209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Oct 25, 2018 at 8:05 PM
    #2921
    Papadave418
    Papadave418 Well-Known Member
    Somewhere out there, a rock has been waiting 100,000,000 years for some slider love
  2. Oct 25, 2018 at 10:21 PM
    #2922
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    What are we looking at? lol. Anyway looks good, ready for that RTT :)
  3. Oct 26, 2018 at 5:59 AM
    #2923
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    New sliders.
    Papadave418 likes this.
  4. Oct 28, 2018 at 9:42 PM
    #2924
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
  5. Oct 29, 2018 at 7:32 PM
    #2925
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  6. Oct 29, 2018 at 10:30 PM
    #2926
    roguegs
    Angelo
    V8 T4R
    Hate autocorrect bullshit
  7. Oct 31, 2018 at 8:59 AM
    #2927
    Sharkfrog
    Cameron
    Modesto, CA
    So the time has come for me to start doing my own maintenance and I'm going to attempt my first oil change ever. I've watched a couple videos and think I've got the process down more or less. Do you guys do anything special during oil changes? Any tips or tricks to share for a first timer?
  8. Oct 31, 2018 at 9:12 AM
    #2928
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    Fresh crush washers? Other than that same shit ive been doing since high school. Get er warm, drain and fill. I have considered some sea foam or something, but ive only changed the oil once on my taco (ive owned it for 13 months, put 3500miles on it lol)
    My work truck gets fresh oil every month
    Sharkfrog[QUOTED] likes this.
  9. Oct 31, 2018 at 9:20 AM
    #2929
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    It's easy peasy brother. Just dump the oil change the filter and refill actually.
    I remove the drain plug and let the oil drain completely and put the plug back in before I move on to anything else... to avoid forgetting to put the plug back in.
    Then I remove and replace the oil filter. (not sure how your filter is located, I'll let a fellow 2nd genner chime in if there are any secrets to get to it.
    I have a high milage engine so I use Mobile 1 high milage synthetic and use Lucas Oil Stabilizer. You may not need "high milage" specifically, but I always recommend Mobil 1 oil.
    I like using K&N oil filters because you can get a wrench on them. I've never had any luck with the stupid strap filter wrenches. (Remember... oil filter wrenches are for getting the filter OFF... You should not need a wrench to tighten the filter on... just get it as tight as you can with your hand... and lube the filter gasket with fresh oil before you put it on, it helps you get the filter tighter by hand.)
    And again, I'll let a 2nd genner chime in on this if it applies. The plug in the oil pan should be under the engine (it shouldn't be that far back)... I've seen a couple guys lately (in these forums) drain their transmission thinking they are draining their engine. -- but I think thise were 1st genners.
  10. Oct 31, 2018 at 9:34 AM
    #2930
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Does your skids have a hole in it below the drain? Maybe get a fumoto valve to make future oil changes easier by not having to remove it...
  11. Oct 31, 2018 at 9:39 AM
    #2931
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  12. Oct 31, 2018 at 9:40 AM
    #2932
    Sharkfrog
    Cameron
    Modesto, CA
    It does but they aren't on the truck yet, still haven't even painted them. I saw those in one of the video's I watched. Will those valves stick out past my skid plate once it's on? I hate to catch that thing on a rock or something.
  13. Oct 31, 2018 at 9:41 AM
    #2933
    roguegs
    Angelo
    V8 T4R
    CalTacoma09 likes this.
  14. Oct 31, 2018 at 9:41 AM
    #2934
    Sharkfrog
    Cameron
    Modesto, CA
  15. Oct 31, 2018 at 9:45 AM
    #2935
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Damn... that dude is fucked up like a soup sandwhich... Can't figure out the right drain plug, then posts about it in the wrong generation forum
    :facepalm:
    Probably shouldn't even own a truck.
    Taco-Rado Girl and CalTacoma09 like this.
  16. Oct 31, 2018 at 9:52 AM
    #2936
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    No it won’t stick past the skid, get the one with the short nipple.
  17. Oct 31, 2018 at 10:42 AM
    #2937
    roguegs
    Angelo
    V8 T4R
    How big of an areola?
  18. Oct 31, 2018 at 10:42 AM
    #2938
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Butter plate size
  19. Oct 31, 2018 at 10:43 AM
    #2939
    roguegs
    Angelo
    V8 T4R
    We talkin Nat Geo size?
  20. Oct 31, 2018 at 10:46 AM
    #2940
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Actual size may vary...
