20x12 fit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dalton01, Jun 25, 2019.
  1. Jun 25, 2019 at 12:17 AM
    Dalton01
    Dalton01 [OP] Member
    Dalton
    2017 tacoma SR5
    i have a stock 2017 Tacoma can I fit 20x12’s with 3 inch leveling in the front???
  2. Jun 25, 2019 at 12:22 AM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
    Yup but I think your tires will rub when you turn.
  3. Jun 25, 2019 at 12:25 AM
    Dalton01
    Dalton
    2017 tacoma SR5
    I just ordered the leveling kit all I have to do is trim now
  4. Jun 25, 2019 at 12:28 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Bro change your thread title. Help is reserved for people stuck or in an accident an in need of assistance.
    JoeCOVA likes this.
  5. Jun 25, 2019 at 12:30 AM
    El Duderino
    Jeremy
    HI->PNW
    Your tires will for sure rub. Going to need to cab mount chop and get to trimming those will be some wide tires. Try searching around using the search bar other set up. If you go above 2.5” you’ll need aftermarket Upper controls or you will never get a good alignment.
  6. Jun 25, 2019 at 12:47 AM
    Dalton01
    Dalton
    2017 tacoma SR5
    What about body lift?
  7. Jun 25, 2019 at 1:16 AM
    mauigrown
    Your cab mount will still need to be chopped. With wheels that wide you’re going to have to put a drop bracket lift I believe if you don’t want to do a cab mount chop. Body lift will only lift the body, not the cab mount itself.
    El Duderino likes this.
  8. Jun 25, 2019 at 1:50 AM
    El Duderino
    Jeremy
    HI->PNW
