209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Mar 22, 2018 at 5:36 PM
    #541
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    LOL, I've never even heard of beads until just now. Had to look it up. so, probably balanced.
  2. Mar 23, 2018 at 5:41 AM
    #542
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Beads don't help with balance til about 40 mph. They don't work too well at slow speeds.
    foxrcing07 likes this.
  3. Mar 23, 2018 at 9:39 AM
    #543
    Sharkfrog
    Cameron
    Modesto, CA
    @TOP TACO @foxrcing07
    Should I order the Axle seal with the ECGS Bushing? Also is the U-bolt flip kit something that I should be looking at?
    Edit: Also also am I going to need to replace the factory bumpstops?
  4. Mar 23, 2018 at 9:54 AM
    #544
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Get the seal just in case it gets damaged upon removal. I was able to re-use mine. But its recommended to replace it.
  5. Mar 23, 2018 at 10:00 AM
    #545
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Haven't done the flip kit yet, so cant speak to it. I think you have to replace the rear bump stops if you do flip...the fronts I believe should be fine with your lift...Can someone else confirm? never dealt with FOX personally
  6. Mar 23, 2018 at 10:02 AM
    #546
    Sharkfrog
    Cameron
    Modesto, CA
    Ok ECGS bushing ordered.
    I was looking at this:
    TOP TACO likes this.
  7. Mar 23, 2018 at 10:04 AM
    #547
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Fuck it! Might as well while everything is apart.
  8. Mar 23, 2018 at 10:14 AM
    #548
    Sharkfrog
    Cameron
    Modesto, CA
    It's only money right?
    TOP TACO[QUOTED] likes this.
  9. Mar 23, 2018 at 10:15 AM
    #549
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Can't take it with you when you kick the bucket!
  10. Mar 23, 2018 at 10:40 AM
    #550
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    I did the U-bolt flip, just helps with ground clearance :notsure:
    but... it's also easy to do down the road later no jack or anything special required to install
  11. Mar 23, 2018 at 11:04 AM
    #551
    Sharkfrog
    Cameron
    Modesto, CA
    I've been screwing around with this the last couple days. I'm trying to convert and old soda keg into a shower/pressurized water supply for camping. I plati dipped it yesterday and rigged up a schrader valve with hose clamps to the gas in line so I can pressurize it with a bike pump. Running a test today to see how hot it gets in the sun. So far the water went in at 8:50 and 52 degrees from the hose. Last check at 10:50 it was 67 degrees. Still trying to figure out what to do with the output valve as the water flow leaves a lot to be desired.
  12. Mar 23, 2018 at 11:06 AM
    #552
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    You will never get good flow. The dip tube in a corny keg is too small.
    Sharkfrog[QUOTED] likes this.
  13. Mar 23, 2018 at 11:09 AM
    #553
    Sharkfrog
    Cameron
    Modesto, CA
    I was thinking of replacing the whole valve and dip tube with something a little more robust.
  14. Mar 23, 2018 at 11:25 AM
    #554
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    Looking like Sunday might be my best chance to get the winch installed.
    Bumps are only required if you do the ubolt flip, you run stock bumps if needed. The ubolt flip is not really needed unless you want more clearance at the ubolt location on the axle.
    Edit: they are nice since stock blows ass.
  15. Mar 23, 2018 at 7:00 PM
    #555
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I’ll trade you a 1/2 barrel keg for that corney keg. Might get better flow? Also 15 gallons :anonymous:
  16. Mar 24, 2018 at 7:20 AM
    #556
    Sharkfrog
    Cameron
    Modesto, CA
    Thanks, but I have a few already. I thought about using one, but they are just too big to lug around. I have two 10 gallon corny's as well but those are too precious to use for something like this. Like 10 years ago or so I bought an older guys entire home brewing set up, got an amazing 3 keggle stand that he had built him self with a built in counterflow chiller and water filter, 15 or so 5 gallon corny's, 2 10 gallon corny's, 3 half barrels that he had used for fermenting a load of regulators and all kinds of misc. equipment. I moved a few times to places I couldn't bring it with me so it sat in storage, and then when I finally got a place where I could use it I had to take some medication that I couldn't drink while I was on :(.
  17. Mar 24, 2018 at 7:21 AM
    #557
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    I have been thinking about modifying a corny keg as well. We shall see. Basically indestructible. I thought about drilling a lid and adding a straight 3/8" downtube.
  18. Mar 24, 2018 at 9:39 AM
    #558
    nDub
    Lead Free Gasoline
    So do you still have all that stuff? Sounds like a pretty good set up.
    I’m finally moving out of my tiny house to a bigger place and I want to start expanding a little on my Homebrew set up. I currently do BIAB and now I want to build an electric RIM system for it. Should be and fun project.
  19. Mar 24, 2018 at 10:07 AM
    #559
    Sharkfrog
    Cameron
    Modesto, CA
    Most of it yeah, I think I may have lost a box of parts in a move but nothing too expensive. I really need to get it cleaned up and back in working order.
    Heres the brew stand before the last time it got moved.
  20. Mar 24, 2018 at 2:02 PM
    #560
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Just finished charging my sway-a-ways
    @CalTacoma09 setup is functional
    The tank was from an AC contractor even came with 1000PSI
