2024 Tacoma TRD Offroad Needle Bearing
Discussion in '4th Gen. Tacomas (2024+)' started by Shanen806, Aug 30, 2024.
  1. Dec 19, 2024 at 7:19 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    I just ordered King 2.5 Coil-Over Shocks front and rear with intention to adjust them for a 2.5" lift (stock springs) on a 2024 Off Road.
    So I understand correctly that the ECGS bushing replacement on the drivers side CV axle is a must to avoid problems?
    How much time in labor is in the install?
  2. Dec 19, 2024 at 7:33 PM
    PDKTaco
    PDKTaco Well-Known Member
    Montana
    2024 TRD Off-road
    Book says 5 hours! Real world 2-3, best to do it when installing the shocks, since it’s already 1/2 way tore down. I would have if I’d have known it’s still an issue!
    Definitely would be easier with the shock removed to install the bushing..
  3. Jan 1, 2025 at 1:03 PM
    fitsofrage88
    fitsofrage88 Well-Known Member
    ATX
  4. Jan 1, 2025 at 6:44 PM
    SouthbayluxeTaco
    SouthbayluxeTaco Active Member
    Hugo
    Los Angeles CA
    2024 TRD Off road Tacoma
    2.5 King suspension front and back, Icon Billet uppers, retrax bed cover, yakima overhaul HD, wescott roof rack, 285/70/17 Toyo open country, K&N intake, AFE heat & cool exchange pipes,
    Can you explain your situation?
    I recently lifted my truck with a 2.5 king kit and when I turn into driveways at full lock my truck clunks/thumps.
  5. Jan 1, 2025 at 6:47 PM
    SouthbayluxeTaco
    Hugo
    Los Angeles CA
    What type of noises are you getting ?
    I did 2" and it clunks/ thumps when I enter a steep driveway at full lock
  6. Jan 1, 2025 at 6:54 PM
    SouthbayluxeTaco
    Hugo
    Los Angeles CA
    Did you install the king 2.5 kit ? I have it and didn't do the bearing because the shop I trusted didn't say anything about needing it. When I enter driveways the play evey buddy is talking about that the CVs have make a clunking/thumping. FYI
  7. Jan 1, 2025 at 7:45 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    The ECGS bushing isn't sold as a fix for suspension clunking/thumping. It solves a hum/vibration that appears in 2wd around 35-40 mph on some lifted trucks, but can on stock rigs also, due to slop in the front differential DS oem needle bearing. 99% of the time it can be diagnosed by putting the TC into 4H to see if the hum/vibration stops. If it does, the bushing is a solution.
  8. Jan 2, 2025 at 7:19 AM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    Check out this thread:
  9. Jan 4, 2025 at 7:56 AM
    fitsofrage88
    ATX
    Some good info here!… as follows..
    https://www.instagram.com/reel/DEVmao4yg6m/?igsh=MWgwMzVoc2swdjM4MA==
    R242 and PDKTaco like this.
  10. Jan 7, 2025 at 12:22 AM
    SouthbayluxeTaco
    Hugo
    Los Angeles CA
    Thanks for this brotha !
    After my offroad weekend. The knocking and clunking has actually gone away on full lock going into a driveway.
    But ! Now I've been noticing a vibration like this video explains. But only at low speeds. In the 4th Gen I feel it in my brake pedal. I have an appointment with an offroad shop this Thursday to have him Inspect the the that 88 rotors did. Which btw. I'm starting so realize that they are horrible at what they do. They are a blow and go shop. They install your kit, take your money and don't help you fix anything thag might have been created by the kit installed. I am a business owner my self and this is not a good way of doing business, IMO.
  11. Jan 7, 2025 at 4:12 PM
    fitsofrage88
    ATX
    yes sir..
