209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Feb 2, 2019 at 7:40 AM
    #3781
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2005 DCLB 2001 Reg cab 4x4
    Dirt
    Grade 8 w loctite
    Factory bolts for those are usually considered a 1time use with a bolt that allows some stretch which creates its own friction to hold it in place, and since the way they mount together doesn’t need any give in a hardened bolt like a grade 8 should be fine
    Pickeledpigsfeet likes this.
  2. Feb 2, 2019 at 9:15 AM
    #3782
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
  3. Feb 2, 2019 at 9:40 AM
    #3783
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red 02 TRD Tacoma Prerunner "now it's 4x4 muthafukas" DC 5vz-fe
    Swapped 4x4, Twin sticks, Tundra Brakes, FOX Resi, AllPro leafs, Pro-Comp 17x8.5, Transgo shift kit, Dual batteries
    Any of you local guys know of a steel yard that's open today?
    Every one I've looked up so far is closed on weekends.
    Taco-Rado Girl likes this.
  4. Feb 2, 2019 at 10:15 AM
    #3784
    CalTacoma09
    Manteca, CA
    Nope, but I haven’t really looked. :anonymous:
  5. Feb 2, 2019 at 10:16 AM
    #3785
    CalTacoma09
    Manteca, CA
    Alco Iron & Metals In Stockton.
  6. Feb 2, 2019 at 10:18 AM
    #3786
    CalTacoma09
    Manteca, CA
  7. Feb 2, 2019 at 10:24 AM
    #3787
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  8. Feb 2, 2019 at 7:26 PM
    #3788
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Taco-Rado Girl, Papadave418 and Pella like this.
  9. Feb 2, 2019 at 7:27 PM
    #3789
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Aaaaaand Matt just picked up another project
    :anonymous:
    @foxrcing07 is seeing this and thinking what kind of stupid questions is this dumb fucker gonna be asking me now? lol
  10. Feb 2, 2019 at 7:53 PM
    #3790
    Anderson
    Anderson Flatbeds everywhere...
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Just an FYI about transmission filters on our autoboxes; they don’t need to be “replaced”, just cleaned. Our slushomatics have a metal mesh filter screen that only needs to be cleaned and refitted.
  11. Feb 2, 2019 at 8:04 PM
    #3791
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I would definitely consider just cleaning the filter under normal circumstances, but this being a salvage yard trans and I don't know the history or maintenance, I'm going to replace with a Wix filter for piece of mind.
    Taco-Rado Girl and CalTacoma09 like this.
  12. Feb 2, 2019 at 8:31 PM
    #3792
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Umm, I don’t follow the logic.
    It doesn’t matter where the trans came from.
    1. Remove filter from valve body via unbolting it.
    2. Disassemble filter body.
    3. Clean filter components thoroughly, very thoroughly. “I can refer you to a doctor, he’s thorough. Very thorough.”
    4. Reassemble filter body.
    5. Reattach filter assembly to valve body via bolts.
    But, since you have already replace the assembly with a Wix filter(they make robust filters), please keep and clean your factory one when you need to replace the Wix unit. This way you are covered, should anything negative happen to your Wix unit(like cavitation).
  13. Feb 2, 2019 at 10:38 PM
    #3793
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I’ll beat you to the ask
    Synthetic not steel
    Twizted and CalTacoma09 like this.
  14. Feb 2, 2019 at 10:50 PM
    #3794
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Already planning on that... I listen to you when you talk about things. I filed that away last time we were talking about winches.
    The ask was going to be... I don't have any experience with choosing winch line. Don't know brands, qualities, etc.
    I'm not wanting to "cheap out" on winch line, but I also am hoping not to spend $300 on 50 ft of it lol.
  15. Feb 3, 2019 at 6:20 AM
    #3795
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    :popcorn:
    I have the same question. I’d like to replace my steel wire with synthetic but I can’t tell what’s any good.
    El Taco Diablo [OP] likes this.
  16. Feb 3, 2019 at 8:05 AM
    #3796
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I don’t know a whole lot about winch lines,
    I do know that they have some that have a sheath and I don’t believe those can be spliced
    My next winch line I plan to find an Amazon one with the best reviews
    If I had money I would probably get a warn or bubba rope line but that’s out of my price range currently
    The bottom is an example of the sheathing
  17. Feb 3, 2019 at 10:06 AM
    #3797
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  18. Feb 3, 2019 at 10:31 AM
    #3798
    CalTacoma09
    Manteca, CA
    Anderson and El Taco Diablo [OP] like this.
  19. Feb 3, 2019 at 10:37 AM
    #3799
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Doesn't that one have sheathing?
  20. Feb 3, 2019 at 11:39 AM
    #3800
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Anyone from the 209 headed to San Jose for any reason?
    Or any of our friends from San Jose headed toward 209 for any reason?
