209 Tacos: "Mod Day"
Discussion in 'Northern California' started by El Taco Diablo, Jul 26, 2018.
  1. Aug 2, 2018 at 4:16 PM
    #81
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    For mounting only I would go to any of the spots on 9th street.
  2. Aug 2, 2018 at 4:18 PM
    #82
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    can you mount/balance them before Saturday?
    Pella likes this.
  3. Aug 2, 2018 at 4:32 PM
    #83
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    truth in these words. I had the same thing happen to me but in Lodi.
  4. Aug 2, 2018 at 4:39 PM
    #84
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I had an alignment done at Tire Pros on Yosemite. They did a good job on the alignment before my truck was lifted... shitty job, when I took it to them after my lift.
  5. Aug 2, 2018 at 4:40 PM
    #85
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @roguegs what exactly are we doing on your lift?
  6. Aug 2, 2018 at 4:48 PM
    #86
    CalTacoma09
    Manteca, CA
    Matt, With everything that is going on I think i'm going to get to your place early try and bleed my brakes and move out of the way. I think that we are going to need more space and hands on Josh and Angelo's rigs (full suspension swap) and UCA and Leafs for Ricky.
    edit : I will bring my jack as well.
    I will bring my tools as well so we have plenty of tools.
    Pella likes this.
  7. Aug 2, 2018 at 4:49 PM
    #87
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Sounds good
  8. Aug 2, 2018 at 4:51 PM
    #88
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @roguegs there's a little tire shop here in Hughson. I just came over here to check with him. He will be open till 3 on Saturday. He said he'll mount and balance for $25 a wheel.
    He's a good guy. I have had him mount quite a few tires for me and have never had a problem with him.
    *** Edit... We can take your wheels/tires over to him and he can be mounting them while we're working on your truck.
    roguegs and Pella like this.
  9. Aug 2, 2018 at 5:31 PM
    #89
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Not a bad idea. I have 5 wheels to be mounted. Only problem is...we need to swap TPMS from my OEM wheels to my new wheels :bananadead:
    Also, the things for this weekend are to compress the spring and raise the C-clip on my 6112s OR use the truck as the weight to compress the spring. Never done either so I would need someone to assist.
    Then install rear AAL from @Drtgrl and that should be about it.
  10. Aug 2, 2018 at 5:34 PM
    #90
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I have @foxrcing07 's spring compressor here. We can make quick work of the front. The AALs are really quick. I think you can actually make a 1 PM alignment appt.
    The guy here in Hughson can deal with TPMS sensors, but it might cost a bit more. We can talk to him on Saturday.
    roguegs[QUOTED] likes this.
  11. Aug 2, 2018 at 5:44 PM
    #91
    roguegs
    Angelo
    V8 T4R
    Do you have an angle grinder? I heard that we might have to chop off the oem retaining clip as it interferes with the AAL pack
  12. Aug 2, 2018 at 5:54 PM
    #92
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Yep
  13. Aug 2, 2018 at 5:56 PM
    #93
    roguegs
    Angelo
    V8 T4R
    Does anyone have lube or grease leftover from their springs? Mine squeak like hell
  14. Aug 2, 2018 at 6:26 PM
    #94
    roguegs
    Angelo
    V8 T4R
    Anyone have a hook up on powdercoating or sand blasting?
  15. Aug 2, 2018 at 6:37 PM
    #95
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    A buddy of mine knows a guy.
  16. Aug 2, 2018 at 8:04 PM
    #96
    roguegs
    Angelo
    V8 T4R
    Do you know a price range by chance? If I keep those trail teams I’m going to powdercoat them.
  17. Aug 2, 2018 at 8:12 PM
    #97
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    My buddy will ask him tomorrow
  18. Aug 2, 2018 at 10:58 PM
    #98
    510to209Taco
    510to209Taco Well-Known Member
    Ricky
    Tuolumne, CA
    2014 Tacoma 4x4 DC
    Front 2.5" Toytec Boss 2.0 Coilover Lift Camburg UCAs OME Heavy Duty Rear Springs Toytec rear shocks 255/85/16 St. Maxx Tires
    I'll plan to be down the hill early then with the leafs to get er done!
  19. Aug 2, 2018 at 11:00 PM
    #99
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    What type of grease should I get to lube my uppers? I’ll bring some brake fluid but what else will I, or anyone else need? @roguegs what necessary fluids are you bringing?
  20. Aug 3, 2018 at 10:37 AM
    #100
    CalTacoma09
    Manteca, CA
    TC should have provided grease with the bushings when installing. The uni ball is a dry lube from what I have heard.
    Pella[QUOTED] likes this.
