2024 trailhunter reviews
Discussion in '4th Gen. Tacomas (2024+)' started by toystory, Jan 18, 2025.
  1. Jan 19, 2025 at 12:39 PM
    dneal
    dneal Well-Known Member
    MidMO
    24 TRD OR 6M
    Yes. Me calling them prop shafts is old habit. They die hard... ;)
  2. Jan 19, 2025 at 1:28 PM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    On Fuelly Tacoma ORs are getting 19.4 average, which is about 1.5 less than EPA (assuming none of the 51 are hybrid). The EPA says you lose about 1-2% fuel efficiency for every 100lb. If you assume the hybrids are carrying 500lb of dead weight and provide no mpg benefit (compared to a non-hybrid) it would lose about 1.6 mpg. Subtract that from what the OR drivers are getting and a Trail Hunter should be around 18. Trail Hunter drivers are clearly driving their vehicles more aggressively.
    snickers likes this.
  3. Jan 19, 2025 at 1:33 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    First month was a blast making that thing launch and turbo sing.
    Vidman likes this.
  4. Jan 19, 2025 at 1:42 PM
    SheauxTyme
    SheauxTyme Member
    2024 TRD Pro. Stock. Same hybrid as the Trailhunter. I don’t drive hard - at all. Commute is about 25 miles per day, 50% at 60mph, the other at 40mph. Tires at 30psi. Getting 17.6mpg overall. Didn’t buy because of mpg, but surprised it’s this poor.
  5. Jan 19, 2025 at 1:45 PM
    toystory
    toystory [OP] Active Member
    RB
    2014 reg cab 4cyl.
    3" fox 2.0 shox, SPC uca's, 3" expedition leaf, Walker Evans wheels, ARE topper
    Yes, chunky batteries don't help. I've wanted to give hybrid a bit more time, guess I'll give em some more.
    My 4 cyl only gets 18 mpg with all my sweet aero deletions, tires and topper. Would like to get back to consistent 20 mpg.
    Appreciate your chat time.
  6. Jan 19, 2025 at 1:49 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    TH getting 16.5 vs OR getting 19.5 means you'll need to put an extra two gallons in every fill up. National average is $3.12, so $6.24x52 = $324/yr. I think if you can afford $65K for a TH you're not going to sweat the $324.
    Vidman likes this.
  7. Jan 19, 2025 at 1:57 PM
    SheauxTyme
    SheauxTyme Member
    Not sweating the $ at all. Just pointing out mileage averages far below what’s stated by Toyota. And, for those who say the auto manufacturers always post numbers based on perfect conditions…I came from a 2016 F-150 with posted numbers of 17/20, got 18mpg over 90,000 miles.
  8. Jan 19, 2025 at 2:20 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    Interestingly, Fuelly says Ranger Raptors have been averaging 16.4. I guess if you want that kind of truck/performance that’s the mpg you are going to get.
  9. Jan 19, 2025 at 2:30 PM
    SheauxTyme
    SheauxTyme Member
    Interestingly, I didn’t buy a Raptor…bought a TRD Pro. But, thanks for sharing.
    rchrds and dneal like this.
  10. Jan 20, 2025 at 2:01 PM
    rchrds
    rchrds Well-Known Member
    TN, USA
    2024 Trailhunter
    Or your math doesn't match up with reality. I drive like a grandma, and never over 73, even in Texas. Still 15.1 best case, as low as 12 loaded and into the wind travelling west.
  11. Jan 20, 2025 at 2:49 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    What did you average in previous vehicles?
  12. Jan 20, 2025 at 3:12 PM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    The TH is also taller and has bigger tires than the stock models. And a few hundred additional pounds of bolt-ons.
  13. Jan 20, 2025 at 3:30 PM
    rchrds
    TN, USA
    2024 Trailhunter
    My 2004 started at 18 when new, over the years (20) worked it's way down to 16.5 as the head gasket started to leak. When I sold it last summer it was 16-16.5.
    Edit: This is what really pisses me off. I was hoping for at least a 1-2 mpg increase over my 2004 Tacoma. Instead...less.
  14. Jan 20, 2025 at 3:37 PM
    Snakepilot
    Tucson, AZ
    2025 Tacoma TRD Pro
    I've met or exceeded epa mpg on every vehicle I've owned. Maybe not every tank, but around 90% of the time.
    People say they don't drive with a heavy foot but I also hear a lot of people complain they can't lose weight even when they diet. They're eating more than they think. Maybe your driving is more aggressive than you think.
    Clervis likes this.
  15. Jan 27, 2025 at 1:41 PM
    #35
    timetoeatpotatoes
    timetoeatpotatoes Well-Known Member
    2024 Bronze Oxide Trailhunter
    the EPA tests suck. The highway test has an average speed of 48.3mph and does not go above 60 mph. the _high speed_ test averages 48.3mph and goes over 70 mph for just ~30 seconds.
    Drive faster than 65-70 mph? We have the aerodynamics of a brick. unless youve got a tailwind you wont get the epa numbers.
  16. Jan 27, 2025 at 1:43 PM
    #36
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Why can’t they test more real world?
  17. Jan 27, 2025 at 1:48 PM
    #37
    timetoeatpotatoes
    no clue. they haven't updated the test methodology since 2008 but even for that time, the speeds are too low.
    Wouldn't be hard to get a much better test. Like, just driving a real world route 10 or 20 times and avg it. or just hold the speed at the typical interstate speed limit for more than 30 seconds if they want to keep it a lab test and eliminate wind and temp variance. hold it there for half an hour so we can actually get some real data.
    CrispyTacoLover likes this.
  18. Jan 27, 2025 at 2:04 PM
    #38
    Schlappesepple
    Joe
    2020 4Runner ORP
    :rolleyes:
    They're not giving you the 48 mph mileage and publishing that as your expected highway mpg.
    Yes, the testing doesn't always line up with what you get real-world, but the important thing to remember is the testing is standardized. So you can usually compare cars with confidence (at least from different manufacturers). Car reviewers generally comment on real-world mpg as well.
    What I would do is look at fuelly.com for your current car, and compare your mpg to the user-reported average. Then you can look at other cars, and estimate where you'd be if you drove that car (i.e. below, at, or above average).
  19. Jan 27, 2025 at 2:10 PM
    #39
    CrispyTacoLover
    My fuelly average is 18mpg over 3500 miles. Very little freeway driving. But it isn’t Trailhunter.
  20. Jan 27, 2025 at 2:47 PM
    #40
    timetoeatpotatoes
    The EPA absolutely intends for this to be real world data:
    https://nepis.epa.gov/Exe/ZyNET.exe...ndex="2011+Thru+2015"/>&QueryTerms=real+world
    and a well designed repeatable lab test can do that, but the tests are just simply not representative of real world driving. people can look at fuelly to get a much more real world idea of what they can expect.
