209 Tacos: "Mod Day"
Discussion in 'Northern California' started by El Taco Diablo, Jul 26, 2018.
  1. Aug 3, 2018 at 10:46 AM
    #101
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Yes... you're right. Tri-Flow is what I think most people use.
    Pella likes this.
  2. Aug 3, 2018 at 10:56 AM
    #102
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    They did, but wasnt sure how to get the grease from that little tube into the zirc fittings :rofl::rofl::rofl:
    CalTacoma09[QUOTED] likes this.
  3. Aug 3, 2018 at 11:02 AM
    #103
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... I have a small grease gun and that super lube we can get the grease in to the fittings. My grease gun has been acting like a bitch though, so hopefully it'll work.
  4. Aug 3, 2018 at 11:05 AM
    #104
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    I may pick up a grease gun then. I’ll need one eventually anyway.
  5. Aug 3, 2018 at 11:10 AM
    #105
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    If you grab a grease gun and it's the regular size, you need to grab a tube of grease... I only have the small tubes.
    You'll want SuperLube or a Lithium based grease. That will work with Poly or Rubber bushings and boots. Regular oil based grease will eat poly bushings.
    Pella likes this.
  6. Aug 3, 2018 at 11:27 AM
    #106
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    TC says to stay away from lithium and to use ptfe. I’ll get some super lube. Is that used anywhere else on the truck, or just the poly bushings? Most arms I’ve installed were heim joint. I have a grease gun but it’s nasty and full of food grade grease lol. I’ll go see my buddy O’Rielly here in a little bit.
    Edit. Where can I find superlube?
  7. Aug 3, 2018 at 11:44 AM
    #107
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That's wierd cause energy suspension says to use lithium based. I think you can get SuperLube at Napa... I always order it on Amazon.
  8. Aug 3, 2018 at 11:47 AM
    #108
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @roguegs my buddy talked to his guy and a set of wheels powdercoated would be around $350 as long as its not some goofy special mix color.
    Pella likes this.
  9. Aug 3, 2018 at 11:50 AM
    #109
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    And @Pella... I use SuperLube on everything on my truck (except I'll probably use Lucas red and tacky on my CVs when I do them)
    You can even eat SuperLube lol... wouldn't suggest it but it IS even food grade.
    Pella likes this.
  10. Aug 3, 2018 at 12:17 PM
    #110
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    I can’t recall where I read that but it was from TC, may have been in the instructions. Said the lithium isn’t good for poly bushings. I found one tube at Napa, good call. I think I got everything I should need. I’ll bring some torque wrenches and get some Taco stuff tonight.
  11. Aug 3, 2018 at 12:20 PM
    #111
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Been reading up on it. The chemicals in White lithium wont eat the poly but dirt etc sticks to lithium and will cause more wear.
    PTFE is basically teflon. Dirt doesn't stick to it.
    Petrolium based grease will chemically break down poly bushings.
    Pella[QUOTED] likes this.
  12. Aug 3, 2018 at 12:29 PM
    #112
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    I found a dude in Livermore that does 70/wheel
  13. Aug 3, 2018 at 12:48 PM
    #113
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I might need to hit you up on your dude when I get my bumper then lol
  14. Aug 3, 2018 at 2:15 PM
    #114
    roguegs
    Angelo
    V8 T4R
    Sorry fellas...going the cheap mofo route for now lol
    CalTacoma09, foxrcing07 and Pella like this.
  15. Aug 3, 2018 at 2:30 PM
    #115
    510to209Taco
    510to209Taco Well-Known Member
    Ricky
    Tuolumne, CA
    2014 Tacoma 4x4 DC
    Front 2.5" Toytec Boss 2.0 Coilover Lift Camburg UCAs OME Heavy Duty Rear Springs Toytec rear shocks 255/85/16 St. Maxx Tires
    Socks and Sandals.....
    :eek:
  16. Aug 3, 2018 at 2:34 PM
    #116
    roguegs
    Angelo
    V8 T4R
    Aka sick day laziness too cold for no socks and too hot for full shoes
    couplefunones and TOP TACO like this.
  17. Aug 3, 2018 at 2:35 PM
    #117
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :rofl::rofl::rofl:
  18. Aug 3, 2018 at 2:38 PM
    #118
    510to209Taco
    Ricky
    Tuolumne, CA
    2014 Tacoma 4x4 DC
    At least the wheels look good!
    I joke lol. Can't wait for tomorrow
  19. Aug 3, 2018 at 2:44 PM
    #119
    roguegs
    Angelo
    V8 T4R
    I’m pretty sure the mounting will fuck up some part of it so i will have an extra can of dip ready lol
  20. Aug 3, 2018 at 2:53 PM
    #120
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I could never have my socks in between my toes like that.
    :puke:
    unk and CalTacoma09 like this.
