2024 TRD Off-road suspension overview and flex test
Discussion in '4th Gen. Tacomas (2024+)' started by Fast1, Jan 23, 2024.
  1. Feb 6, 2024 at 12:22 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Here is a reminder that the fat ass factory 200 series land cruiser bone stock can manage a 661.
    Junkhead likes this.
  2. Feb 6, 2024 at 2:06 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    If I was to regear then I would have absolutely done the same.
    My truck came with 4.30 so I got no complaints.
  3. Feb 6, 2024 at 2:07 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    FWIW I’m sans sway bar and my truck rides so much nicer on FSRs and in general.
  4. Feb 6, 2024 at 2:22 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    I should have been more clear. Removing the front swaybar allows the front tires to move independently of each other, which really helps on forest service roads on the potholes and washboard. But I daily drive my truck and I like having the swaybar installed for better handling on road. The ability to hit a disconnect button for driving offroad is appealing to me because I could have the best of both worlds.
    FWIW, I'm not trying to start a debate on swaybar vs. no swaybar... I know everyone has a different opinion. I just wanted to point out that the speed threshold seems very low on the Toyota.
  5. Feb 6, 2024 at 4:39 PM
    Fast1
    Fast1 [OP] Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    :thumbsup:
    Tested by the same guy in my original post of this thread. The results seem to make a joke of the new 24 Tacoma (street truck?) and the RTI score.
    https://www.youtube.com/watch?v=hBQgYBpGCtg
    Junkhead and SH10151[QUOTED] like this.
  6. Feb 7, 2024 at 9:53 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You're exactly right. If you were hitting stuff that resembled speedbumps at a perfect 90 degree angle to the vehicle, the sway bar being engaged wouldn't make a difference. But on roads like you're referring to, what's hitting a wheel isn't necessarily hitting the other wheel at the same time which results in a LOT more force/shock entering the cabin because you're using the bar to significantly bolster the spring rate of the affected wheel. It's like driving down the road with spring rates that are something like 50% more than what's on your truck (which would be HORRIBLE haha).
    And there's zero debate on swaybar vs no swaybar...the truck absolutely drives better with a swaybar on the road; period. That's what's so exciting about a disconnectable sway bar. Best of both worlds! And I agree, the speed at which it reconnects is a bit low. But I bet someone will hack it so you can keep it disconnected at any speed much like someone created a board to do 2WD LO. :)
    MasonSTL and bigd9247[QUOTED] like this.
  7. Feb 7, 2024 at 10:35 AM
    bigd9247
    WA
    Yes, hopefully someone will come up with a way to disconnect the swaybar at any speed!
  8. Feb 7, 2024 at 11:28 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    It would be a manual bypass. Meaning cutting the link to the ECU and act like any aftermarket disconnect. At least Toyota would have already built out the parts. Parts that you can assume reliable. The inherent risk is Toyota voiding warranty on anything they deem associated and your insurance company denying payout on a catastrophic crash just because they can.
  9. Sep 6, 2024 at 11:44 PM
    TacoRancher
    TacoRancher Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    I wonder when the 24 PRO and TH with their upgraded suspensions will be tested on the ramp and if that makes a difference for those models. Curious if they can match the 3G pro.
    Fast1[QUOTED][OP] likes this.
