21 Tacoma still vibrates after TSB.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daily47, Oct 9, 2021.
  1. Oct 9, 2021 at 12:46 PM
    daily47
    daily47 [OP] Active Member
    I have a 21 Tacoma 4door long bed 4x4 automatic. From mile 0 to now 11,000 the truck will shake when slowing down to a stop, downshifting makes it work. It will still vibrate while slowing down even if I am not using the brakes but it most noticeable when I do use the brakes. I can also pull up on the e brake it will vibrate. Here where it gets confusing. It does NOT do it all the time. Sometime it will be smooth as butter and others it feels like the truck is going to shake apart. So I took it to the dealer and the agreed with me. The replaces the rear drums, surfaced the front rotors and replaces the rear leaf spring under a TSB. T-SB-0071-19. All the work changed nothing. At first I thought warped drums, but it doesn’t do it all the time. Then I thought maybe the pinion angle is off when braking because of the leaf springs. Now I have no idea. Anyone have any insight on the issue? The truck is going back to the dealer in about a week. Here is the link to the TSB. I would say the TSB describes the problem well
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10187246-9999.pdf
  2. Oct 10, 2021 at 5:24 AM
    Ichanz66
    Ichanz66 Active Member
    2004 Tacoma SR5
    keep bringing it back with the same complain. Document what has been done, dates and by whom. Win the Lemon arbitration and you'll end up with a brand new 2022. Gluck.
  3. Oct 10, 2021 at 5:36 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Ok I'm confused. That TSB covers through MY 2019. You said you had a 2021. How does it apply to your truck?
  4. Oct 10, 2021 at 5:36 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What do you mean by, "downshifting makes it work"?
  5. Oct 10, 2021 at 5:37 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I think he meant "worse". Come on, don't you speak typo? LOL :p
  6. Oct 10, 2021 at 5:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Don’t use your brakes
  7. Oct 10, 2021 at 5:43 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’ve learned to speak not only typo but also autocorrect in these modern times haha
  8. Oct 10, 2021 at 6:31 AM
    splitbolt
    NW Arkansas
    No, I doughnut.
  9. Oct 10, 2021 at 7:54 PM
    daily47
    Oops. “Worse”
  10. Oct 10, 2021 at 8:00 PM
    daily47
    yes it applies to my truck. 2016-2021
  11. Oct 10, 2021 at 8:04 PM
    splitbolt
    NW Arkansas
    Downshifting is the computer or you in S-mode
  12. Oct 10, 2021 at 8:05 PM
    daily47
    That would be cool. Time will tell on this one. Thanks
    AusBerg likes this.
  13. Oct 10, 2021 at 8:06 PM
    daily47
    When the computer makes it downshift.
  14. Oct 10, 2021 at 8:14 PM
    Duddits
    Duddits Member
    2021 Tacoma
    Just had my 2021 access cab tacoma fixed for the 25 mph area vibration.
    They replaced the leaf springs, added a steering wheel damper and checked the drive shaft angle. Now it drives so much better with almost no detectable vibration... I noticed this issue at about 400 miles on the truck.
    I had a 2010 v6 4.0 tacoma for 10 years so I was so disappointed to deal with this from a brand new truck also the service tech told me this issue has been active in tacomas since 2015
  15. Oct 10, 2021 at 8:16 PM
    splitbolt
    NW Arkansas
    In particular speed range?
    I'm guessing around 35mph?
  16. Oct 10, 2021 at 8:20 PM
    Duddits
    Duddits Member
    2021 Tacoma
    Mine was at 25 mph mainly but could also feel it anywhere between 20 - 30
  17. Oct 10, 2021 at 8:21 PM
    Duddits
    Duddits Member
    2021 Tacoma
    I said the same thing ...but they did fix it with no cost to me except my time
  18. Oct 10, 2021 at 8:23 PM
    daily47
    it’s most noticeable below 35 mph but it will do it at any speed. I can just drive down the highway and gently pull up on the E break and it will do it most of the time. It feels exactly like warped brakes.
  19. Oct 10, 2021 at 8:28 PM
    Duddits
    Duddits Member
    2021 Tacoma
    I can't understand how leaf springs would cause this but I assuming that toyota is making changes to them to fix this issue.
    I will check my paperwork an see if they did a direct replacement or if it was a new part #.
  20. Oct 10, 2021 at 9:13 PM
    daily47
    I think what is happening is the “driveline” angles change when the rear brakes are applied or you give it gas. The axle is twisting up when you give it gas and down when you break. The leaf springs that were in it we’re not strong enough to counteract those effects. The leaf springs that they put in it seem way stronger. I think this is also called axle wrap. when the driveline angles become too much it can cause vibrations.
