2025 EV Tacoma thread.
Discussion in 'Electric Vehicles (EVs)' started by G2.M6, Jan 13, 2022.
  1. Jan 27, 2022 at 5:15 PM
    #261
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The last description of the Rivian's size was on a YouTube video, they said smaller than a Full Sized but larger than the Mid Sized.
    Lt. Dangle and Benny blanco like this.
  2. Jan 27, 2022 at 5:18 PM
    #262
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    What facts? I'm taking about discussion board conjecture.
  3. Jan 27, 2022 at 5:19 PM
    #263
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Compared to a DCSB the Rivian is about 5" longer, 6" wider and up to 9" taller depending on air suspension settings.
    shakerhood[QUOTED] likes this.
  4. Jan 27, 2022 at 5:32 PM
    #264
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Like when someone says can I get my steak in between med rare and medium.
  5. Jan 27, 2022 at 5:34 PM
    #265
    shakerhood
    Southern Ohio
    That actually sounds pretty good!
  6. Jan 27, 2022 at 5:40 PM
    #266
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    Sheesh. The choices are black and blue, very rare, med rare, medium, medium well, well, and extra well.
  7. Jan 27, 2022 at 5:42 PM
    #267
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I think a better analogy would be or if we could get a Tacoma with a cab in between the double cab and access cab, and 6” longer bed
  8. Jan 27, 2022 at 6:15 PM
    #268
    Mattedfred
    Mattedfred Well-Known Member
    Ted
    2012 Tacoma SR5 DC 4WD
    OK. Sorry. I guess I missed those posts.
  9. Jan 30, 2022 at 5:26 AM
    #269
    Mattedfred
    Ted
  10. Jan 31, 2022 at 6:23 AM
    #270
    Mattedfred
    Ted
    Does anyone know why they only got 2% regen during the descent?
  11. Jan 31, 2022 at 11:12 AM
    #271
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Probably batteries were hot and the truck didn’t want to add more heat into them via the “regen” charging .
    Regen is just another word for charging your batteries at some power rate (watts) . When you charge EVs fast or at a high rate (like a 100kw supercharger or “regen breaks” at many kw) it makes the batteries heat up faster. So possibly rivian built that fail safe into the Regen .
    Or maybe the settings were not optimized or maybe Rivian sucks vs other EV makers at key parameters like battery conditioning, heat management and efficiency …
    when I put my model 3 in “track mode” the battery radiator/ coolant kicks on constantly and I also turn off “regen” to avoid any additional heat going into batteries
    As time goes on and more ppl learn the ways of the ev, these concepts of heat , efficiency will be more understood by all . At that point they will see why there is only one real option for EVs , Tesla. Everyone else is making nice little project cars for practice. Practice makes perfect, so others will catch up soon I hope.
  12. Jan 31, 2022 at 12:53 PM
    #272
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Yeah, that makes sense. Our plug-in Prius will similarly kick on the ICE and stop charging if you run it down a big steep hill.
    shakerhood likes this.
  13. Jan 31, 2022 at 2:57 PM
    #273
    2000prerunner23
    steve
    Yeah. Hot not good always. Tesla does a little better job with “thermal management” than the others but it’s not a night and day difference. With 20 min of hard beating on a track the model 3s radiator/heat pump can’t keep up with the hot battery. It’s a fact. I won’t lie to you guys. You guys are cool. But , that’s not very common (track day , or heavy towing).
    Don’t let these issues make u think “well it will be the same headache as a gas car , just a new type of head ache.” No.
    let me tell you why (and I won’t mention obvious shit like no gas / oil / spark plugs or smogg….)
    - switching on/off our rear E locker doesn’t happen always as requested, and the POS takes time to engage. Quad motor ev = no differential, no re gear needed , no lockers or any mechanical traction aid. It’s always ready to be “locked” or not .
    - switching transfer case into 4Low or even 4high isn’t always a sure thing. Can get stuck in one or the other which is annoying when needed or if it leaves you stranded.
    - running 35” tires and driving on the highway or off road in sand / steep hills is super annoying shifting between gears. Gets your auto trans hot as you shift from 2/3 every 10 seconds when beating in dirt. Also going up steep hills = rape for engine and transmission . Even with costly re gear ( not needed with ev) this still wears your mechanical monsters seals , gears , fluids.
    -when you’re crawling you will not accidentally stall your motor because you hit the brakes too hard (or bounced off a rock ) and now came to a complete stop in first gear with a manual (couldn’t press the clutch in in time). in the EV with the instant torque you can 1 foot drive over difficult obstacles without cooking the torque converter or having to play around with the clutch and getting stressed out.
    - when off roading , that TRD shitty fake sounding flomaster exhaust sound ruins the ambience when you’re out in the desert or out in the mountains and just want to relax and enjoy nature. Nobody wants to hear that dumb ass drone all up and down the trails . shut the f* up. Ev silent , Just like a herd of elephants silently moving through the forest. Such power but no sound.
  14. Feb 1, 2022 at 12:10 PM
    #274
    Mattedfred
    Ted
  15. Feb 1, 2022 at 12:12 PM
    #275
    Mattedfred
    Ted
  16. Feb 1, 2022 at 4:17 PM
    #276
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Mattedfred[QUOTED] likes this.
  17. Feb 1, 2022 at 4:24 PM
    #277
    trdxtacoma
    trdxtacoma Well-Known Member
    18 Tacoma SR AC
    I doubt Toyota has the EV tech that can compete. Have yet to see a Toyota BEV with the range/performance that can stand to Tesla, Ford, GM, VAG.
    The only thing that can save Toyota in the EV market is if they can get an electric truck out before everybody else. But that doesn’t sound even slightly possible at the moment.
    2000prerunner23 likes this.
  18. Feb 1, 2022 at 4:28 PM
    #278
    stevesnj
    No EV tech to compete? Toyota has had EV's before Musk had his prototype roadster. What's the rush? Proper R and D. While the American companies rush to get their trucks out Toyota wants to do it right. I'd rather have a proper engineered EV truck than a rushed one. Lets see how long before the American trucks get recalled because they wanted to do it quick. Toyota is in a lot of markets in the world. They can't afford to rush things.
  19. Feb 1, 2022 at 4:41 PM
    #279
    trdxtacoma
    18 Tacoma SR AC
    Which Toyota EV is there? Full EV. Hybrids don’t count. If there is I want to buy one.
    The 2010 RAV4 EV was a project with Tesla. I think the CHR/Lexus UX is available as a EV in foreign markets but the range is mediocre compared to what’s on the market.
    Toyota has had plenty of time to develop their EV tech. They dropped the ball and put their money on hydrogen and hybrids. They are finally playing catch up now. I understand Toyota will probably want to do an in-house battery unlike GM/Hyundai going with LG, but that takes time. The competition is already leagues ahead of Toyota assuming they are still using pre-2010 battery technology
  20. Feb 1, 2022 at 4:48 PM
    #280
    stevesnj
    Hybrids are EV's. Have always been. Toyota is building a battery plant in the USA which looks like Panasonic. Panasonic has been used in Toyota's for years as their main battery supplier. I believe most Toyotas use Panasonic starter batteries to this day. So to me 2025 isn't a long way away. I'd want it right, not quick. Who cares what others are doing. When Toyota gets going they and I believe the Germans will dominate the EV market along with hyundai.
