2024 Turbo manufacture and model
Discussion in '4th Gen. Tacomas (2024+)' started by XilverTaco, Jan 12, 2025.
  1. Jan 17, 2025 at 10:15 AM
    #61
    MGMDesertTaco
    Nice
    JustDSM[QUOTED] likes this.
  2. Jan 17, 2025 at 10:20 AM
    #62
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    Oh, good to know!
  3. Jan 17, 2025 at 10:49 AM
    #63
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Trans tuning for one and I want the ECU flashed not a piggy back intercepting data.
    Most piggybacks are designed to work in conjunction with factory sensors and do not offer any tuning changes other than timing, rev limiters, fuel cut-off, etc. With an actual ECU Flash, you can adjust almost every single parameter that affects how your run. You can add multiple stages of boost, adjust your cam timing, run sequential setups, run piggyback CDI’s, and much more
  4. Jun 15, 2025 at 1:19 PM
    #64
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    It's been a few months. Anyone have the specs on the stock turbo so that aftermarket turbos can be considered? Also, I haven't seen anyone making downpipes for the T24A in longitudinal format. Hope that changes.
    I hear @JustDSM is evaluating a set of replacement turbine wheels that re-uses the stock turbo housing.
  5. Jun 15, 2025 at 1:45 PM
    #65
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I’m not able to share the specs at this time. I expect to be able to make that information public once we finish testing on the upgraded unit (larger compressor and turbine).
