209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Jun 3, 2019 at 11:14 AM
    #5301
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    It's all pretty much fire roads. I don't see why a stock 4wd Tacoma couldn't make it. If you run in to problems, I have a winch, tow straps, shovel, traction boards, axe, MREs, a flashlight... well, you get the picture.
  2. Jun 3, 2019 at 11:17 AM
    #5302
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
  3. Jun 3, 2019 at 11:31 AM
    #5303
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Kenwood (@Twizted has a much fancier version... but I like mine)
    Taco-Rado Girl likes this.
  4. Jun 3, 2019 at 11:32 AM
    #5304
    Sharkfrog
    Cameron
    Modesto, CA
    Yeah thats what he said. His can do some pretty rad stuff but I want to start looking at what all the different versions can do.
  5. Jun 3, 2019 at 11:42 AM
    #5305
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Question for the 2nd Genners with camper shells. @Hookgrip is trying to decide on leaf springs. Which would you guys suggest between the the 96R (Heavy Duty) and the 95R (Regular Duty).
    I'm telling him the 96R because I believe that's pretty much what everyone runs that has a shell and has a load out for camping... But I don't have a second gen, or a shell.
    @foxrcing07, @Motofox, @Sharkfrog
    @anyone-else-that-may-want-to-weigh-in-on-this
  6. Jun 3, 2019 at 11:47 AM
    #5306
    Blue Canary
    Blue Canary Not responsible for any earthquakes
    Larry
    Stockton
    2015 MGM DCSB
    Pinstripes, dings, and dust.
    Since I missed out on the camping shenanigans last weekend, I'm down for a drive in the woods.
    The stock truck is plenty capable and having good spotters makes it easy. If it's fire roads with the occasional obstacle, you should be fine.
  7. Jun 3, 2019 at 11:48 AM
    #5307
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Main thing I was looking for was Android Auto.
  8. Jun 3, 2019 at 11:56 AM
    #5308
    Sharkfrog
    Cameron
    Modesto, CA
    He'd probably be ok with the standards but once you start loading out for camping or hauling anything besides just the shell the Heavy duties are going to be nice.
  9. Jun 3, 2019 at 12:03 PM
    #5309
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Figure out which shell first. They can very from 200-500 pounds empty. That will tell you what he would need.
  10. Jun 3, 2019 at 12:13 PM
    #5310
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    So, i went with the HDs for future proofing. The ride is fine, not rough in my opinion. I have a shell and typically no other heavy gear when im driving around town (axe/shovel and my typical automotive/emergency supplies are always there of course).
    I do think the mediums would have been just fine for unloaded w/ shell, as the heavys with only a shell has lifted the rear alot and i find myself wanting more lift up front. Whereas the mediums would have probably settled/sagged down to 2.5" of lift and kept my truck more level/less rake.
    But i do typically bring alotta gear as i like to camp for weeks at a time. Plus i wanted to future proof for a RTT setup or drifter (or even FWC). So i went with the heavy duty pack and have been happy with it. Handled my recent road trip loaded to the roof with gear, took a few unintentional jumps like a champ aswell lol
    I think if 90% of your driving is unloaded, then the mediums would probably be the way to go. They say "330lbs of constant weight" and i know most shells are like 150-200lbs. You can always add a leaf down the road if you start adding more weight or notice excessive sagging when you load up for camping but i bet theyd be fine.
    I should also add that I plan on doing a rear high clearance bumper with the swing out. So since I knew I was just going to keep adding weight it helped me make the decision for the heavy duty Leafs
  11. Jun 3, 2019 at 12:47 PM
    #5311
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    I have the old standard Dakars but I am going to probably have a custom pack made
  12. Jun 3, 2019 at 2:06 PM
    #5312
    Papadave418
    Papadave418 Well-Known Member
    Edit: I can do Sunday all day, Saturday I’ve got a commitment starting at 5pm
    How long would it take?
  13. Jun 3, 2019 at 2:28 PM
    #5313
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I don’t have any reference to the part numbers you are posting. However, I’ve had a few different rear leaf spring setups now for different shell setups as well.
    If it’s just an unloaded bed with a shell, well then, I suggest a Deaver U402 stage 1.
    If it’s a lightly loaded bed and an RTT, I would suggest the Deaver U402 Stage 2.
    If it’s same as above but with rear swingout and armor I would suggest the Deaver Stage 3.
    If it’s a bed build out with RTT, full recovery gear, water storage, fuel storage, rear swingout bumper... Deaver Custom pack.
    I’ve had Icon AAL’s that flattened out within two weeks of a camper shell with a toolbox filled with stuff.
    Then I swapped to AllPro Expo springs with the RTT. Those were fine till I did the rear swingout.
    I’m now on Custom Deaver Springs. But, my setup has gotten complicated.
    But that’s just my experiences. YMMV.
  14. Jun 3, 2019 at 3:36 PM
    #5314
    Hookgrip
    Hookgrip Member
    2017 TRD Off Road
    Camper is a SnugTop Rebel with sportsmans package. Found another thread on TW which snugtop quoted weight as 240.
    Pella[QUOTED] likes this.
  15. Jun 3, 2019 at 3:44 PM
    #5315
    Hookgrip
    Hookgrip Member
    2017 TRD Off Road
    Sounds like the 96Rs it is then.
    Ballpark estimate of my load comes to roughly 750lbs. For some context, will essentially be living out of the truck from July-Nov.
  16. Jun 3, 2019 at 3:56 PM
    #5316
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    The Rebel is the same topper that I just got my quote on. It is 240 lbs bone stock. The dealer I talked to last week said loaded with the sportsman package total weight is close to 500 lbs. the shell is 1” thicker than normal. Again, this is what the dealer said.
    Edit, I think the Dakar HD would be the way to go. I think 2-2.5” with 600lbs is what I believe it’s rated at. I have the Dakar med duty which is 2-2.5” with zero weight in the bed. I will be adding the HD leaf to mine.
    Hookgrip[QUOTED] likes this.
  17. Jun 3, 2019 at 4:10 PM
    #5317
    Hookgrip
    Hookgrip Member
    2017 TRD Off Road
    Looks like we may as well call Snugtop and clear this up. The thread I found the answer on stated 240lbs with the sportsmans package.
    https://www.tacomaworld.com/threads/snug-top-rebel-question.462420/
    Regardless, just pulled the trigger on the HD 96Rs from Wheeler's
  18. Jun 3, 2019 at 4:24 PM
    #5318
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    I just called the same place that told me 500. He just said with sportsman package, it’s close to 250lbs. My bad, I had thought 500 seemed excessive but wtf do I know?
    El Taco Diablo[OP] likes this.
  19. Jun 3, 2019 at 6:13 PM
    #5319
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    How long is really hard to tell... especially with roads just now opening up. @Pella and I had to re-route a few times, on saturday, due to road closures and such. Also depends on how often we stop etc.
    Taco-Rado Girl and Pella like this.
  20. Jun 3, 2019 at 6:17 PM
    #5320
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    BUT... we'd be in a whole network of roads. National Forest roads 14, 17, and 31 run through where we will be and you could take those back to 108 or 120 in a relative easy amount of time.
    Edit.... I just fucking quoted myself didn't I?
    Taco-Rado Girl, CalTacoma09 and nDub like this.
