209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Mar 22, 2018 at 10:35 AM
    #521
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    @CalTacoma09 I finally got a nitrogen tank, so I'm piecing that together now
    are your shocks schrader or the needle?
  2. Mar 22, 2018 at 10:45 AM
    #522
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Is he getting coilovers? I must have missed where it said what he was putting on in the front. I was assuming he was going with struts.
    Taco-Rado Girl likes this.
  3. Mar 22, 2018 at 10:47 AM
    #523
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    fox 2.5 I think is what I saw
    @Sharkfrog isn't that what you got?
    also did you get a U-bolt flip kit?
  4. Mar 22, 2018 at 10:56 AM
    #524
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    This is everything included with the kit that I should be getting:
    Fox 2.5" Extended Travel Coilover with Reservoir and Compression Adjusters for 2005+ Toyota Tacoma 0"-3" Lift
    Fox 2.0 Rear shock for 3.5-5" rear lift with reservoir and compression adjuster for 05+ Tacoma
    OME Dakar Heavy Duty Leaf Pack for 2005+ Toyota Tacoma
    OME U-bolts
    05+ Tacoma Leaf Spring and Shackle Bushing Kit
    OME Driveshaft Spacer for 05+ Toyota Tacoma
    24" Brake Lines 24" Steel Braided Extended Rear Brake Lines for 05+ Toyota Tacoma - Coated
    Light Racing Upper Control Arms for 05+ Toyota Tacoma
    Let me know if there is anything else I need and I'll get it ordered ASAP.
  5. Mar 22, 2018 at 10:59 AM
    #525
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    might want to consider doing the ECGS bushing while everything is apart...if you haven't done it already.
  6. Mar 22, 2018 at 11:12 AM
    #526
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    i have the ecgs tool too
    TOP TACO likes this.
  7. Mar 22, 2018 at 11:18 AM
    #527
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    My needle bearing started to go about 1,000 miles after I installed my lift.:facepalm:
  8. Mar 22, 2018 at 11:18 AM
    #528
    Sharkfrog
    Cameron
    Modesto, CA
  9. Mar 22, 2018 at 11:22 AM
    #529
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
  10. Mar 22, 2018 at 11:31 AM
    #530
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    schrader
  11. Mar 22, 2018 at 11:33 AM
    #531
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    well if I don't spend my money on other shiny things I should have the recharge kit done in the next week
  12. Mar 22, 2018 at 11:44 AM
    #532
    CalTacoma09
    Manteca, CA
    Man, I need to order these.
  13. Mar 22, 2018 at 11:53 AM
    #533
    CalTacoma09
    Manteca, CA
    wow, I would love to be able to rebuild on my own instead of spending 300 for someone else to do it.
  14. Mar 22, 2018 at 12:04 PM
    #534
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    That's my goal, the sway-a-ways were pretty easy, but they didn't have remote reservoirs, so when I do my ICONS i'll cross that bridge
    CalTacoma09[QUOTED] likes this.
  15. Mar 22, 2018 at 12:39 PM
    #535
    CalTacoma09
    Manteca, CA
    I would be interested in the process so I’m aware of what I would be getting myself into when I need to do this as well. Also I would be more than happy to get the tank charged with nitrogen if and when I would want to try and tackle this process.
    FirstTimeFirstGen likes this.
  16. Mar 22, 2018 at 12:42 PM
    #536
    CalTacoma09
    Manteca, CA
    Right now I’m just waiting for the skies to clear up a little to do my winch install. I’m wanting to get it installed before I head to Oregon in early April. Well, I need my hawse to show up as well. I decided to change out the wire for synthetic rope right from the gates.
  17. Mar 22, 2018 at 12:42 PM
    #537
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Watch this, unbelievably easy for the sway a ways
    https://youtu.be/XsACjUE9awE
  18. Mar 22, 2018 at 1:53 PM
    #538
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  19. Mar 22, 2018 at 5:26 PM
    #539
    Sharkfrog
    Cameron
    Modesto, CA
    Tires ended up coming today, and wheels tomorrow.
  20. Mar 22, 2018 at 5:31 PM
    #540
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Are you going to have them balance or run beads?
