209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Jun 22, 2019 at 11:06 PM
    #5541
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    More questions... lol
    Will the Auto Trans in a 93 T4R bolt up to a 5vz-fe? I think the 93 would have an A340H the 5vz-fe would be paired with an A340F (in 4x application) not sure if the bellhousings are the same.
    Also, what is a good donor for a Solid axle swap? Not even sure where/what I'd be looking for.
  2. Jun 23, 2019 at 8:01 AM
    #5542
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    https://www.offroadsolutions.com/tech-info/3-4l-5vz-fe-conversion/#automatic_transmission
    As far as axle, it all depends on what tcase you use. Pre tacoma tcase works perfect with 79-85 toyota front axle, 95+ you would need danas. You can buy adapters to mount older tcases to newer trans. I prefer toyota front axles as you can make all the internals strong enough to run 40s reliably. They are narrower than ifs rears but you just run spacers up front. If you want to spend some more money but stick with toyota internals you can run Ruffstuff,TG, or Diamond housings with custom length axle shafts.
    You can also find danas with either side drop, but you are going to be cutting them down which can add some work.
    I run pre 95 v6 thirds front and rear. Then if I blow a rear I can swap the front in and still drive back home or to the trailer.
    nDub and Drtgrl like this.
  3. Jun 23, 2019 at 8:06 AM
    #5543
    Pickeledpigsfeet
    Foothills, CA
    As far as donor parts, all you need is a complete front axle. You will then have to buy steering, springs, shocks, shock towers, hangers, brake lines, and a ton of cutoff/grinding wheels and a welder.
    Build a sq tube front shaft to save some money.
    Then you will need longfields, cryod hub gears, trunnion eliminator, hub studs, and a few other small things to run 35s and never have a breakage in the front end.
  4. Jun 23, 2019 at 6:47 PM
    #5544
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Just saw you guys coming down 108.
    I was headed back from the bay.
    Saw you this morning but was in a rush to get my wife to the airport so I didn’t swing in at the Raileys.
    Pella likes this.
  5. Jun 23, 2019 at 7:02 PM
    #5545
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    Goodbye shell!
  6. Jun 23, 2019 at 7:30 PM
    #5546
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Awesome dude! It's only for a month or so.
    Twizted and rob1208 like this.
  7. Jun 23, 2019 at 8:25 PM
    #5547
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    Congrats Cameron. :thumbsup:
  8. Jun 23, 2019 at 8:33 PM
    #5548
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Never mind the badass green truck behind his
    :pout:
  9. Jun 23, 2019 at 8:34 PM
    #5549
    CalTacoma09
    Manteca, CA
    Nice, that thing supercharged now?
  10. Jun 23, 2019 at 8:36 PM
    #5550
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Yea, but it seems to be running lean
    I need a air fuel ratio gauge and boost gauge to start figuring out tuning
    CalTacoma09[QUOTED] likes this.
  11. Jun 23, 2019 at 8:42 PM
    #5551
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Another epic day in Stanislaus National Forest with @Pella and @Papadave418 :thumbsup:
    Clavey River Bridge
    Then we headed to the spot @CalTacoma09 @Sharkfrog @rob1208 and I decided not to go to last weekend. (Where we talked to that couple on the ATV)... He was right... absolutely not getting across with the river where it is. But found an OUTSTANDING place to camp... and a cool trail to run to get there. (no way I'm calling it a road).
    Then on towards Bourland Meadows.
    Made it within less than a mile to Bourland Meadows... But a large tree and snow drifts kept us out.
    So we headed to Bourland Tressel
    And then headed back to the rat race.
    TacoYea_88, Pella, TOP TACO and 3 others like this.
  12. Jun 23, 2019 at 9:05 PM
    #5552
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The place we found today, down by the river, would make an awesome spot for a TW camping trip. I bet we could fit 10 or more trucks in the clearing by the river. The road down to it is pretty fun too. :thumbsup:
  13. Jun 23, 2019 at 9:24 PM
    #5553
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I’m in
  14. Jun 23, 2019 at 9:34 PM
    #5554
    Sharkfrog
    Cameron
    Modesto, CA
    Me too
  15. Jun 23, 2019 at 9:52 PM
    #5555
    Blue Canary
    Blue Canary Not responsible for any earthquakes
    Larry
    Stockton
    2015 MGM DCSB
    Pinstripes, dings, and dust.
  16. Jun 23, 2019 at 9:57 PM
    #5556
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I could be convinced
  17. Jun 24, 2019 at 5:53 AM
    #5557
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
  18. Jun 24, 2019 at 11:38 AM
    #5558
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Taco’s in their natural habitat. It was great to see them in the wild. It’s amazing that this rarity be captured on film.
  19. Jun 24, 2019 at 11:43 AM
    #5559
    Papadave418
    Papadave418 Well-Known Member
    Lots of fun guys, glad to finally get to the trestle 1608C163-083B-4887-A671-B00CA7803240.jpg
  20. Jun 24, 2019 at 11:56 AM
    #5560
    Pickeledpigsfeet
    Foothills, CA
    I have pics of the trestle when you could still walk across it in the 80s. I will see if I can dig them up. My Grandpa lived in a camp there with the other loggers back in the olden days.
