20k service recommendations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, Mar 9, 2009.
  1. Mar 9, 2009 at 9:48 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I know what the service manual says but was just wondering what you guy and gals did it your 20k service? Hey I'm bored, and will be doing mine in the near future.
  2. Mar 9, 2009 at 10:16 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i had my 06, on my 20k..........i did oil and filter change,changed the rear diff oil to synthetic, and rotated my tires. easy peasy.:)
  3. Mar 9, 2009 at 10:27 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    I was tempted to go to syn diff oil. Are you running syn. in your 04? If so how do you like it? Thanks Will.
  4. Mar 9, 2009 at 10:42 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah man.................in my 04, i got synthetic in everything except for the transmission and power steering.:D
    with synthetic in the rear diff and transfer case and front diff............locking the rear and going into 4x4 are alot easier............alot smoother. and there is less drag with synthetic, so you may pick up a bit of mileage as well.
  5. Mar 9, 2009 at 1:28 PM
    jrsmokestacks
    jrsmokestacks Well-Known Member
    Northern, IL
    Long Bed
    Stock work truck
    Only do oil changes until 100,000. It's a Toyota.
  6. Mar 9, 2009 at 1:37 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Not sure if I'd sweat the diff yet. There is very little friction in there since there are only three moving parts. I didn't change mine until last year, and its a 13 year old truck with 215,000. The old oil still looked brand-new. But... it's super easy to do and doesn't take a lot of time. So go for it if you want to. Like everyone else said: oil and air filter change and you're good to go.
  7. Mar 9, 2009 at 4:03 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    I was hoping somone would have a great idea somthing different, I was gonna use the 20k as a good excuse to try it. Thanks guys. Just have the Trans and diffs to convert to synthetic.
  8. Mar 9, 2009 at 4:08 PM
    JWWPHOTO
    JWWPHOTO Well-Known Member
    Westlake, Louisiana
    2008 Tacoma Pre-Runner w/ TRD packag
    Will, that oil did you go with in the rear end....?
    Jeff W. Waldrop
  9. Mar 9, 2009 at 5:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i went with mobil1 75w90. took right over 3 quarts, and i used one of those small bottle/hand pumps.................made it quick and easy.:)
