209 TACOS - B/S and shenanigans
Discussion in 'Northern California' started by El Taco Diablo, Dec 12, 2017.
  1. Jun 30, 2022 at 8:31 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    It takes a little work but they are worth it if you want to get on harder trails. Hell, even for easier trails they are better. The only place they suck is the highway but 5.29's mostly solves that problem.
  2. Jun 30, 2022 at 8:48 PM
    02hilux
    Planet: EARTH
    Or a slurpercharger
  3. Jun 30, 2022 at 9:26 PM
    CemenTRDgen
    CemenTRDgen Stay Flexible!
    Joshua
    Concord, CA
    2019 DCLB TRDOR Cement
    Bilstein 6112/5160, Icon RXT, BAMF Sliders, Skids, & Hybrid Front Bumper, Warfab Phantom Rear Bumper, & Hitch Skid
    From what I understand the skinny 35s are easier to fit and require less trimming. Kenda Klever 35x10.50R17 or the Mickey Thompson Baja boss AT 255/85R17 (35x10.00R17) both are 34.6" I think. My research has all been for 3rd gen but the same alignment advise applies. Rear cam set to push the LCA out and front cam set to bring it in to give clearance from the firewall and cab mount. Then set SPC to a forward position E or F to reduce the actual caster and it moves the spindle a tiny bit forward as well. CMC and pinch weld and maybe fender trimming. First gens are SICK on 35s since they are so much smaller than 2nd and 3rd gen.
    https://www.tacomaworld.com/threads/35x10-50x17-kenda-klever-r-t-kr601-thread-skinny-35s.657193/
    @Buttskevin21 just posed 49K miles on the Kendas, and just went thru the Rubicon with them.
    https://www.tacomaworld.com/threads...hread-skinny-35s.657193/page-19#post-27500525
    This was a really good post on alignment specs:
    https://www.tacomaworld.com/threads...d-love-alignments.594309/page-7#post-20252854
    Buttskevin21 likes this.
  4. Jun 30, 2022 at 10:45 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Whoop whoop! Yeah the tires are a champ, they have never been the problem when I cant make it up something/get stuck, its always the low breakover angle :rofl:I'm running stock gears, dont mind it at all but I do have a large tranny cooler with a fan to keep the tranny happy on the trail.
  5. Jul 1, 2022 at 8:02 PM
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Doin some shit
  6. Jul 1, 2022 at 8:21 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
  7. Jul 1, 2022 at 8:31 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lmao... No SAS.
    Not on this truck.
  8. Jul 1, 2022 at 8:35 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I backed up the alignment tabs by welding them.
    Need to install the alignment cam eliminators
    Re-boot the CVs
    Install new LCA bushings
    And install the LCA skids
    Tomorrow.
    Then, hopefully I'll start the body lift tomorrow. Once I get the BL done I'm thinking about using Jen's 35s to clearance.
  9. Jul 1, 2022 at 8:39 PM
    theesotericone
    Bishop CA
    Clearance for 35's without the body lift. Cut at least 1/2" more then you "think" you need. Then put on the body lift and 37's. lol
    TacoEspecial likes this.
  10. Jul 1, 2022 at 8:45 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Was thinking, if I'm going to clearance, then take out the coilovers and remove the bumps, and cut 1/2 more than I need.
    You may be on to something... Who wants ta see El Taco Diablo on dirty 7s?
  11. Jul 1, 2022 at 8:50 PM
    theesotericone
    Bishop CA
    That is the way. Put a trans jack under the wheel and lift the rig. Then start clearances. I made a template out of a piece of cardboard on the passenger side once I was happy with the cut. Then I moved the template over to the drivers side. That keeps both cuts as close to the same as your gonna get. I don't have a body lift. I could fit 37's if I put a 1" BL on. There still gonna rub the frame with 3.5" BS wheels but it's only at full lock. My 35's take paint off the front of the frame already. lol
  12. Jul 1, 2022 at 10:45 PM
    nDub
    Lead Free Gasoline
    :wave:
    :oldglory:
    theesotericone likes this.
  13. Jul 3, 2022 at 9:10 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Tank will be on 37s soon. Waiting for after summer
    CalPoppy, TacoEspecial and foxrcing07 like this.
  14. Jul 3, 2022 at 9:25 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I've always said 35s is as big as I'll go on this one.
    But now I'm thinking 37s is going to be as big as I go. lol
    I'd really rather be running RCV if I go 37, but they don't do Toyota, manual, shafts. Maybe I need to do Solo spindles with D44 hubs. (Damn, there really is no bottom to this hole I throw money in)
    Fernando[QUOTED] likes this.
  15. Jul 3, 2022 at 10:13 AM
    02hilux
    Planet: EARTH
    Why not 343/85?
  16. Jul 5, 2022 at 8:15 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Damn they pricey! Maybe I'll stick to 35s :rofl:
  17. Jul 5, 2022 at 12:31 PM
    02hilux
    Planet: EARTH
    :D
  18. Jul 20, 2022 at 12:16 PM
    CemenTRDgen
    Joshua
    Concord, CA
    Had a couple people bail on my planned Niagara Rim run this Saturday so now the crew is down to 2 rigs. If anyone is itching to hit the trail in the vids above @El Taco Diablo posted We will be running it this Saturday 7/23 starting at the sign on 5N01 (38.296171, -119.850728) at 11 am.
    I'll be camping up there Thur 7/21 - Mon 7/25 DM me for details if you want to join.
    nDub and Blue Canary like this.
  19. Jul 23, 2022 at 12:03 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If anyone is interested.
    Hughson Tire has a set of lighly used 285/70R17 BFG Ko2s for 700 bucks.
    They came off the shop owner's truck after about 3000 miles. I know him personally, he's a legit dude. If he says 3K miles, it's true.
  20. Jul 23, 2022 at 8:56 PM
    Blue Canary
    Blue Canary Not responsible for any earthquakes
    Larry
    Stockton
    2015 MGM DCSB
    Pinstripes, dings, and dust.
    We had some friends drop by last night and we decided to head up that way and say Hi. Ran the trail backwards with the hope to get to HBH and turn around. Didn’t quite make it, but it was still a nice drive. A bit of smoke was working it’s way north east. Hope you have some good camp time.
    El Taco Diablo[OP] and TOP TACO like this.
