20TC01 Special Service Campaign (Air Injection Pumps & Air Injection Valves)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlakeyD, Apr 17, 2021.
  1. Apr 17, 2021 at 12:46 PM
    BlakeyD
    BlakeyD [OP] Well-Known Member
    Blake
    CA
    2012 Tacoma TRD Off Road "Tyra"
    I was notified by Toyota about this in either June or July of 2020 and definitely read a few threads floating around about it. I called a couple dealerships and was told because it was a TSB and not an official recall they would not touch it unless I threw the engine codes. As most of us have done, I have just been running the unifilter mod to eliminate the disintegrating foam issue.
    Today I went to purchase my tags and AAA would not release them to me because their system showed there was an outstanding emission recall on my truck. You will also incur a fee if you do not have this addressed by the dealership and present a special certificate to AAA showing that the work was performed by the time your current registration ends. I immediately drove to the dealership and told them I could not receive my tags and they quickly flipped their position and were more than happy to locate/order the parts covered under the
    20TC01 Special Service Campaign. Still waiting to hear back from the dealership on when they can get me in, luckily I have a couple weeks before my registration ends.
    So if you are in California, affected by the 20TC01 and told that you did not have to have this addressed unless you are experiencing the engine codes, you will be unable to renew your registration until you show AAA the dealer certificate showing that the recall was addressed.
    https://www.toyota.com/recall
  2. Apr 20, 2021 at 7:02 PM
    smoothwhitetaco
    smoothwhitetaco Well-Known Member
    2012 DCSB SR5 4X4
    2012 DCSB SR5 4X4
    I actually just bought a truck and looking at the service record it has already had this work done. :kona:
  3. Oct 28, 2021 at 7:34 PM
    Taco1425
    Taco1425 New Member
    Vince
    2012 preruner
    3 inch lift
    I need to get this fixed before I can get registration, with 82,000 my 6 cilínder went bad I had to re do complete engine I wonder if it was because of this recall ? Can someone tell me thanks
  4. Oct 28, 2021 at 8:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve never seen or heard of a case where the Secondary Air Injection Filter caused an engine failure.
    It can/has caused the engine to go into limp mode. AKA: reduced power mode.
    This renders the truck pretty much useless until the problem is fixed. The fix isn’t a whole new engine.
    Why did you have the engine rebuilt replaced?
    What was the reason?
    tcBob and Geeves77 like this.
  5. Oct 30, 2021 at 12:12 PM
    Taco1425
    Taco1425 New Member
    Vince
    2012 preruner
    3 inch lift
    Overheating
  6. Oct 30, 2021 at 12:13 PM
    Taco1425
    Taco1425 New Member
    Vince
    2012 preruner
    3 inch lift
    Keep braking belt, ca compressor wen bad
  7. Oct 30, 2021 at 3:23 PM
    TnShooter
    Deogee
    STOCK
    What he said ^
    The Air Injection pump is electrically operated. The belt has nothing to do with it.
    Fix the compressor and inspect your idlers/pulleys and tensioner while the belt is off.
  8. Apr 3, 2022 at 2:49 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    +1 on this recall stopping me from getting new tags this year!
    I did the Unifilter mod in 2014... nice of Toyota and CA to catch up with the times almost a decade later :rofl:
    My clock is ticking until the end of April... hoping the DMV and dealer will be quick as its my one and only DD :anonymous:
  9. Jun 12, 2022 at 4:32 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    I gotta get this done now. My 2012 threw this code this afternoon. I have 205,033 on the clock.
    Hoping Toyota cooperates nicely along with mileage and their replace it without any issue. Last time I dealt with Toyota was with the Clockspring going bad on my 2006 Taco. There was a Recall on it, but only for specific vins and mine happened to not be apart of it even though I had the same issues arise that included the airbag and cruise control going out.
