a new model ! :)
  14. Dec 1, 2023 at 4:12 PM
    #134
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    In 3 years...when I trade in the v6 for a 4cyl turbo with all the kinks worked out...
  15. Dec 2, 2023 at 1:00 PM
    #135
    Fast1
    Minneapolis, MN
    Has anyone wondered how having the catalytic converter housed inside the engine compartment under the hood next to the engine/exhaust manifold on the 2024 Turbo 4 banger will add to the known turbo generated heat production? What happens to under hood temps when you turn the engine (and coolant flow) off and that catalytic converter is still roasting hot?
    What is the normal temperature for a catalytic converter?
    Normal operating temperatures of a converter are 500-800°F, and up to 1200°F when the vehicle is under heavy load.
  16. Dec 18, 2023 at 8:57 AM
    #136
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I wasn't aware that there were tunes available for the Highlander. So that's the same engine that Sheldon Brown said is designed to be 50% stronger for the Tacoma?
    BTW, even without tunes this 2.4 Turbo is packing more punch than any Tacoma engine before it. To reach peak torque under 2000 RPM and with and 8-speed auto that sounds like a good driving experience to me. With those numbers gear-hunting should be almost non-existent. There's another video that has a 3rd gen chassis/engine next to a 4th gen chassis/engine. In there the gentleman mentions that they tested the engine at different angles to simulate people off-roading at those extreme angles. I wonder if that's a response to some of the 3rd gens having the smoke-on-incline issues? I've seen a few posts on here about that but never witnessed this on any of the 3rd gens my friends have had. It also seems to happen on some 2019 and older models, I haven't seen/read/heard of this happening on the 2020-2023 models. Maybe it's been fixed?
    Sweets and enforcertaco91 like this.
  17. Dec 18, 2023 at 4:36 PM
    #137
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    …Hauling on a 100°+ day…hurts just thinking about it!
    Fast1[QUOTED][OP] likes this.
  18. Dec 18, 2023 at 4:42 PM
    #138
    Topanga Taco
    Rick
    :evil:
  19. Dec 18, 2023 at 5:17 PM
    #139
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    I believe the low volume of vettes changes the calculus on CAFE. It is, after all, a corporate average
  20. Dec 18, 2023 at 5:23 PM
    #140
    GBR
    GBR Well-Known Member
    19 TRD OR
    I guess, but then it's no different than Toyota pulling the 3.5 off the shelf for the 3rd gen. Manufacturers trying to have as few engines as possible has been a thing for as long as the industry has existed.
