209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Sep 14, 2018 at 10:23 AM
    #2401
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    A rivet gun or a Rivnut?
    I have both
    Anderson and FirstTimeFirstGen like this.
  2. Sep 14, 2018 at 10:24 AM
    #2402
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I looked at the hardware and its a standard rivet nut
  3. Sep 14, 2018 at 10:29 AM
    #2403
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    According to the Genesis video there was NO indication that you need a rivet gun. So unless you have 6 1/2 inch holes in your sheet metal with no way of filling it in, please refrain from saying that I shouldn’t be frustrated. Thanks.
  4. Sep 14, 2018 at 10:30 AM
    #2404
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I never said you shouldnt be frustrated. I would be too.
    You got friends here saying they will help you install so Im not sure why youre still feeling the way youre feeling.
  5. Sep 14, 2018 at 10:34 AM
    #2405
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I just about freaked out I was like WTF Angelo
    I read this 6.5"
    not quanity 6 ........... 1/2 inch holes
  6. Sep 14, 2018 at 10:37 AM
    #2406
    roguegs
    Angelo
    V8 T4R
    Lol would it be out of line to say I almost resorted in using one of those because I couldn’t find my 1/2 inch bit
  7. Sep 14, 2018 at 10:37 AM
    #2407
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    DO IT!!!!!!!
  8. Sep 14, 2018 at 10:39 AM
    #2408
    roguegs
    Angelo
    V8 T4R
    At least the holes are already drilled...
  9. Sep 14, 2018 at 11:02 AM
    #2409
    Justintheegreat
    Justintheegreat Well-Known Member
    Northern CA
    06 DCSB Sport
    Anyone know how to take this cap off for the fuel pump??
  10. Sep 14, 2018 at 11:05 AM
    #2410
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    2 man job
    push the tabs in and turn like hell
  11. Sep 14, 2018 at 11:08 AM
    #2411
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    if you have a cold chisel with a wide tip you could use that to tap it in a circular motion, just don't do too much on one particular tooth or you could sheer them off
    Anderson likes this.
  12. Sep 14, 2018 at 11:53 AM
    #2412
    roguegs
    Angelo
    V8 T4R
  13. Sep 14, 2018 at 12:02 PM
    #2413
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I used the “belt” method of constant tension on the outside of the flange while slowly pulling on the belt and pushing the tabs in as I went. Solo.
  14. Sep 14, 2018 at 1:08 PM
    #2414
    Justintheegreat
    Northern CA
    06 DCSB Sport
    Yup just got a big flat tip chisel and tapped it loose with a mallet.
    It came off.
    Thanks fellas.
  15. Sep 14, 2018 at 7:54 PM
    #2415
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    nDub and Pella like this.
  16. Sep 14, 2018 at 9:07 PM
    #2416
    roguegs
    Angelo
    V8 T4R
    Well then it’s fucking IN. Drivers side sagging about 1/4 inch.
  17. Sep 14, 2018 at 9:44 PM
    #2417
    Papadave418
    Papadave418 Well-Known Member
  18. Sep 14, 2018 at 9:49 PM
    #2418
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
  19. Sep 14, 2018 at 9:51 PM
    #2419
    roguegs
    Angelo
    V8 T4R
    Only if I’m aquaman
  20. Sep 14, 2018 at 10:51 PM
    #2420
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Is that 100% installed?
