20x9 on 33s
Discussion in 'Wheels & Tires' started by JoedyV, Aug 4, 2011.
  1. Aug 4, 2011 at 3:59 PM
    JoedyV
    JoedyV [OP] Well-Known Member
    Joedy
    TN
    TRD Off-Road Prerunner
    Borla Exhaust K & N intake Morimoto BHLM Retrofits HID fog lights Rear Aux Working Lights BFG A/T KO tires
    I'm looking into making my purchase of 20x9 of 33s. I want to see what you guys think on the offsets and if any trouble on rubbings on your Taco.
    I'm getting 20x9 5.71 in. BS and 18mm Offset. I'm putting them on the Nitto Trail Grappler 295/55R-20 with 3" ProComp lift kit & level kit.
  2. Aug 4, 2011 at 4:06 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    You will rub like crazy with that BS
  3. Aug 4, 2011 at 4:11 PM
    JoedyV
    Joedy
    TN
    What would be a good BS JLee?
  4. Aug 4, 2011 at 4:14 PM
    JLee
    Jerry
    Grass valley CA
    4.5 is ideal for 2nd Gens for the least amount of rubbing. With 20's and that BS your rim might hit the UCA's or put your tire into the frame at full lock and you really can't cut there.
  5. Aug 4, 2011 at 4:16 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    May need spacers
  6. Aug 4, 2011 at 4:17 PM
    JoedyV
    Joedy
    TN
    Yea I wouldn't want that major trouble. How about with 4.53 BS and 12 Offset?
  7. Aug 4, 2011 at 4:19 PM
    JLee
    Jerry
    Grass valley CA
    That's way better but the 9" rim might be the killer. You can always run a 1" wheel spacer if you have rubbing problems.
    Where is KPT anyway he's on point on these tire threads :D
  8. Aug 4, 2011 at 4:23 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    you're gonna end up cutting your fenders anyway but you can at least save from cutting on the frame
  9. Aug 4, 2011 at 4:25 PM
    JoedyV
    Joedy
    TN
    Thanks for the insight JLee. Been a real great help on intel.
  10. Aug 4, 2011 at 4:27 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Sorry I'm late. you should be fine with the 9" wide wheel and the 4.5" backspacing. That's a pretty big tire though and you may need to cut a lot. I'd recommend a 285/55/20. you will still need to trim some with that size though.
  11. Aug 4, 2011 at 4:39 PM
    JoedyV
    Joedy
    TN
    Ok I see what you mean KPT. It's nice to have great help on this forum. I will most likely go with that option n run the 285/55-20
    :yay:
  12. Aug 4, 2011 at 4:56 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    im just curious . . . . . why 20s
  13. Aug 4, 2011 at 5:11 PM
    JoedyV
    Joedy
    TN
    I like the way it looks on them.
  14. Aug 4, 2011 at 7:42 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    good enough for me, was just wondering
  15. Aug 4, 2011 at 8:44 PM
    JoedyV
    Joedy
    TN
    Yea I won't be doing much Off Roading. Mostly be some trails and City/HWY
  16. Aug 5, 2011 at 4:20 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    way to rep Memphis by tha way! I havent seen many on here
  17. Aug 7, 2011 at 11:11 AM
    JoedyV
    Joedy
    TN
    For sure man .. not many at all
