2024 Tacoma Owner's Manual & Maintenance Booklet
Discussion in '4th Gen. Tacomas (2024+)' started by 3JOH22A, Dec 11, 2023.
  1. Dec 13, 2023 at 6:08 PM
    #61
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    It says allow the engine to idle immediately after hill climbing.
    Not after pulling in a rest stop, driving through town, etc. But idle immediately. Which means stop.
    I have been on interstates where they have lanes reserved to the side for steep grades.
    So you would according to the manual have to immediately pull off and idle at the top to prevent damage. That's what it says. At least you can look at that big display while you are idling.
    No thanks.
    taco terror likes this.
  2. Dec 13, 2023 at 6:09 PM
    #62
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Doesn't the turbo have its own coolant circuit with an electronic water pump?
    Maybe they still want the oil to be circulating
  3. Dec 13, 2023 at 6:23 PM
    #63
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    I'll try one more time.
    It means after you are done driving. Like if you have been gunning it, let it idle for a minute or two after coming to a stop.
    You do not have to pull over and stop after you crest the top of a long steep hill on the interstate and start going down the other side. That would be ridiculous.
    BrokenMachine, BC Hunter and GBR like this.
  4. Dec 13, 2023 at 6:27 PM
    #64
    GBR
    GBR Well-Known Member
    19 TRD OR
    If that was the case then why doesnt Toyota specify a time limit for driving up a hill or driving 62 mph or greater?
  5. Dec 13, 2023 at 6:30 PM
    #65
    3JOH22A
    3JOH22A [OP] トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No. The turbo is cooled only by oil, so the engine needs to be running for the oil to circulate. If the oil stops flowing in a hot turbo, the stationary oil in the turbo gets cooked.
  6. Dec 13, 2023 at 6:32 PM
    #66
    GBR
    19 TRD OR
    I'm legitimately not sure if you're being serious.
  7. Dec 13, 2023 at 6:33 PM
    #67
    3JOH22A
    District 6ix
    No. Idle just means foot off the gas. :facepalm: There's no requirement to "come to a stop", that would be contrary to the physics of the problem.
    BC Hunter likes this.
  8. Dec 13, 2023 at 6:36 PM
    #68
    2016Tacoman
    J
    Idle. Idle immediately. Look up the definition.
    RTFM.
  9. Dec 13, 2023 at 6:39 PM
    #69
    adrew
    Leer 100XR
  10. Dec 13, 2023 at 6:40 PM
    #70
    2016Tacoman
    J
    So after climbing a mountain we leave our foot off the gas on the interstate for "approximately one minute " ? :facepalm: :rofl:
    There are no physics involved here, maybe thermodynamics.
  11. Dec 13, 2023 at 6:47 PM
    #71
    3JOH22A
    District 6ix
    ^Only if you for some reason plan on shutting off the engine on the Interstate immediately after climbing said hill. ;) You neglected to read the section heading "Idle time before engine stop".
  12. Dec 13, 2023 at 7:04 PM
    #72
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    If only you read the header of the screenshot. Where it says “before engine stop.”
  13. Dec 13, 2023 at 8:01 PM
    #73
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Idle immediately before engine stop is not the same as idle immediately.
    The turbo is water cooled, and doesn’t have a separate water pump.
    Jeff
  14. Dec 13, 2023 at 8:07 PM
    #74
    GBR
    19 TRD OR
    So the water pump is mechanical and there is no secondary pump?
    Thanks.
  15. Dec 13, 2023 at 8:21 PM
    #75
    Jeff Lange
    Calgary, Canada
    Correct. Some models do contain an additional pump for the HVAC heater core, but not for the turbo.
    Jeff
    3JOH22A[OP] and GBR[QUOTED] like this.
  16. Dec 13, 2023 at 8:25 PM
    #76
    GBR
    19 TRD OR
    Thank you sir!
    Well, that explains why there is an idle recommendation at all.
    Jeff Lange[QUOTED] likes this.
  17. Dec 14, 2023 at 5:21 AM
    #77
    batt700
    batt700 Well-Known Member
    2017 SR5 Premium 4Runner
    So basically after every single highway ride that is above 62 MPH (every time on the interstate it's like ~70 MPH) you would need to idle for 1 minute once you get to your destination before turning the truck off?
    Yeah what a fucking joke.
  18. Dec 14, 2023 at 5:22 AM
    #78
    81shark
    81shark Well-Known Member
    i heard you can only go 1/4 mile up hill before you have to take a one minute break
  19. Dec 14, 2023 at 5:28 AM
    #79
    GBR
    19 TRD OR
    Are your destinations typically on the shoulder of the interstate?
  20. Dec 14, 2023 at 5:58 AM
    #80
    batt700
    It clearly states allow the engine to idle immediately after high-speed driving, which it defines as "continuous driving of 62 MPH or more". On the highway i am continuously driving at 62 MPH or more.
    So no, my destination would be a couple minutes out from the interstate usually, at which point i assume i would need to idle for 1 minute based on the manual. Or would i need to idle the second i get off the highway?
    2016Tacoman likes this.
