21 SR access cab steering wheel vibration around 60-70mph, 2k rpm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TikeSavage, May 3, 2024.
  1. May 3, 2024 at 6:50 AM
    TikeSavage
    TikeSavage [OP] Member
    2021 tacoma SR 6ftbed
    steering wheel vibration around 60-70mph, 2k rpm.
    if use the "shift-it-yourself” mode and downshift, The RPMS go up, speed stays the same, while the vibration basically goes away. upshift again and it reoccurs.
    occasionally i get a vibration when moderate breaking from that speed, but the steering wheel does not vibrate.
    hard to pin point where its coming from but feels like front of vehicle.
    based on above i would guess the following but wanted everyones input.
    Torque converter, does these have lock up /Over Drive?
    Engine misfiring under load at low rpm?
    rhythmic vibration b/c of something in tranny or engine?
    warped roter?
  2. May 3, 2024 at 7:03 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Maybe you threw a balancing weight on one of the tires. I'd start with the cheap and easy before you start tearing the engine or transmission apart.
    Welcome to TW
  3. May 3, 2024 at 7:20 AM
    TikeSavage
    yeah my plan is to swap driver front tire to rear. drive a week then do passenger.
    was putting thread out there to see if there was any know things to look at first. 30k miles
  4. May 3, 2024 at 8:36 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I had a rhythmic vibration around 50mph on my stock Toyo tires. Rotating them never got rid of the vibration. I never had them re-balanced because wasn’t happy with Toyo anyway.
    I had tread life left but got Michelin LTX Defenders at 40K miles and no more vibration.
    Your situation may be different if down shifting makes the vibration go away. Maybe, try a Road Force balance first.
  5. May 3, 2024 at 8:39 AM
    TA2016
    Oregon
    Also, do you have 4x4 or 2WD? If you have 4x4, does the vibration go away when in 4Hi?
  6. May 3, 2024 at 9:22 AM
    TikeSavage
    4x4. and i have the TOYO tires.. i am actually really impressed with the tread life and overall ability of the tire for the cost. i have read online that the wheels had issues but wasnt sure the year. will change wheels and tires once they are needed in another 15-20k
