209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Sep 14, 2020 at 11:31 AM
    #8281
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Same kind? You can probably pick up a nice 2 lung OHV Kohler motor.
  2. Sep 14, 2020 at 11:38 AM
    #8282
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Yea the space that the motor fits into is not very accommodating for motors, and the vanguard V-twin fits very snug, some people have notched the side to accommodate other motors, but I don't want to put any extra holes into something that is designed to swim
    https://youtu.be/S_RgN2pyPos?t=17
    Taco-Obsessed, Twizted, nDub and 2 others like this.
  3. Sep 14, 2020 at 5:27 PM
    #8283
    thatrafael23
    thatrafael23 Active Member
    Rafael
    Bay Area, California
    18’ Quicksand Taco
    Bilstein 5100's with 887 OME coils, JBA High Caster UCA, Method NV 16”
    Been a few months since I last signed onto TW but pick up my BAMF sliders last week and installed them today!
  4. Sep 14, 2020 at 6:01 PM
    #8284
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :thumbsup:
    thatrafael23[QUOTED] likes this.
  5. Sep 14, 2020 at 11:09 PM
    #8285
    Taco-Obsessed
    Your product looks great. Good luck with the business.
  6. Sep 15, 2020 at 7:36 AM
    #8286
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    Not eager to repeat your uncles mistakes?
    Blue Canary likes this.
  7. Sep 18, 2020 at 4:35 PM
    #8287
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Idk why but I’m excited AF to get my Baja Designs in and switch panel...
    Papadave418 likes this.
  8. Sep 18, 2020 at 4:36 PM
    #8288
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    What switch panel did you go with?
  9. Sep 18, 2020 at 4:54 PM
    #8289
    roguegs
    Angelo
    V8 T4R
  10. Sep 19, 2020 at 8:41 PM
    #8290
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Plan change.
    I'm f'n spent. We're cutting the trip short. Going to route change to a direct route down 25 to Albuquerque and across 40.
    Nothing bad happening... this has just been a lot more taxing than I thought it would be.
    This will cut return trip down from 3 days to 2 days.
  11. Sep 20, 2020 at 9:33 PM
    #8291
    Papadave418
    Papadave418 Well-Known Member
    Kelly and I jetted up to Usal Beach and Road. One of the few places not on fire and blue skies. Camped for the weekend without cell service. So nice! And she spoiled me with amazing camp food!
    181032D0-E53F-4151-863F-A3D80C366E6B.jpg F272E2FB-322C-4515-B1BC-85CB3C49D328.jpg AF121ED9-BC79-4BC3-9488-15B6E9429420.jpg 6AA419B3-5A76-4833-928C-FE6C4C2D5267.jpg A01E1CEA-73DC-4B5D-82BC-03C14DA32650.jpg
  12. Sep 21, 2020 at 12:45 AM
    #8292
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Officially... the cheesiest, most tourist trappy photo I have ever taken on a road trip :thumbsup:
  13. Sep 23, 2020 at 3:41 PM
    #8293
    roguegs
    Angelo
    V8 T4R
    Switch panel is installed! Took a little longer than anticipated thanks to my chatty neighbor who decided to come out and talk to me for an hour.
    kit does not come with a tap fuse/add a fuse so you have to source your own but fortunately I had one from my old dash cam kit.
    have some BD S1s going up on my ditch light brackets but the bolt is tiny that came with it so gonna have to either drill a new hole on the bracket or get extra washers
  14. Sep 24, 2020 at 6:30 PM
    #8294
    roguegs
    Angelo
    V8 T4R
    BD S1s are on!! Instead of drilling into the ditch brackets, ended up getting a 1/4” ID plastic spaced washer and put it in the ditch light bracket hole to eliminate the bolt moving around. Had to grind off a bit of the plastic to make it fit snug but the figment is PERF. gonna test the lights out later but it’s all wired up to the switch panel too!
    TheLastLatin likes this.
  15. Sep 25, 2020 at 5:18 PM
    #8295
    roguegs
    Angelo
    V8 T4R
    OME 861s, 4th Gen T4R billies, Durobumps bumpstops front and rear installed!!! Removed rear sway bar.
    glad to have some wheel gap after adding all the armor.
    didn’t have time to install the PCK but the panhard angle doesn’t look too bad.
    height difference between my pop’s 5th gen
  16. Sep 26, 2020 at 4:52 PM
    #8296
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Mail call!
    Thought this would be a good way to keep track of what States we've hit.
  17. Sep 26, 2020 at 5:05 PM
    #8297
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I run 861's. Your panhard is most certainly at a bad angle. From the factory they are level at ride height. The PCK will return you to that and keep your ass end from hopping all over the place on washboards. Just weld it up.
    I also run no sway bars. The 861's handle cornering well enough that I hardly ever even notice it's gone.
    MattJakobs and TheLastLatin like this.
  18. Sep 26, 2020 at 5:39 PM
    #8298
    LINCOLN45
    LINCOLN45 Well-Known Member
    john
    sac
    2014 TACOMA DCSB
    265/70/17 TOYO OC AT Bilstein 6112 Coil and Strut Combo Tacoma Stealth 32" LED SOS SKID PLATES AND SLIDERS RIGID LED FOG LIGHT UPGRADE
    states driven through?
    visited/been drunk in?
  19. Sep 26, 2020 at 7:31 PM
    #8299
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Driven through / Visited... specifically in El Taco Diablo.
    I've been in (somewhere around) 43 States.
    siznarf and TheLastLatin like this.
  20. Sep 26, 2020 at 8:06 PM
    #8300
    roguegs
    Angelo
    V8 T4R
    I actually have an adjustable panhard on there probably should have mentioned that!
