209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Oct 13, 2021 at 12:27 PM
    #9781
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    And I picked up another project for the truck.
    Going to set this in place of my M8000 and mount the M8000 in the back.
    rob1208, CalTacoma09, nDub and 3 others like this.
  2. Oct 14, 2021 at 9:50 AM
    #9782
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    So... does anyone want to help me work on a Chevy this weekend?
    Need to get Jen's truck back together so I can start tearing mine apart.
    List of shit to do on Jen's truck is:
    Re-install oil pan
    Re-install diff intermediate shaft
    re-install starter
    Install new CVs
    Install new Pitman arm, Idler arm, Idler arm bracket
    Re-install sway bar
    Re-install and adjust torsion bars
    Torque lower control arms
    Adjust and torque adjustable Upper Control arms
    Reinstall spindles and calipers
    Replace valve cover gaskets
    Replace spark plugs
    Fill oil
    Reconnect battery
    Reprogram performance chip
  3. Oct 14, 2021 at 10:46 AM
    #9783
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    At a wedding this weekend. Sorry, Matt.
  4. Oct 14, 2021 at 11:39 AM
    #9784
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Oh... I forgot... Need to install new inner and outer tie rods and re-install the steering stabilizer too :frusty:
  5. Oct 16, 2021 at 6:56 PM
    #9785
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    20211003_132604.jpg 20211003_163801.jpg 20211003_181531.jpg 20211016_114710.jpg 20211016_140541.jpg 20211016_154821.jpg 20211016_182721.jpg
    Re-install oil pan
    Re-install starter
    Install new CVs
    Re-install center link
    Re-install steering stabilizer
    Install new inner and outer tie rods
    Re-install sway bar
    Replace spark plugs
    Fill oil
    Reconnect battery
    Got a few things done on Jen's truck today. Still have a bit of a list for tomorrow.
    :frusty:
  6. Oct 16, 2021 at 7:18 PM
    #9786
    essjay
    Concord, CA
    Goddamn. Working hard on that truck.
  7. Oct 16, 2021 at 7:23 PM
    #9787
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I want to get this shit done, so I can get going on my truck.
    The list is twice as long for my truck.
    Visually, (and somewhat functionally, depending on how you look at it) this winter is going to mark the biggest changes to my truck so far.
    nDub and essjay[QUOTED] like this.
  8. Oct 17, 2021 at 6:15 PM
    #9788
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well... Didn't get the entire list done today. But at least we were able to get it back down on 4 wheels.
    Re-install oil pan
    Re-install starter
    Install new CVs
    Replace steering stabilizer bushings
    Re-install sway bar
    Torque new lower control arms
    Adjust and torque new adjustable Upper Control arms
    Replace PCV valve
    Replace spark plugs
    Replace spark plug wires
    Fill oil
    Fill diff oil
    Reconnect battery
    Really, all we didn't get to was the valve covers and the spark plugs. Doesn't seem like we got much done today looking at the list from yesterday, compared to today. lol
    The front seems like it still needs to come down a bit. Hopefully it will settle. Pic was taken about 5 minutes after it was sitting under it's own weight. The torsion keys have a few more turns on them to lower, if needed.
    Thing that sucks about doing this work on a truck someone else lifted, is I'm not sure what was done. Not sure if the torsion keys are stock or if they are lifting torsion keys.
    Blue Canary, essjay and nDub like this.
  9. Oct 18, 2021 at 6:34 PM
    #9789
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    ✔ Spark plugs replaced
    Ordered some new plug wires because, fuck it why not?
    Plus the boot at the plug on the driver side near the fire wall seems worn out. It didn't seem to want to snap on right.
    She damn better be happy with her truck when I'm done lol
  10. Oct 19, 2021 at 7:55 PM
    #9790
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Another day in the Silverado 1500 saga.
    :frusty:
    Valve covers came off pretty easy. I think they may have needed a bit of cleaning.
    Plug wires already got here from Summit. (I just ordered them last night)
    We ran out of daylight, and I'm not in a hurry enough to dick with drop lights so we'll button this bitch up tomorrow. That should be a wrap on this truck... for now.
  11. Oct 20, 2021 at 6:49 PM
    #9791
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I can finally start working on my truck again!
    :taco::taco::taco:
    CemenTRDgen, Twizted, essjay and 3 others like this.
  12. Oct 21, 2021 at 9:00 AM
    #9792
    essjay
    Concord, CA
    Nice work, Matt!
  13. Oct 21, 2021 at 8:16 PM
    #9793
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Parts piling up and more on order for my truck
    :stirthepot:
    CemenTRDgen, essjay and foxrcing07 like this.
  14. Oct 21, 2021 at 8:23 PM
    #9794
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    But did you get a new jack yet:boink:
    https://youtu.be/SaCCm2nM5XY
    I bought the jack and ordered the kit today
  15. Oct 21, 2021 at 8:25 PM
    #9795
    essjay
    Concord, CA
    If you need the shims to fit the extension adapter plate, I think I have some left over from when I did mine. Are you going all-in with the big wheels?
  16. Oct 21, 2021 at 8:27 PM
    #9796
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I am (most likely) going that direction. But I've got quite a few other things to get started.
    This winter is going to be a lot of work.
  17. Oct 21, 2021 at 8:31 PM
    #9797
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I did the 2 ton with 6” wheels
  18. Oct 21, 2021 at 8:39 PM
    #9798
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Did you do the 911Motorsports kit?
  19. Oct 21, 2021 at 9:06 PM
    #9799
    essjay
    Concord, CA
    Ah, nevermind. I did the DIY 1.5 ton with the Pro Eagle extension. Wanted the lightest setup with the smallest footprint.
  20. Oct 21, 2021 at 9:27 PM
    #9800
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    I like the pro eagles, but couldn’t justify the price
    The ProEagle and the 911motorsport conversions are almost identical weight, but the 911MS are about half the price
